Question about GE 21008GE2 Cordless Phone
Display My phone seems to working fine, however my display is unreadable with broken characters and incomlete words.
  • 1 more comment
  • Myron1000 Mar 01, 2008
    One of the two handsets display now has a row of dashes which roll up the screen and a variety of miscellaneous characters flashing in the top rows. Otherwise the phone itself works to make and receive calls. GE support (Thompson) was useless. I got what I paid for.
  • sharray Sep 09, 2008
    The display screen has the numbers and letters missing and broken lines. It is becoming unreadable..Units have new batteries.. Otherwise phones work great.. Can you suggest a solution to the problem..
  • Kissa Jan 08, 2009
    lcd display has gone blank on one GE21008GE2 phone while the other is too dim to read. PHONE HAS NEW BATTERY. What do I do?
SOURCE: ge 5.8 ghz edge phones
I have changed my phones in the bases and it fixed this problem, you also need to make sure it is charged up well. I have problems with the volume even on # 4. Don't you?
Posted on Sep 19, 2007
SOURCE: Display on the cordless phone is distorted.
display reads
NAR FOES********
H4:107 LOUD C3
How do you remove it & get standard display
Posted on Apr 24, 2008
guru_dev
  • 315 Answers
SOURCE: Unreadable Display
I just put new batteries in it will solve your problem...
Posted on Jun 11, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: display is unreadable - partial numbers visible on
A suggestion, it might be time for a battery change
Posted on Jun 12, 2010
archaeology
  • 662 Answers
SOURCE: Display screen unreadable. Removing battery
You have an (unfixable) LCD screen problem - the Liquid Crystal Display is dying (or broken by impact).
The best you can do (without a spare LCD screen and soldering/electronic repair skills) is hope that
there's a workaround that lets you use the phone without the LCD screen working.
Exploring a workaround: call the cordless from your cell phone, and see if you can answer by just using the keypad - if so, then the cordless works and it can be used until the whole phone dies (rather than just the LCD screen).
Most consumers just end up buying a new cordless about every year since these units take too much accidental abuse to last long.
If you decide to scrap the unit, save the battery for recycling at your nearest Home Depot.
They accept
old rechargeable batteries of any type - NiCad types used in cordless phones are especially toxic
(the (heavy metal) cadmium poisons spermatogenesis). Even better, save the battery for your
other GE 25932 5.8 GHz cordless phone - if you have a pair, then its mate's battery is old too.
Posted on Jan 02, 2011
CHARACTERS ARE ILLEGIBLE ON THE DISPLAY WINDOW.
Hi
It seems the problem with display as well as to the charging unit. Display problem can be repaired only br replacing the display. And for your set, its not worth to get the display replaced. You can get the handset to your near service man to check whether the power charging unit works well.
Thank you
Sep 08, 2008 | Motorola Mobility MD451 Cordless Phone
They accept
Jan 02, 2011 | GE 25932 Cordless Phone
Phone works fine if you use keyboard on outside of case. When you open phone, LCD screen displays whitescreen permanently across entire LCD.
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Jan 08, 2010 | Nokia 9300 Smartphone
2001 Grand Prix radio display
replace it with a nice stereo with amp!
Sep 25, 2017 | 2001 Pontiac Grand Prix
TI-89 menus (f1,f2,f3,etc.) a couple words are unreadable
Part of the display control has failed disabling sections of the display. You might check with TI to see if they have a fair repair price, this is not likely to be one you can solve.
The only possibility would be to disassemble the case to gain access to the display. If TI doesn't repair them at a fair cost, you might try to remove the LCD display from its mounting or, if it seems practical, to stress the display from the side. The contacting of an LCD is done with a silicone rubber strip with embedded fine wires that carry the control signals from the printed circuit board to lightly plated corresponding contacts on the glass of the LCD. The positioning of this strip is extremely critical and is dependent on precise pressure on the silicone strip. Yours may have 'slipped' but the error could be cause by poor positioning at the factory that has just now revealed itself. The difference between contact and no contact at the junction of the strip and plated glass area could be a couple thousandths of an inch. You may make it worse instead of better but if it is unreadable anyhow, it really doesn't matter.
Feb 02, 2009 | Texas Instruments TI-89 Calculator
Denon AVR-3802 Front Display problem
This can be either the display itself or the display driver IC havng problems. Something as simple as poor solder connections may cause this as well. Without seeing hte unit, it is difficult to say what the real problem is. If you can solder, try resoldering all of the voltage regulator ICs in the unit. These look like transistors and will be marked 7805 or 7812. If the voltages drift too low because of bad connections, the ICs can get "confused" and not work properly.
Keep us posted.
Dan
Aug 26, 2008 | Denon AVR-3802 Receiver
The text dictionary keeps giving me the wrong words and i cant change, how do you knock it off. the phones a samsung d900i
Using T9 mode
T9 is a predictive text input mode that allows you to
key in any character using single keystrokes.
Entering a word in T9 mode
1. Press [2] to [9] to start entering a word. Press
each key once for each letter.
For example, press [4], [3], [5], [5], and [6] to
enter HELLO in T9 mode.
T9 predicts the word that you are typing, and it
may change with each key that you press.
2. Enter the whole word before editing or deleting
characters.
3. When the word displays correctly, go to step 4.
Otherwise, press [0] to display alternative word
choices for the keys that you have pressed.
For example, OF and ME use [6] and [3].
4. Press [ ] to insert a space and enter the next
word.
Other T9 mode operations
• Press [1] to enter periods or apostrophes
automatically.
• Press [ ] to change case. Lower case (No
indicator), Initial capital ( ), and Capital lock ( )
are available.
• Press [ ] to insert a space.
• Press the Navigation keys to move the cursor.
• Press [C] to delete characters one by one. Press
and hold [C] to clear the display.
Adding a new word to the T9 dictionary
This feature may not be available for some languages.
1. Enter the word that you want to add.
2. Press [0] to display alternative words for your key
presses. When there are no more alternative
words, Spell displays on the bottom line.
3. Press <Spell>.
4. Enter the word you want using ABC mode and
press <OK>.
"The faulty interface lies between the chair and the keyboard"
Apr 21, 2008 | Sony Ericsson w580i Cellular Phone
Nokia N70 phone display unreadable
It seems your display is needs to be replaced. Display can be obtained from open market and you can replace it if you have screw-driver set and little skill. You may send me mail if want to see "How to?". I will send a detailed picture and service manual of N-70 which will help you to know more about your phone. If you found this solution fixing your problem do vote.
Jan 08, 2008 | Nokia N70 Cellular Phone
Siemens Gigaset 2420 Desk Staion LCD Display
That is a common problem with those types of displays, they are sensitive to heat, cold and any movement. They were used by Siemens, and almost all the other manufacturers during this time period. Unfortunately on this particular model, they are not soldered in, they are pressed on by a machine. So if you don't have a Zebra cable press machine ($1000's), and a brand new display, you can only resort to sending it in for repair. Sorry.
Apr 28, 2007 | Siemens Gigaset 2420 Cordless Phone
GE 21008GE2 Cordless Phone Logo
52 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
