Question about Hawking Computers & Internet
Technology HOWABN1 HiGain Outdoor Wireless 300N will not connect to router
In set up the device is not recognized in the setup software and will not connect
SOURCE: Linksys WPSM54G No Device
Do a reset on the print server. To do this, hold in the reset button on the back, unplug, then plug in and continue to hold for 10 seconds. Your setup should now detect the print server
Posted on Nov 30, 2008
  • 62 Answers
SOURCE: No connection with wireless router
Have you tried using an ethernet cable instead of a USB cable? USB connections for internet traffic aren't always the best.
If you can make the change to ethernet and then open your command prompt and type ipconfig /all and tell me what ipaddress,subnet mask, and default gateway it says.
Posted on Dec 20, 2008
  • 4 Answers
SOURCE: linksys 300n 1.1 router installation instructions
HERE IS THE LINK TO THE MANUAL
http://downloads.linksysbycisco.com/downloads/WRT300N_ug,0.pdf
Posted on Mar 01, 2009
shadow83
  • 496 Answers
SOURCE: have wireless router in other room PS3 setup can't connect www
  1. Make sure that your wireless Internet is turned on and working properly.
  2. Step 2 Turn on the Playstation 32.gif game console.
  3. Step 3 Access the "Network Settings" screen under the "Settings" screen in the main menu.
  4. Step 4 Select the "Internet Connection" tab and select "yes" when the system displays a new screen.
  5. Step 5 Select "easy" on the new screen that pops up asking what type of installation you want to use.
  6. Step 6 Select "wireless" when it asks you what type of Internet connection you have.
  7. Step 7 Select "scan" on the next screen so that the system searches for all available Internet connections in the area.
  8. Step 8 Select your home Internet when the screen pops up displaying the available Internet options.
  9. Step 9 Save your settings on the next screen.
  10. Step 10 Test the connection to make sure that it works properly.
Posted on Oct 01, 2009
SOURCE: I have a Sitecom WL322 (300N Wireless ADSL modem )
try to change somethink like... wireless settings
Banda : bandVal = 5; bandVal = bandVal-1; var bandTbl = new Array("2.4 GHz (B)","2.4 GHz (N)","2.4 GHz (B+G)", "2.4 GHz (G)", "2.4 GHz (B+G+N)"); for (i=0; i'+bandTbl[i]+''); else document.write(''+bandTbl[i]+''); } 2.4 GHz (B) 2.4 GHz (N) 2.4 GHz (B+G) 2.4 GHz (G) 2.4 GHz (B+G+N) ESSID : document.write(showText(50))Canale : regDomain = 3 defaultChan = 13; var domainMin = new Array("1","1","1","10","10","1"); var domainMax = new Array("11","11","13","11","13","14"); for (i=1; i'+j+''); else document.write(''+j+''); } } } 1 2 3 4 5 6 7 8 9 10 11 12 13 document.write(showText(54))Client associati : document.write('') document.write(showText(85))Analisi del sito : document.write('') document.write((showText(606)))Channel Bandwidth 20/40MHz 20MHz var iDOD = 1-1; document.wlanSetup.wlanNChanWidth.selectedIndex = iDOD; document.write((showText(607)))Extension Channel 9 Root AP SSID : "> document.write(showText(58))Indirizzo MAC 1 : document.write(showText(58))Indirizzo MAC 2 : document.write(showText(58))Indirizzo MAC 3 : document.write(showText(58))Indirizzo MAC 4 : document.write(showText(89))Imposta sicurezza : document.write(showText(89))Imposta sicurezza : document.write(showText(89))Imposta sicurezza : displayObj(); if(wisp==1) document.wlanSetup.chan.disabled=true;
Posted on Jan 25, 2010
How to setup up for repeater mode
This particular Hawking device must be configured after it is connected to your LAN and powered up.
Before you can do this, you will need the software from Hawking. If your devices Serial Number begins with HEMCHWREN1 use the link below"
http://hawkingtech.com/products/downloadfile/114.html
If you have a Revision 1 device with a Serial Number begins with HEMCREN1R1 use this link:
http://hawkingtech.com/products/downloadfile/117.html
Once you have the software, here are the steps you need to follow:
  1. Connect the A/C power adapter to an
    electrical source, and then connect it to the
    'Power' socket of the Range Extender.
  2. Connect your Range Extender to a LAN
    port on the Router or AP that you would
    like to extend (repeat) the range on.
  3. Connect your PC to any of the LAN ports
    located on the back of your router/AP.
  4. Now run the appropriate program you obtained from the instructions in the beginning of the answer.
When the auto-load page appears, click the Setup Wizard option on the right and follow the Setup directions.
Scan for your Range Extender by clicking the 'Search' button. Once found, click the device to highlight it and click 'Next".
