Question about Sceptre Televison & Video
Emerson model LC320EMF
Tv switches on and off and won't stay on
4 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: MY LG TV WON'T SWITCH ON MODEL NO 29FX4RGE-TA
Most likely cause is the power supply board inside the set has failed. I suspect that as it is dead--could be a fuse but a fuse makes no sound when it fails--if you cannot open the set to look take it to a good shop and have it examined.
Posted on Apr 11, 2012
SD Tech
  • 14553 Answers
SOURCE: my emerson tv won't turn on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.6_2_2012_12_46_56_am.jpg6_2_2012_12_47_12_am.jpg
Posted on Jun 02, 2012
SD Tech
  • 14553 Answers
SOURCE: emerson tv....won't turn on...stand by light won't go off
Not making it on or out of standby---first place to look is the power supply for signs of damage or puffed up filter caps there.
Posted on Dec 10, 2012
My emerson lc320em1f tv won't turn on.
Calm down, Calm down! Your power supply board is at fault. On the power supply, you have a bad diode. Location of this diode is D639. Replace it with an NTE 5087A. Thanks for asking, Matt of Martins TV Repair.
Jan 27, 2013 | Televison & Video
Emerson tv....won't turn on...stand by light won't go off
Dec 10, 2012 | Emerson SLC195EM8 LCD TV
13" EMERSON TV WON'T TURN ON?
What can anyone advice what to do with a dead set? Contact any experienced service technician.
Dec 05, 2012 | Emerson SpongeBob SquarePants TV
Component input won't work
There are 2 rows of RCA connectors on the back of this TV.
If you are looking at the back of the TV, on the right side you'll find the connectors.
On the bottom row, left most RCA jack is the Video in for the Component video.
on the top row, the right 2 connectors are for Audio connections.
we put the Yellow plug from our Wii into the bottom row video connector, and the red and white RCA connectors into the top row plugs.
This enabled us to connect the Wii, and play games.
Sep 24, 2012 | Emerson LC391EM3 39 in. LCD HDTV
I have a Emerson 32inch LHD32K20US and it won't
ry changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | Televison & Video
Rcr4258
Setup codes to check with this remote control for Emerson TV are:
1003, 1004, 1009, 1011, 1018, 1021, 1023, 1025, 1026,1028, 1030, 1031, 1033, 1035, 1038, 1039, 1041, 1045,1047, 1054, 1078, 1083, 1109, 1123, 1127, 1128, 1133, 1163, 1165, 1167, 1206, 1207, 1208, 1230
Select any one which your TV accepts. Try each one at a time. It is noted that, after each code check, if it found not working with the TV, you must switch off the TV or unplug the TV from AC mains wall socet, and replug it after a while.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 06, 2012 | RCA Televison & Video
What's my tv code.... I'm have a Emerson tv.
Hello
Three digit universal remote codes for Emerson TV are:
004/ 009/ 014/ 023/ 024/ 025/ 026/ 027/ 030/ 032/ 033/ 034/ 035/ 036/ 037/ 038/ 039/ 040/ 041/ 042/ 043/ 045/ 046/ 049/ 053/ 116/ 135/ 147/ 177/ 179
Four digit codes are:
0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
Direct Code Entry
Feb 12, 2012 | Emerson Televison & Video
Tv won't stay on any one channel for any length of
I had a tv come in doing the same thing and a cap had been ripped from the circuit board I traced it back to the remote input from the front of the chassis. i havve no dea what value to but back so i have replaced it with several various fareds none work perfectly but some are better than others.
Sep 21, 2011 | Emerson LC320EM9 32 in. LCD HDTV
I have an Emerson EWC19T3 that won't stay on. And
EIther the power supply is faulty or the power switch itself is faulty. You can test with test light or ohmeter to be sure the switch is ok. You can use voltmeter to check power from supply to main circuit board
Oct 28, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Televison & Video Logo
77 people viewed this question
Top Sceptre Televison & Video Experts
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
