Question about SATO M-8485Se Thermal Label Printer Print Engine - P/N W08485811
Sato 8485Se going offline
We have a diagraph labeler that has a Sato 8485Se printer on it and it will run for 5-10 minutes tops and then it goes offline and spits a label partway out. Any help would be greatly appreciated
SOURCE: printer problem
check baud rate on NIC card (pull out NIC), against COM settings on PC. they must match. 9600 usually works
Posted on Jan 14, 2008
SOURCE: Sato CL 480e not printing clearly...
Your platen roller (the black rubber roller) isn't smooth in that spot. Maybe it has be nicked or cut there or has something stuck onto it. If it's cut you will have to replace it, otherwise try cleaning it with high percentage isopropyl alcohol.
Posted on Mar 06, 2008
  • 54 Answers
SOURCE: my sato cl408e label printer misses printing on
recalibrate the stock.
Posted on Jan 27, 2010
  • 97 Answers
SOURCE: ribbon not printing correctly on new labels
The ribbon / label combination usually doesn't have anything to do with print position of the fields on the label. Is the quality/durability of the print that you are seeing on the new labels the same as before ? With a glossier stock print quality should actually be better. This will at least tell you that the ribbon is correct for the new label stock. Is the new label a different size than previous labels ? That could account for the fields not printing in the correct position if the printer is not calibrating correctly on the new size.
Not sure if this will help but may give some ideas...
Posted on Apr 08, 2010
  • 121 Answers
SOURCE: Printer goes offline but is pingable on Network
I would see what kind of data is being sent to the printer. If the spooler is trying to send some data to the printer that is outside of its limits, even a page break missing, it will do this. Also see how much data it is trying to send to the printer. If it overwhelms the printer, it will just give up until the spooler stops sending requests.
Posted on Jun 28, 2010
Jun 28, 2010 | SATO CT400 Thermal Label Printer
I have a Sato M-8485S printer and changed my print head 2 times making sure i dont scratch it while i put it on and changed de rubber roller. But still it is well dark at the bottom but light dark after...
Lo mas probable es que requiere que la cabeza sea bien ajustada en su posicion. Lo mejor es que la ajuste un tecnico calificado en impresoras SATO. The most probable is that it requires that the head is tightened into position. The best thing is that adjust by a qualified technician in SATO printers.
Jun 04, 2009 | SATO M-8485Se Thermal Label Printer Print...
Sato 8485se problem whit the papaer ajustment
1-go to the menu
2-media settings
3-Label Lenght ( adjust lenght here) back out and save settings
Aug 26, 2008 | SATO GT408E Thermal Label Printer
Pagesetup Sato CX400 - 2,5x11cm(Hight,width)
Install the software label gallary which has come with Printer CD, design the label over there. It will work
May 08, 2008 | SATO CX400 Thermal Label Printer
Ribbon End
Try changing setup from thermal transfer to direct thermal
Apr 03, 2008 | SATO M-8485Se Thermal Label Printer Print...
Printing
Have you tried using a SATO label Gallery? I think it's more compatible with SATO printer
Apr 13, 2007 | SATO CL408e Thermal Printer
SATO M-8485Se Thermal Label Printer Print Engine - P/N W08485811 Logo
48 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
pkwc
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
