Question about Dometic 3312024.015 Duo Therm Comfort Control 2 CCC2 Champagne
Find a manual
I need to find a manual for a Duo therm furnace Model # C1356, Type control V5267F, serial #7181
SOURCE: duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Posted on Jul 19, 2008
motor1258
  • 6674 Answers
SOURCE: duo therm air conditionning/furnace thermostat in RV
Checked all breakers & fuses in panel ?
Posted on Aug 14, 2008
carlsbiz
  • 1124 Answers
SOURCE: i have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Posted on Jul 09, 2009
  • 59 Answers
SOURCE: How do I install a blower motor in a duo therm
ITS NOT EASY. YOU NEED A LONG SET OF ALLENS TO LOOSEN BLOWER WHEELS. THIS IS A  DUEL SHAFT MOTOR , BACK COIL NEEDS TO BE PULLED AWAY FROM MOUNT WITHOUT BENDING COPPER. MOTOR BOLTS 3 OF THEM HAVE TO BE REMOVED AND WHEN BOTH BLOWERS ARE REMOVED AND WIRES REMOVED THEN IT CAN BE REMOVED . THE PROBLEM IS THAT THE NEW MOTOR IF IT IS NOT FROM DUO THERM YOU WILL HAVE TO CUT SHAFT TO RIGHT SIZE AND WIRES MAY NOT BE SAME COLOR. IF IT IS SAME MOTOR FROM DUO THERM YOU CAN CUT WIRES AT OLD MOTOR AND WIRE NUT THEM COLOR BY COLOR.
Posted on Apr 22, 2010
SOURCE: duo therm air conditioner that the compressor will not start
your switch should be oopen but when it reaches 41 degrees it should open so the system shuts off before it damages the compresor by sludging it, i have the same unit and my compresor runs for 5 seconds and shuts off, i checked the amp draw at the compresor and it draws 21 22 amps trying to start after the initial 5 second run, but it wont come on againts a load so the comprresos equilizes and tries to start over again with out positive results. i bipass the external obverload on top of compresor terminals area, still no fix yet, the relay on the control board continious to send power to the compresor and still draws , so if there is a problem with the control relay i would open up and dont send power to the compresor so i dont think is the relay, i am a a/c service man for
35 years and do this for a living still today, by experience i think it is the compresor gone bad but will try by passing the relay just to see what happens, also it could be bad capacitor since it have a hard start relay and start capacitor (black )also a run (silver ) capacitor they check ok, there is no way to check the charge unles you install a saddle tap to check presures and rechage this unit i think the compresor replacement is the way to go ( around 250) plus labor and freon r22 e mail add aljpuig@yahoo.com.
Posted on May 06, 2010
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Furnace fault codes ignition lockout fault.. and this means what?
This means the furnace will not operate. Remove the power and then on again to clear it.
Sep 30, 2013 | Dometic 3312024.015 Duo Therm Comfort...
Furnace refuses to cycle off even when room is 20 degrees warmer than setting
Do you know how to access your furnace wiring ? What make/model furnace?
Jan 18, 2013 | Dometic 3109228.001 Duo Therm Comfort...
Where is the fan limit switch on a model 66012-041 duo therm furnace
Here's a good link for you, where you can download a PDF manual for that furnace. The limit switch is normally near back of unit attached to or close to heat chamber. Follow wires that run toward the rear. One will go to one side of limit switch, other will be coming back.
http://bryantrv.com/docs2/docs/operating/dt6600.pdf
Nov 05, 2012 | Dometic Rooftop RV Air Conditioner
New digital therm. air works but no furnace can be found on therm.
What make and model of AC, as well as Make, model of thermostat ? Need that info for proper diagram.
Sep 13, 2012 | Dometic Rooftop RV Air Conditioner
Dometic 3312024.015 Duo Therm Comfort Control 2 CCC2 Champagne Logo
82 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
