Question about Epson Stylus Photo R300 InkJet Printer
Clean the print head
How do I clean the print head of my Epson Stylus photo 300? The print is a wee bit blurry and not as "solid" as it was. Margery. Thanks so much if you can help.
  • margery Aug 09, 2007
    Thanks but I am not sure I know how to get the print head out. Or do you actually mean the ink cartridges? Margery.
    Novelist:
    Champion:
  • 231 Answers
Hi, the easiest and best way to clean any print head is to put the print head/cartridge in a glass bowl [to avoid ink stains] and pour a small amount of boiling water from your kettle into the bowl, just enough to cover the lower part of the cartridge/print head. then gently agitate the unit up and down for a couple of minutes. Allow it to dry on a paper towel, as soon as its dry replace it and your printer should be fine. Please note that to prolong the life of a cartridge you should print ssomething at least once a week. Goodluck. Regards mistyman
Posted on Aug 09, 2007
Color mismatch and blurry/smudgy prints
Remove ink catridges and clean print head, shake inks and reinstall the inks, if problem persist, Uninstall the driver and reinstall. thats should help. Some time if the print head are dirty it prints multi color. You have to make sure the Head is Clean and install th inks properly.
Dec 10, 2012 | Epson Stylus Photo R1900 InkJet Printer
Printing horizontal solid lines across paper - have done all diagnostic testing but still solid lines across paper.
Hi
Well it is possible that the nozzles are clogged. You did good in troubleshooting the issue, normally head cleaning cycle will resolve that, but if it fails and out of warranty. Best suggestion is to get a new one since head cleaning cycle from printer settings will consume a lot of ink and not a guarantee to work in printers behaving like what you are getting when printing.
Thanks for using Fixya!
Apr 02, 2010 | Epson Stylus photo C87 InkJet Printer
Brown spots appear on the right of prints
I finally fixed it by printing in glossy mode on a thick and rough paper used for manual drawings. A bit of dust came off from under the print head and now it prints clean again.
Jan 16, 2010 | Epson Stylus Photo R200 InkJet Printer
Printing every few lines blurry, but not every line.
Printer head is clogged, be sure to clean it until you get the solid lines
Jul 11, 2009 | Epson Stylus R380 InkJet Photo Printer
Printing problem
Try jiggling the cables and making sure that the USB connection is solid. It worked for me. Good luck.
Sep 03, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus CX5000 blurry or smudged printing
epson uses pigmented ink and compatibles use dyes and thus if the paper is not of good quality then you can have this problem.
do the following
change the paper and try.
As there will be ink in the head and the ink feed tubes , print some 10 -15 copies of all color prints so that the original ink starts to get into the head and then the paper.
this should solve your problem
Also use your printer every 2 -3 days if you dont have any prints then give a noozle check and then switch off the printer. This will avoid the printer from doing a head clean very time you switch on the printer and also the ink will give you more output as there is less amount of head cleaning
bye
Aug 09, 2008 | Epson Stylus CX5000 InkJet Photo Printer
How to remove print head of epson stylus photo r1800
Had the same problem - but the print head is actually easy to remove.
1) Remove ink cartridges
2) Remove 3 Phillips head screws at the bottom of the cartridge housing. (looking down from the printer front - top left, bottom left, top right).
3) There are 2 small plastic tabs on a plastic bracket that secure the flex cable on the right hand side of the cartridge housing. Gently release the tabs with a small flat head screw driver.
4) Lift the print head straight up (don't pull on the flex).
There may be a release for the flex to separate from the print head. But I did not see one. Instead I poured 1/4" of Windex in the bottom of a small plastic container and soaked my print head for about 15 minutes (occasionally agitating).
Then put back in reverse order - be sure to seat the flex in the guide (top-back-right) of the cartridge housing before screwing down. Then run a cleaning or two to flush the cleaning fluid out of the print head. (I have a waste ink tank installed so I am not worried about dumping excessive ink into the waste sponges).
The differences was remarkable - though there was still slight banding - maybe should have soaked longer (1 hr perhaps?) - I may repeat if it remains an issue.
Additionally there were large solid deposits on the left side of the print head which were responsible for scraping heavier weight photo paper. These dissolved in the Windex too.
Jan 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson stylus photo 810 won't print
Is it just not printing on the paper and feeding it thru, or will it just not do anything? I need more info?
Dec 05, 2007 | Epson Stylus Photo 810 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
274 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
