Question about Master Bilt (DD26CG)
How to check thermostat on ice cream freezer - Master Bilt (DD26CG)
Ice cream is not freezing on FFUS2613L Frigidaire Refrigerator
Thanks for your post, friend!
I understand that your ice cream inside of your Frigidaire refrigerator, FFUS2613L. I would turn down your thermostat to see if that would help correct the issue of your ice cream not freezing. I hope this helps. -Matt
Sep 30, 2014 | Frigidaire FFUS2613L Side by Side...
Sub zero 361rfd
The problem is in your description. It is the thermostat.
Make sure no loose wires .if no loose wire is found just change out the thermostat
Jun 03, 2017 | Refrigerators
My whirlpool frost free fridge freezer's alarm keeps going off, ice-cream doesn't freeze?
Check condenser is clean, fans working, thermostat set correctly, try to check internal temp with digital thermometer
May 17, 2012 | Refrigerators
My freezer does not keep my ice cream hard, yet it freezes meats, etc. without a problem. What is wrong?
You don't note whether or not you've adjusted the thermostat. Ice cream (and juices) requires at least zero degrees, if not minus 5 degrees, for storage. Meats, fish, bread, etc. can become rock hard at much higher temperatures. Try setting the thermostat lower.
Jun 07, 2011 | Freezers
I have a kenmore upright freezer and can't remember which setting it should be on. It has coldest 1 2 3 etc.
I keep min two notches from the coldest setting.A great way to check where you should set yous,is ice cream.Put an open container of ice cream in the freezer,and turn the freezer to coldest.The next day try to scoop the ice cream.If the ice cream is hard the freezer is too cold.Adjust the freezer two notches ,and try the ice cream the next day.Repeat till you are happy with the hardness of the ice cream.It should be easy to scoop but not too soft.
May 17, 2011 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Ice Cream Server
It is a dual thermostat unit. You could have a bad thermostat, giving you false readings.
May 13, 2010 | Caravell 5.5 cu. ft. / 156 liter Chest...
Ice cream soft
Ice Cream is the hardest thing to freeze in a fridge /freezer unit , you need a least 0 deg F
to harden ice cream. If the ice cream was satisfactory before the repair and the stat is set to max. it is possible you have an over charger refrigeration circuit.
Fuji
Aug 06, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice cream going soft
What is happening is that ice cream has a lower freezing point that water. Perhaps 5-10 degrees for ice cream. Now, the problem with the freezer is 1 of 3 things. 1. Make sure the air vent coming into the freezer is not blocked. 2. Check the thermostat setting and make sure it is on the coldest setting. You can always bring it back up when you get it colder. The thermostat may be going bad. 3. The freezer may be going bad (compressor or other componnets). If it is older than 12-15 years, then you may be better served getting a new one. This may mark the beginning of the end. Check these and let me know how you do.
Feb 25, 2009 | Kenmore 57029 Side by Side Refrigerator
Master Bilt (DD26CG) Logo
Top Master Bilt Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Master Bilt Refrigerator Expert? Answer questions, earn points and help others
