Rca l32hd31yx12 What is the mounting hole pattern on this TV? By that I mean the distances between the holes.
  • 21 Answers
SOURCE: Wall mount Akai LCT 3285TA flat panel TV
You have to get correct wall mount for this model tv.
Posted on Oct 18, 2008
SOURCE: having trouble mounting a LC420SS8 VESA mount
There are 6 mounting screws located on the back panel that can be used as mounts points if you wish to construct a DIY mount (or if you don't want to purchase the official mounting bracket). See the manual for their exact locations.
I used 2 of these screws (the top two) to anchor a twisted steel cable that I designed to work in the same manner as a picture frame cable mount. I then drove a masonry nail into the brick chimney above my fireplace, and connected this steel cable to that mount point. The TV is mounted there, much like the way you would hang a painting (a very large & heavy painting). The bulk of the weight is supported by the front edge of the TV, which rests on a brick mantel that is part of my chimney. The steel cable, while strong enough to fully support the TV, only acts as a balancing wire, or to catch the TV should it topple forward off of the mantel.
Be sure you know how to work with steel cable and have a strong anchor point if you try to use this method. DO NOT USE THIS METHOD FOR DRYWALL ONLY APPLICATIONS. USE FOR EITHER WOOD STUDS or MASONRY APPLICATIONS ONLY.
Posted on Jun 11, 2009
  • 864 Answers
SOURCE: Panasonic TC-P54S1 mounting hole pattern
See page 8 of the manual at: http://service.us.panasonic.com/OPERMANPDF/TCP42S1.PDF The bracket shown there looks like the mounting holes (4?) are vertical on the back of the TV. They may be identified by an arrow pointing to them. There will be two holes on each side of the TV centerline to attach the vertical components of the bracket that hang on the horizontal angle bars on the wall.
Posted on Oct 06, 2009
Select TRNX
  • 4 Answers
SOURCE: wall mounting the LG 42LC2D TV there are holes in
There will be 4 big holes used to install a mounting bracket on the back of the TV.
Posted on Jan 10, 2010
  • 910 Answers
SOURCE: I have SOYO MT-+SYTPT3227AB TV
This TV is not Wall Mountable as the Control Box protrudes and is therefore not suitable for a VESA Wall Mount.
Posted on Jun 10, 2011
Screw size for sony kdl-46v2500 WALL MOUNTING BRACKET BOLTS FOR BACK OF TV
VESA® Hole Pitch: 200 x 200 hole pattern / M6 thread size / 14mm hole depth
Jan 06, 2018 | Sony Televison & Video
Tip
Wheel bolt patterns
OEM wheel bolt patterns & specs
Acura
Alfa Romeo
AMC/Eagle
American motors
Audi
Bentley
BMW
Buick
Cadillac
Chevrolet/GMC
Chrysler
Daiwoo
Daihatsu
Dodge
Ford
Geo
Honda
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
KIA
Land rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Plymouth
Pontiac
Porsche
Peugeot
SAAB
Saturn
Scion
Sterling
Subaru
Suzuki
Toyota
Volkswagen
Volvo
Yugo
Bolt pattern conversions
mm in
A bolt pattern or lug pattern is the diameter of a circle formed by the centers of the wheel lugs. Bolt patterns can be 4, 5, 6, or 8 lug holes. A bolt pattern of 4x100 would indicate a 4 lug pattern on a circle with a diameter of 100 mm. The bolt pattern is comprised of two numbers, the first indicates how many bolt holes are on the wheel, and the second describes how far apart they are. A bolt pattern of 5-115mm would mean the wheel has five bolt holes and they are 115mm apart (measured across the center of the wheel).
Offset
The lists of bolt patterns to the right includes OS (offset) information in the last two columns. The offset of a wheel is the distance from the mounting surface of the wheel to the true centerline of the rim. A positive offset means the mounting surface of the wheel is positioned in front of the true centerline of the rim / tire assembly. This in effect brings the tire in to the fender well more. Conversely, a negative offset means the mounting surface of the wheel is behind the true centerline of the rim / tire assembly. This will cause the tire to stick out away from the vehicle.
The bolt patterns are marked as either H, M, or L
H = High positive offset - FWD Typically +45, 40, 35 offset
M = Medium offset - RWD Typically +20 offset
L = Low offset - RWD Typically 0 offset
Dual bolt patterns
More often called "dual drilled", some manufacturers (usually cheaper ones) are building their wheels with two bolt patterns. This expands the number of fitments the wheel applies to. For example, a wheel with a 4-100/114.3 bolt pattern has 8 lug holes and will fit both 4-100mm and 4-114.3mm fitments. Without close examination, certain wheels can be mistaken for dual bolt pattern wheels, as some manufacturers will sometimes add a second set of holes only for aesthetics and weight savigs. The holes are often straight through and have no mating surface for the wheel lug nuts.
Centerbore
Centerbore relates to the center hole in the wheel that centers the wheel on the hub of the car. Since most wheels are mass produced, they have a large center bore to accommodate several different vehicles. If this is the case, it is recommended that a hub ring is used. Hub rings are hard plastic or metal ring that fits between the wheel and the vehicle. This centers the wheel perfectly on the hub ensuring that there is no run out when the wheel is installed on to the vehicle. Without hub rings it is possible to get vibrations even if the wheel / tire assembly is perfectly balanced.
Measuring bolt patterns
on Apr 15, 2015 | Cars & Trucks
What is the distance from bottom of tv to the lowest set of mounting holes on sony KDL70W850B?
You will have to measure from the center of the hole to the bottom of the screen. Yes - 400mm is the width of the screw, and 300mm is the depth,
Feb 22, 2015 | Sony BRAVIA KDL-70W850B 70" LED TV...
Caravan specs
measure from were the tire bead would sit from side to side, this gives you rim width. measure the distance from the centre of the wheel stud hole to the centre one beside it this gives you distance from hole to hole. the axle dimension measure the width of the axle were the wheel rim would mount against.
Aug 28, 2014 | Dodge Caravan Cars & Trucks
I want to mount my Westinghouse TV, 42", Model W4207. It weighs approximately 35 lbs. I have the pattern for the 8 holes. Is it a universal bracket? Can I buy a multi directional mounting...
When you go to buy your mount, they are rated according to size of the panel. The options available are almost endless. From tilt,to swivel, they'll have what you want. of course, features= $$. Just make sure that you mount it to a stud.
Aug 30, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
HI, I have a RCA Model: L32HD31YX12 TV and when i plug the power and cable into it all I get is a black screen. The green light at the bottom of the TV is on but I'm not sure what to do. Also I do not have...
I have an RCA LCD TV Model#:L32hd31yx12. I have an issue with the settings staying in place when I shut it off then turn it back on I have to reset everything. Is there an update for the firmware for this particular tv???
Dec 26, 2010 | Televison & Video
Oct 06, 2009 | Panasonic TC-P54S1 54 in. Plasma HDTV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
