Question about Refrigerators
Samsung refrigerators rs225dvsw
The swich non fonction
After power breakdown the display of the temprature and all the microswiches do not operate
SOUNDS LIKE YOU GOT A POWER`SURGE WHEN THE POWER WAS RESTORED AN CAUSED THE CONTROL PANEL BURN IF IT IS A SAMSUNG GOOD LUCK HAD ONE CAUGHT FIRE .
Jun 06, 2015 | Refrigerators
Control locked non fonction of the washer
Remove the panel and check for moisture which can make the function erratic. If so dryer using a heater. If not clean and reset the connections, if the inlet does not open when the function is started then it can be fault in the main control board.
Feb 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Its is not fonctionning
first I would recommend to replace the batteries. Or simply put them out and back in, then test if it works. If not, replace for new ones.
Did it stop to work suddenly? Or did you drop it on the floor? If it is not damaged mechanically, then it should work with another Samsung TV, VCR, DVD or other Samsung devices...
Jan 13, 2011 | Samsung BN59-00455A Remote Control
Refrigerator not working
replace the ptc overload contactor relay located on the compressor,it merely unplugs off the compressor and get an exact replacement from most any appliance parts outlet,this component serves to protect and aid in compressor starting and or overloads, this will solve your non-functional units non operation
Jan 01, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
Problème avec camera Nokia 3250 "generale fonction non supporté"
hello
my camera is npt work when i m strt camera then says genral featured is not supported plz help me my mobil model is nokia 3250
Aug 10, 2010 | Nokia 3250 Cellular Phone
New frige
CHECK YOUR DOOR SWICHES AND WIRES. IF THEY REMOVED THE DOORS THE WIRES TO THE SWICHES ARE UNPLUGGED.
May 12, 2010 | Samsung 18.8 Cu. Ft. Bottom-Mount...
Metro psc cell phone Kyocera K612B crash dump nested
salut mon portable a un probleme avec appareil photo quand on actionne il mais comme suivant fonction non suporter je c'est pas sa signifi aider moi sil vous plait merçi
Jul 18, 2008 | Cell Phones
I have a Samsung RS2556BB Refrigerator, purchased in end of year 2004. Looks like the defrost stopped working, cause freezer stop working. A Technicain came as directed by Samsung Customer care, he said it...
Justy a piece of junk. The display has nothing to do with the defrost. Hold your top two buttons for 10 seconds and the displays will reset..good luck.*****
May 30, 2008 | Samsung Refrigerators
Samsung e770
jai un probleme avec le 0 qui ne fonctione pas
Oct 01, 2007 | Samsung SGH-E770 Cellular Phone
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
