Question about Lionel 1122 Right Hand O27 Remote Control Track Switch
Switch wiring diagrams for lionel track controllers
Need wiring diagram for controller
SOURCE: WE are trying to get our lionel holiday train
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
Posted on Dec 27, 2009
SOURCE: need wire and hook-up diagrams for Lionel train
http://cs.trains.com/TRCCS/forums/t/195035.aspx
Posted on Aug 01, 2011
  • 34 Answers
SOURCE: CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK
Track power is not recommended for this uncoupler. Use an aux fixed supply of at least 10 to 13VAC for the supply. You have to move a jumper on the bottom of the track to do this. Then there will be four wires needed. Two for the aux power (hot and common) and the other two which go to the pushbutton switch.
Note: Same goes for Lionel FasTrack Remote switches. Run the switches from a 10 to 12 VAC aux supply. There is a jumper you remove on the bottom of the switch to connect an aux supply.
Posted on Sep 05, 2011
  • 34 Answers
SOURCE: How to wire a Lionel block signa lwith insulated
Only one outside rail has to be insulated from other sections. A hot wire goes to the signal block. The other wire from the signal block goes to the section of track with the insulated outside rail. When the train passes over the section of track with the isolated rail, a connection is made to the power supply common through the wheel axel. The other wire from the aux supply (common) is connected to the same common as the supply powering the rails. Power the block signal from an aux supply not rail power.
Posted on Oct 05, 2011
technowee362
SOURCE: I have Lionel Fastrack 048
If you power up the track and the light on the actual (track) switch comes on but no power to the toggle switch then the toggle switch may be faulty....I had purchased 2 rh o36 & 2 lh 036 and one of my lh switches did that, so I sent it back for a refund..This is usually where i have been getting my stuff from wholesaletrains.com or you can try on ebay for items you need...Hope this helps
Posted on Apr 06, 2012
Lionel 2330 wiring diagram
Request the wiring diagram directly from Lionel.
Feb 26, 2018 | Crafts & Hobbies
Where can I get a wiring diagram?
NEED WIRING DIAGRAMS FOR LIONEL #1055 TEXAS ...
www.faqqq.com/.../need-wiring-diagrams-for-lionel-1055-texas-lionel-doll...
Question Product: Lionel Dolls, Playsets & Toy Figures Question Details: NEED WIRING DIAGRAMS FOR LIONEL #1055 TEXAS NEED WIRING DIAGRAMS ...
treadmill wiring diagram Dolls, Playsets & Toy Figures ...
www.fixya.com > Forum > Tags > treadmill wiring diagram
Ask your treadmill wiring diagram doll, playset and toy figure questions. ... need a wiring diagram for a massey ferguson 135 tractor lookin for a complete wirng ...
pactrol p16 wiring diagram Dolls, Playsets & Toy Figures ..
Jan 17, 2016 | Toys
Lionel toys
see attached pdf.
Jan 19, 2014 | Lionel Crafts & Hobbies
Need wiring diagram for Lionel 313 Bascule Bridge
There are 5 terminals on the bridge number them from outside to inside 1,2,3,4,5
Terminal 1 gets connected to the outside rails on a V,Z,VW,orZW transformer terminal U. The control button a #96 push button gets connected between terminals 2 and 3. Terminal 3 also gets a wire from A or B on a V or Z or Bor C on a VW/ZW. Terminal 4 gets connected to the transformer terminal D. Terminal 5 gets a wire to the lockon on the black bridge frame. The bridge needs 3 sections of track on each end seperated from the rest of the track as a stopping section remove the center rail pin on this section, This forms the stopping sections at each end of the bridge.
Oct 14, 2013 | Toys
Need diagram for hooking up #252 Lionel Crossing Gate
Here's a link to the Service Manual to the 252 Crossing gate.
http://www.lionel.com/media/servicedocuments/71-2714-250.pdf
Dec 31, 2012 | Lionel O 27 252 Auto Crossing Gate
CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK THRU TRACK POWER - WHAT IS PROPER WAY TO HOOK UP RED AND BLACK WIRES? LIONEL FASTRACK
Apr 27, 2011 | Lionel 12020 Fastrack Remote Uncoupling...
I have Lionel Fastrack 048 switch. I extended the controller wire and all of my slices are perfect. The switch operates but the light in the controller does not operate - neither red or green. I checked...
You will need to check continuity of the yellow RSC wire from inside the controller to where it enters the switch connection block. Neither light will work if this wire is broken.
2nd: Lionel quality control is so poor that if that is not the problem, remove the plate from the bottom and make sure the five plugs are firmly in place on the electronic board. Since both green and red do not work it is most likely not the micro switchs but an issue with the circuit board.
Jan 01, 2011 | Lionel Fastrack O36 Manual Right Hand...
Whenever a piece of rolling stock sits on any portion of the switch track, the solenoid begins to vibrate. This happens with all 6 of my Lionel 027 switches. How can this be stopped? I sometimes have to...
You must use insulator pins on the inside rails than come off the frog. Also make sure each track after the switch is wired with the same polarity. Keep power to center rail and ground to the same outside rail.
Nov 16, 2010 | Lionel 027 Left Hand Remote Control Switch...
Lionel 1122 Right Hand O27 Remote Control Track Switch Logo
189 people viewed this question
Top Lionel Video Game Consoles & Games Experts
James Wishart
Are you a Lionel Video Game Console and Game Expert? Answer questions, earn points and help others