Choose a name for your Range Extender. You will use this name to identify and connect to your extended network. Optionally, you may change your login username and password. Click 'Next'.
At this point, the Setup Wizard should automatically obtain a new IP address for your Range Extender from the Router. Please wait for this IP to generate into the IP address field. Note the new IP address and click 'Next' to continue.
In the Search box, find the Wireless Network that you would like to extend. This Range Extender works best with other wireless-N networks, but also supports wireless-B and G networks as well. Select your preferred network and then click 'Next'.
For Security Settings, you must make sure that the Range Extender's security settings are identical to that of the Router/AP that is having the signal extended. If you do not know these settings please contact your network administrator.
At this point the Setup Summary displays all configured settings of the Range Extender. If the information displayed corresponds to your desired networks settings, you can go ahead and click 'SET' to apply the settings. The HWREN1 will automatically reboot. Please be patient.
More information can be obtained on the hawking site:
http://hawkingtech.com/products/hi-gain_wireless_networking/range_extenders_&_repeaters/hwren1.html
Sep 24, 2011 | Hawking Hawkin HiGain HWREN1 Wireless300N...
How to secure the router
HI
please find the ans.
Features
  • Firewall protection for your network
  • Parental control to supervise Internet activity
  • Works with wireless 802.11b/g adapters
  • Backward compatible with 802.11g and 802.11b devices including game consoles and digital media player
  • Secure wireless network using advanced
  • WEP, WPA, or WPA2 encryption
  • Easy to get started with D-Link Quick Router Setup Utility
Description The D-Link DIR-615 Wireless N Router provides better wireless signals for your network than existing wireless 802.11g technology. Upgrading your home to Wireless N provides an excellent solution for sharing an Internet connection and files such as video, music, photos, and documents. D-Link Wireless N products use Intelligent Antenna technology to transmit multiple streams of data which enable you to receive wireless signals in the farthest corners of your home. Not only does D-Link's Wireless N technology extend your wireless range, it also works with your existing 802.11g and 802.11b wireless devices.
Easy To Set Up:
The D-Link Quick Router Setup utility quickly configures your new Wireless N Router to get you up and running in minutes. Our D-Link Quick Router Setup walks you step by step through the installation process to configure your Internet connection, wireless network settings and security, and everything else you need to get your network up and running so that you don't have to be a networking expert to get it set up.
Easy To Secure:
The DIR-615 supports the latest wireless security features to help prevent unauthorized access, be it from over a wireless network or from the Internet. Supportfor WEP, WPA and WPA2 standards ensure that you will be able to use the best possible encryption, regardless of your client devices. In addition, this Wireless N Router utilizes dual active firewalls (SPI and NAT) to prevent potential attacks fromacross the Internet. Delivering great wireless performance, network security and coverage, the D-Link DIR-615 Wireless N Router is ideal for upgrading your existing wireless home network.
Specifications Technical Specifications Standards: IEEE 802.11n (draft) IEEE 802.11g IEEE 802.11b IEEE 802.3 IEEE 802.3u Device Interfaces: 4 10/100 LAN Ports 1 10/100 WAN Port Antennas: Dual external 2dBi Gain reverse SMA antennas Security: 64/128-bit Wired Equivalent Privacy (WEP) data encryption Wi-Fi Protected Access (WPA, WPA2) Advanced Firewall Features: Network Address Translation (NAT) Stateful Packet Inspection (SPI) VPN Pass-through / Multi-sessions PPTP /L2TP / IPSec Device Management: Internet Explorer v6 or late Mozilla Firefox v1.5 or later Java enabled browsers Leds: Power Status WAN WLAN (Wireless Connection) LAN (10/100) Internet Status Power Input: DC 5V 2.5A, through external power adapter Dimensions: 193 x 116.8 x 30.5 mm Weight: 940 grams (0.7 lb) Operating Temperature: 0ºC to 40º C Storage Temperature: -20ºC to 65º C Operating Humidity: 10% to 90% Storage Humidity: 5% to 95% Certifications: FCC Class B IC CE
Dec 11, 2010 | D-Link DIR-615 Wireless Router
I have three dell computers with windows xp that i'm using a d-link 300n wireless router and d-link 300n wireless antena's on the computers. I used the setup cd's that came with the units to install...
download o2 connection manager ( it is used for the broadband dongles but you can still use for this problem ) so when you have downloaded the software install it and then start it, and make sure your wireless is switched on. now by using the o2 connection manager it will disable what ever else is controlling your wireless and o2 connection manager will be the default. you will see a blue box in the left hand corner and this will now scan for your network and obtain your ip address and connect you and stay connected until you want to disconect.
Jul 19, 2010 | D-Link / RangeBooster N 650 / DIR-635 /...
