Question about Hitachi 50UX57B 50" Rear Projection Television
Pikish Hue and curved colored lines
After the TV warms up for 10-15 minutes, the screen goes pinkish with red and green curved lines throughout. You can still make out the picture, but it is clouded. The problem appears to be getting worse - meaning it takes less time to cloud up.
    Genius:
  • 1,153 Answers
Sounds like the convergence amp are heating up and going out. you can look for the amps and see if there is a loose connection on the trace and if you can solder you may be able to save them or just replace amps with orginal. This is sometimes caused by moving set around, Set being so heavy it can not take a joult like the direct view sets
Posted on Aug 12, 2007
Tv screen is high in green color what settings do I need to be on
If your TV has a color temperature setting; it is probably on medium. Try it on warm. This will decrease the amount of green and increase the red.
Otherwise you will need access to the tint/hue controls; adjusting it more toward red will help.
Dec 21, 2014 | Televison & Video
Pinkish hue now adjusting the green has no effect all red colors are yellow now
Check all the pins at both ends of the cable, also try it with another PC to make sure it is not the video card paroblem. Please post back the result for further help.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Aug 30, 2010 | HP f2105 21" LCD Monitor
MY SONTY WEGA TRINITRON HAS A PURPLE HUE AT THE TOP OF THE SCREEN. ALSO THE CHANNEL DISPLAY WHICH IS NORMALLY GREEN ON COLOR IS NOW A RED COLOR
This kind of problem occurs if tv screen got hit by some thing that damage internally and its irreparable, second possible cause is magnetic field nearby screen, please check any speaker or some thing that has magnet inside around tv, remove it from tv to fix purple hue at top of screen.
Unplug tv from AC wall socket for 20-25 minutes, replug back in and turn it On, this will demagnetize screen to cure the problem.
Apr 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
For the past week my on my colot tv, everything has a pinkish hue to it . i have played with brightness, contrast, color hue,etc; but cannot get nice color; can see colors but background is washed out and...
It looks like degausing problem. You have taken some pocket radio or magnet near your TV. Mostly in the corners it will appear.
If so,
Try your TV in a different orientation. East to West or............
Try switching on the Tv in this position . Do not use remote. Switch off wait for thirty minutes. Again repeat. The auto deguasing will remove this. But you have patiently do this.
Apr 01, 2010 | Televison & Video
Dell Inspiron 1501 Laptop-6'' Red Vertical Line
The color red and especially red colored lines or a pinkish hue are indicative of an impending screen failure. The only other possibility is that the data cable on the left backside of the lcd panel may be loose at the socket or on the motherboard. 9 times out of 10 though, it is the lcd panel that it failing.
Jan 17, 2010 | Computers & Internet
There is too much green color, i tried hue - contrase - lite etc. but the color is still green
how do i get the red and green hue back on my olevia 227-s11 tv my screen is blue and brown
Dec 09, 2009 | Syntax OLEVIA LT20HV 20 in. LCD Television
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
I have a KP-65WV700 and the screen looks a lil to green
OK, I'm the guy that was having the same problem, but had a blue tint to the screen. I also had blue lines running across the screen, and when I followed the steps below that were posted by another user not only did the lines disappear, but the blue haze vanished as well. My tv looks like it's new again, so you may want to try this:
noavatar_s.gif Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
I have fixed this several times on my KP 65WV700
As Slinteriors posted if it is a thin curved line you need to adjust the screen control, it's sorta like a brightness for each color, and if one color is too high it will produce a thin curved line.
The best way I have found to get to the controls is by removing the lower grey speaker cover front the front of the TV. There are 6 screws if i remember, 3 on each side. Then it snaps off, seems like its going to break but you have to pop it off pretty good.
Once its loose you have to remove a cardboard like cover plate in the center that will give you access to the small controller board.
Now be very careful while experimenting on which knob controls which colors. Turn them very slow, if you turn to fast you will cause your TV to shut down. If this happens, turn the adjustment back to original spot and turn TV back on and take it slow.
Adjust the correct color until the line just goes away. Its easiest to do this with a black screen.
Nov 18, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Colors No longer True
If you are using the component jacks (red, blue, green, red and white) to connect the DVD player to the TV then check that all cables are securely pushed all the way into the jacks on both the DVD player and TV. I have been called to several houses with that exact complaint only to find that those heavy 5-conductor component cables have pulled themselves halfway out of the jacks.
Jul 10, 2007 | JVC XV-523 DVD Player
Hitachi 50UX57B 50" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
