Question about Minn Kota Minnkota edge 45/ld 45 trolling mo 1355947 image for reference,
Wiring minkota edge 45
Looking for directions on wiring
2 Suggested Answers
  • 8 Answers
SOURCE: my brother inlaw got a minkota 40ta all terraine
I would check the battery. If you're using an old or under charged battery you will loose power for sure. Make sure you're also using a 12v deep cycle marine battery as this will ensure proper operation and a longer battery life.
Posted on Sep 07, 2009
I need a digarm of how the speaker wires in the motherboard
You can try Tiger Direct dot com and look for your m/b.
They usually have diagrams for the speaker pin ID locations numbered 1 thru *16 plus or minus a few in the owners manual I am not positive.
The pins are located on the front side edge usually or along the left hand side edge. Away from the main chip.
There could be other pins on the m/b for speakers to attach but not positive
Jun 27, 2015 | Computers & Internet
Cant seem to stop sqeeky brake noise
My 2008 rear brake used to squeal like a Banshee.
The cure is to remove the pads, and chamfer the leading edge.
By leading edge, I mean the part that the disc enters first.
Imagine making a tape line from the center of the disc to the outside edge of it.
If the wheel were to rotate in the normal direction, the edge of the pad it would hit first is the leading edge.
To illustrate, I'll use this image:
http://image.hotbikeweb.com/f/images/9810852/0804_hbkp_04_z%2b2008_harley_davidson_fat_bob_fxdf%2brear_wheel_view.jpg
The disc would first contact the pads at the top rear of the caliper.
Now, with the pads out, that edge, chamfer at a 45 degree angle.
File or sanding disc.
The, on the back side of the pads (the metal backing that the caliper pistons contact), spray some of this on:
http://www.oreillyauto.com/site/c/detail/CRC0/05017/N0448.oap?ck=Search_N0448_-1_-1&pt=N0448&ppt=C0069
Works everytime for me.
Aug 17, 2013 | 2001 Harley Davidson FLHRCI Road King...
I have an RCA rear projection TV model # 052W25 that once on for about 30-45 min. the screen goes black. I do have sound just no picture. Could this be the bulb? Any suggestions? Thanks
If this is a chassis ITC 222 RCA, then you could have a bad solder connection under the deflection board (this is the board that has the transformer with the large red wire coming out). It's a pickle to turn upside down and has to be done carefully. It has plastic catches on the edges and center of the board. Unplug the ribbon cable to the right and unplug any wires that stop you from turning it upside down. Cold solder joints has to be looked for closely perferably with a magnifying glass. Solder suspected places with rosin core solder and electronic soldering iron.
Jun 10, 2011 | RCA Televison & Video
Is there a built in microphone?
Take a look at the right edge just below the right corner of your keyboard. look for a small hole and itshould have a very small microphone icon on the left side slanted about 45 degrees.
Dec 03, 2010 | Acer Aspire 5500 5570-2609 Laptop
Lookinf for a manual for a minn kota model 55d
call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
May 28, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
It comes up (edge.dat tidak menemukan) as soon as u put it on
Looks like the card dont find the edge.dat.
The edge.dat must be direct on the SD card and not in a folder. Also install the folder Edge with the cheats.dat inside
Jan 26, 2010 | Nintendo DS Console
HOW TO REMOVE Momentus 4200.2 100 GB ATA hard drive FROM MY HP DV8140US NOTEBOOK SO I CAN REPLACE IT.
Here is a direct link to the maintenance & service guide for this laptop model:
http://h10032.www1.hp.com/ctg/Manual/c00554540.pdf
Go to page 93 of this PDF file, & go through the procedure described to remove & replace your hard drive.
Nov 03, 2009 | HP Pavilion dv8140us (EP407UA) PC Notebook
1999 renault espace - rear door won't lock
hi , did you get this problem sorted as i am having same problems
Oct 26, 2009 | Renault Sportwagon Cars & Trucks
My brother inlaw got a minkota 40ta all terraine trolling motor that is supposed to produce 40 pounds of thrust. it does not seem to produce even close to that. is it possible that the motor is turning the...
Apr 18, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
Mitsubishi vs-50603 removing screen for cleaning
Don,
You were in the right place going at it from the front. After removing the grill the bottom edge of the screen has a series of screws holding the lower edging down. Remove the screws and gently but firmly work the sides of the screen frame up to unlatch the top. When you have the screen/frame in your hand just be careful not to go to far with it - wires attaching the panel controls are still attached and don't have a lot of extra length.
Clean the cans, mirror and reverse area of the lenticular screen and re-assemble.
Bill
Mar 11, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Minn Kota Minnkota edge 45/ld 45 trolling mo 1355947 image for reference, Logo
61 people viewed this question
Top Minn Kota Boating Experts
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
Phil Walker
Phil Walker
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
