Question about Dryers
I have a GE model# GTUP240EMWW washer/dryer combo. I wired it with the three wire configuration. At first the washer worked but notthe dryer and now neither will work. I checked voltage the breaker, the outlet, the power supply and the unit terminal block. At the terminal block (from top to bottom) I am getting 236V, 0V, and 24V. Can anyone help with this? I cannot figure what would cause this crazy voltage. Continuity is good, fuses are good, please help.
  • 46 Answers
Sounds as if the converter may be bad. The washer needs 120 volts when the dryer 220-2225.The converter determines or supplies which is which.
Posted on Jun 18, 2017
  • Audie Bogus
    Audie Bogus Jun 18, 2017
    Sounds as if the converter may be bad. The washer needs 120 volts when the dryer 220-225.The converter determines or supplies which is which.
localwonder
  • 6784 Answers
SOURCE: maytag electric dryer not heating
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jun 03, 2009
SOURCE: Wiring diagram for Ramsond 18000 BTU Ductless
See link below for detailed wiring. I found it very helpful
http://www.ramsond.com/minisplit/wiring/detailedwire5170.pdf
Posted on Oct 02, 2009
SOURCE: GE front load washer, wbvh5200j1ww. no power.
the door can be manually unlocked by removing the bottom front panel, reach up and there is a pull tab on the lock mechanism. it is a crime that they do not post this online or in the manual, and let folks ruin their clothes.
power problem was a part called the "FILTER" it is where there power cord plugs into, something along the lines of part number 201. cost is $85 plus tax. service man has not seen one of these ever go before.
Posted on Dec 09, 2009
SOURCE: Hot water heater Model EE3J40RD045V
how to change lower heating element on water heater Whirlpool ee3j40rd045v
Posted on Apr 24, 2010
  • 11800 Answers
SOURCE: My TV has a 17pw26-1
No, the voltages are just fine. The fault must be either in the PMW itself or in the HT transformer - and the only way to fix that is to replace the entire inverter board.
Posted on Oct 19, 2010
Model GTUP240EMW
I'd like to help you, can you be more specific about the problem? Are there any fault codes for example? Can you tell me something about how the dryer was working before it stopped working; or what you think led up to its malfunction? Like a power surge or outage? Thank-you
Jul 01, 2014 | GE GTUP240EMWW Laundry : Laundry Centers
Plug problem
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 01, 2009 | Whirlpool LER4634J Electric Dryer
Replacing a 3 prong cord with a 4 prong cord on a Maytag Neptune Model # mde4000ayw
Sep 27, 2009 | Dryers
I have a new 4 prong plug to replace a old 3 prong on dryer
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
Changing dryer plugs
Sep 09, 2009 | GE DCVH515GF Gas Dryer
Convert three pin plug to four pin
Sep 06, 2009 | Frigidaire GLEQ2152ES Electric Dryer
How to attach the cord on the whirlpool dryer model ler3624eq0 -- was working fine, then when i moved it to reconnect the vent, heard a 'pop'. wondering if it's connected correclty in the first place
Aug 30, 2009 | Dryers
GE dryer: DPXQ473ET5WW
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
I tried to get it for you!
The model # DPXQ473ET5WW is not coming up at GE! How old is the unit?
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 27, 2008 | Dryers
Dryers Logo
35 people viewed this question
Top Dryers Experts
