Question about Canon CLC 1120 Color Copier
Potential control pcb drum - Canon CLC 1120 Color Copier
Got an error code E000020-0340. Can anybody help with the code description. Probably one of the drums by the related answers in other posts.
Dear
It may unable to adjust the control voltage at Bk inductance initialization.
1. Check if the Drum Unit (Bk) is installed.
2. Check the Drum Unit Relay PCB (Bk)
3. Check the Drum Unit Memory PCB (Bk)
4. Check the harness/connector between the DC Controller PCB and the Drum Unit Relay PCB (Bk)
5. Replace the Drum Unit (Bk).
6. Replace the DC Controller PCB.
Thanks.
Feb 09, 2015 | Office Equipment & Supplies
Error code E000020-0100
ATR Sensor error or toner supply error. Abnormal detected patch reading value.
1. Check if the Drum Unit (Y) is installed.
2. Check the Drum Unit Relay PCB (Y) (UN26)
3. Check the Drum Unit Memory PCB (Y) (UN30)
4. Check the harness/connector between the DC Controller PCB (UN09/ J25) and the Drum Unit Relay PCB (Y) (UN26).
5. Replace the Drum Unit (Y).
6. Replace the DC Controller PCB (UN09)
May 05, 2014 | Office Equipment & Supplies
Code erro e000061-001 e e000061-002 ir6570
canon copiers model ir6020i show code E000061-0001 what happen wiht my copier and how to solve this problem?
Apr 26, 2011 | Office Equipment & Supplies
Error problem no E000061-0002
The laser shutter is faulty. The laser unit is faulty. The potential measurement
PCB is faulty. The DC controller PCB is faulty.
Mode of
Detection
0001 As the result of potential control, the drum surface potential (VL2)
of the white background is about 200 V (generating solid black images).
0002 The primary charging output used for print output and the drum
surface potential after laser output has been made are about 200 V
Feb 13, 2011 | Canon imageRUNNER 5000 Copier
E000061 error code running problem
this is code for fault in potential measuring pcb .try this solution.enter service mode(press additional function * then 2 and 8 together and again *) on screen select copier > option > po cont :> press 0 > ok. press reset button twice ,switch off machine and restart. make a copy if problem disappears then change potential measuring pcb if u don't wish to replace the pcb machine will still work with potential control off but u will have to adjust copy quality by adjusting primary corona height.
Jan 28, 2011 | Canon imageRUNNER 5000 Copier
E00061
There is a potential control error/there is an APC error.
If the sub code is 0001 As a result of potential control, the drum surface
potential (VL2) of the background is 200 V or
higher (i.e., causing a solid black image).
If the sub code is 0002 The primary charging output used at time of
printer output and the drum surface potential after
laser output is identified as being 200 V or more
Fix - Replace the potential sensor unit.
- Replace the laser scanner unit.
- Replace the DC controller PCB
Note. If you are a technician get yourself a service manual before you try anything, you can get one from eBay item # 330407696483
Good luck, keep me posted
Mar 13, 2010 | Canon IMAGERUNNER 6570 Copier
Ir5000 error code e000062-000. how do I clear it?
E061
Main Cause The laser shutter is faulty. The laser unit is faulty. The potential measurement
Mode of
Detection
IF you are meaning E602 - replace hdd and system software
Feb 16, 2010 | Canon imageRUNNER 5000 Copier
Error code E000061-0001
in ir 6000 E000061-0002 what i do
Nov 21, 2009 | Canon Office Equipment & Supplies
My copier canon IR6000 shows error code E000061-0001. plaese help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} E061
Mode of
Detection
Sep 08, 2009 | Canon imageRUNNER 8500 Copier
Error Code 000061-0001
Error code for 0061-0001
Main cause : The laser shutter is faulty. The laser unit is faulty. The potential measurement PCB is faulty. The DC controller PCB is faulty.
Mode of detection : 0001- As the result of potential control, the drum surface potential (VL2) of the white background is about 200 V (generating solid black images.)
Dec 14, 2007 | Canon imageRUNNER 5000 Copier
Canon CLC 1120 Color Copier Logo
26 people viewed this question
old marine
old marine