Hawking wireless 300n Won't Reconnect if Router
try turning on an open NAT configuration, opening your ports on the router, look for tutoriales on how to do so.
this will probably solve your problem
Mar 03, 2010 | Computers & Internet
Does thies parts work togeher ?? WLI-PCI-G300N too D-LINK Router?
Hi! the buffalo wireless adapter should connect the the dlink wireless router if the driver is properly setup and configured. and u have to setup as well the dlink router, bcoz there is an option on the router - WISH (Wireless Intelligent Stream Handling) prioritizes the traffic of various wireless applications. u can find that on the setup page and select advance and u will see the option WISH.. here is a help list in order for u to setup the router using the WISH Technology-
WISH is short for Wireless Intelligent Stream Handling, a technology developed to enhance your experience of using a wireless network by prioritizing the traffic of different applications.
WISH Enable WISHEnable this option if you want to allow WISH to prioritize your traffic. Priority Classifiers HTTPAllows the router to recognize HTTP transfers for many common audio and video streams and prioritize them above other traffic. Such streams are frequently used by digital media players.Windows Media Center Enables the router to recognize certain audio and video streams generated by a Windows Media Center PC and to prioritize these above other traffic. Such streams are used by systems known as Windows Media Extenders, such as the Xbox 360. AutomaticWhen enabled, this option causes the router to automatically attempt to prioritize traffic streams that it doesn't otherwise recognize, based on the behavior that the streams exhibit. This acts to deprioritize streams that exhibit bulk transfer characteristics, such as file transfers, while leaving interactive traffic, such as gaming or VoIP, running at a normal priority. WISH Rules A WISH Rule identifies a specific message flow and assigns a priority to that flow. For most applications, the priority classifiers ensure the right priorities and specific WISH Rules are not required. WISH supports overlaps between rules. If more than one rule matches for a specific message flow, the rule with the highest priority will be used.
NameCreate a name for the rule that is meaningful to you.Priority The priority of the message flow is entered here. Four priorities are defined:
  • BK: Background (least urgent).
  • BE: Best Effort.
  • VI: Video.
  • VO: Voice (most urgent).
ProtocolThe protocol used by the messages.Host 1 IP RangeThe rule applies to a flow of messages for which one computer's IP address falls within the range set here.Host 1 Port RangeThe rule applies to a flow of messages for which host 1's port number is within the range set here.Host 2 IP RangeThe rule applies to a flow of messages for which the other computer's IP address falls within the range set here.Host 2 Port RangeThe rule applies to a flow of messages for which host 2's port number is within the range set here. This will work if you will be able to setup the router and the buffalo.. and ofcourse for best performance of this product, it is always advise by the manufacturer to use the same brand in order to work with best features, but this device will work..
Aug 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Unable to get PC to recognize wireless connection with DI-624
Which is it? PC cant connect or not able to setup wireless? If the router came with a setup CD, run that from your pc... Make sure you have a crossover Cat5(ethernet) cable connected between the router and a PC just to set it up initially... within the router can enable or disable wireless function... But to really narrow your device down, i need to know the hardware revision number... its on the same label as the MAC address on the outside of your router
Apr 03, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Frequent disconnects with wrt300n
Ok for starters this wireless technology is still in it's early stages and is being tested while wireless G is still in play. Most of the time if you continue to get kicked off or get no connection at all, this is due to firewall settings. When a device connects to a router of any kind it must send and recieve a signal. Unless you have a static address on your laptop. (an IP address you placed into your wireless adapter setting) Your IP address sometimes changes, it does this when you turn off your computer, log off, etc. Sometimes when reconnecting to your wireless network the IP address changes because it is a dynamic address. A static address never changes. I have found that with some wireless technology devices if a firewall is setup with windows XP the IP address changes thereby not allowing the device to reconnect to the network or be recognized based on the IP change. I have found this alot with wireless printers, external Network storage devices, etc. Sometimes when you take down the firewall your computer will reconnect to the network. Or just go back to the basics: Right click onto the wireless icon at the bottom right near the clock. You should have an option asking you to repair, this helps most of the time.
Most common problems with having be disconnected from your network is when you have a laptop and you use it outside of home on or in another location. Any more questions I have tons of answers. I can also walk you through a network setup!
Nov 25, 2007 | Linksys WRT300N Wireless Router
No connectivity
the 169 address indicates you're not getting an IP address from the router.
I'd start by re-setting the router to defaults. Get it functioning with a wired connection, then do the wireless setup.
Make sure the adapter is recognized in Control panel before proceeding with the wireless setup.
Oct 21, 2007 | Netopia 3-D Reach (TER/GUSB-N1)...
Open Questions:
Computers & Internet Logo
Top Hawking Computers & Internet Experts
WTF Chuck.....
WTF Chuck.....
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
