Question about Samsung GT-C3520BLK Unlocked GSM Cell Phone with Camera, Bluetooth and FM Radio - No Warranty - Charcoal Gray
Memory card removed message - Samsung GT-C3520BLK Unlocked GSM Cell Phone with Camera, Bluetooth and FM Radio - No Warranty - Charcoal Gray
My cam says "memory card
If the camera displays Memory card error or No Memory Card when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. If this is the case, you may wish to Format the memory card in the camera using the Setup Menu option [Format] as shown below. Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data. This can also be caused when images shot with another camera are stored on the memory card.
If after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service. If the card appears to be defective you may wish to contact the memory card manufacturer.
Thank you!!
Sep 04, 2011 | Canon PowerShot SX210 IS Digital Camera
1-It turned off by itself 2- it send a message the memory is full
The phone memory of the phone is full.
There are several steps to free memory.
First try to remove attachments in mail and files received in inbox through bluetooth. This will help you to recover some memory.
You can also change the messages on memory card instead of phone memory. To do this, open messaging, select options, other options, memory and change the memory from phone to memory card.
Second remove unwanted software and games from phone memory
If nothing solves the problem, you need to format the phone. First, take a backup of your contacts and messages through Nokia PC Suite. Then format the phone by dialing *#7370# and press yes. But it will remove data from phone memory and free the memory. Then you can restore the data from pc suite.
Reply in case of any problem.
Jun 09, 2011 | Nokia E52 Smartphone
How to remove card error in fujifilm jz300 camera
Welcome to FixYa.
The reasons why do you get a message "CARD ERROR" are:
1. The memory card is not formatted.
2. The memory card requires cleaning or memory card is damaged
3. Incompatible memory card.
4. Camera malfunction.
What do you need to do are:
1. Format the memory card.
2. Clean the contacts with soft and dry cloth. If the message is repeated, format the memory card again. If the message persists, replace the memory card.
3. Use compatible memory card.
4. Contact FujiFilm dealer.
Feel free to send us your comments and suggestion fi this solution was helpful.
Thank you for using FixYa.
Apr 11, 2011 | FUJIFILM FinePix JZ300 Digital Camera
My nokia E63 gives an error message saying "memory full, try shutting down some application" when i try to send a text message.I deleted all messages and both phone memory and card memory are...
The phone could have hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Feb 23, 2011 | Nokia E63 Cell Phone
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
I cannot change my 'Memory in use' from Phone Memory to Memory Card. 'Changing message memory in use' is appearing, but after that, nothing happens, it's still using Phone Memory as storage.
are you doing it for messages, if yes, it works properly but whenever you remove your memory card it reverts to phone memory, you have to revert setting back to memory card
Jun 27, 2010 | Nokia N73 Cellular Phone
My nikon coolpix s51 show message memory card is
For the message that show's on your camera here's is what your need to do. 1. Remove the memory card and check for the physical lock toggle.
2. Toggle the lock on and off.
3. Try blowing on the memory card and the memory card port so it will be cleaned somehow. here is the picture of the lock toggle of the SD memory card 919a7e0.png
Apr 13, 2010 | Nikon COOLPIX S51 Digital Camera
My SMS Storage is full, how do I correct this?
firstly you have to remove some sms if your phone has memory card than go to messing click the message settings than find the option called use memory, here you click the card memory. after applying this first your messaging memory will be extended and secondly your messages will save on memory card
Jul 21, 2009 | Samsung Blackjack SGH-I607 Smartphone
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
Regarding memory card problem
settings meaning if you have the phone reading like themes and sounds from the card once it is remove all of what is being read from the card will not be on the phone until the card is inserted again.
Apr 14, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Samsung GT-C3520BLK Unlocked GSM Cell Phone with Camera, Bluetooth and FM Radio - No Warranty - Charcoal Gray Logo
59 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
