Question about Dell A920 InkJet Printer
My Dell A920 Printer will not print
The computer says that my black ink cartridge is half full, and that my full color cartride is fine. But when I go to print, the page feeds through and the printer acts as if it is printing, but the page comes out blank. I run a test page, and the only thing I used to get is a page of blurry chopped up magenta lines. Any help is appreciated...
  • ihategravity Mar 29, 2009
    Acoording to the computer my color ink is half full, and black ink is about a fourth full, but when I tried a test page ( I just got this printer used ) whatever I print has little lines going through it, and even though its supposed to be printing in dark blue it's printing light blue with other colors (red and purple) mixed in.
  • Anonymous Apr 26, 2009
    I have a dell A920 injet printer and i have blank and color ink but It will not print anything.
SOURCE:
SOURCE: Black stopped printing out. Dell 922 all-in-one ink jet.
HI thanks for that and i will try it.
Posted on Jan 15, 2008
Basti
  • 1447 Answers
Did you already run the head cleaning cycle from the utility?
Posted on Apr 23, 2008
SOURCE: Dell 924 printer problem with black cartridge
the printers are set to do this so you will buy there own brand but there is a way to reset the printer so it will work, I"m not exactly sure how, I'm trying to find that out myself. if you ask at the place that refills your cartridges they might be able to tell you
Posted on Jan 08, 2009
  • 7 Answers
SOURCE: When I click "Print" paper feeds through the printer, but nothing prints
Go to printers and faxes folder, right click the printer and go to 'printer preferences'. under preferences go to advanced tab and click on button "more options". uncheck the box that says "use color cartridge to print all black. Click Apply and then OK.
that should resolve the problem if your printer feeds paper through and prints nothing on it, yet it prints when you copy or scan something.
Posted on Feb 17, 2009
T-Mania
  • 42 Answers
SOURCE: A920 printer has ink, feeds paper, but pages come out blank
If this is a new printer have you removed the sealing tabs inside it.
May be caused by bad drivers. Check the vendoes site for the latest drivers for your operating system and see how it goes.
Did it previously work and after swapping something start failing?
Posted on Mar 19, 2009
My Dell A920 black Ink holder broken
call DELL technical support number and ask if there is available spare parts for broken cover replacement, you might end up replacing the whole ink carriage.
Jan 13, 2013 | Dell A920 All-In-One USB Color Inkjet...
My printer has been printing just fine until today. It still "acts" as though it is printing, but a blank page comes out. I have replaces both black and color cartridges and have shut down the...
Have you tried running cleaning the nozzles using the software? Here is a link on how to do it:
http://support.dell.com/support/edocs/systems/A920/a920en1.pdf
just checking that you also removed any "tape" that might have been on the ink cartridges prior to installing them?
Oct 27, 2010 | Dell A920 InkJet Printer
My black ink will not print. Do I have to have
The larger of the two black cartridges is used for text only printing.
The saller cartridge is used for black in graphic images or pictures.
This saves you color ink . It allows you to put the black ink on the image without making the color inks blend the black ink.
Don
Jan 31, 2010 | Canon PIXMA MP780 All-In-One InkJet...
A920 printer will not print in color & the cartridge is OK
is there any more colour ink inside? if there is ink inside you just have to open your printers properties dialog and look for a color option that uses black only. 2. see if the colors are blocked
Feb 07, 2009 | Dell A920 InkJet Printer
I am trying to copy and print with dell A920, but it says: cartridge stall the current print job has been canceled 1. turn the printer off 2. open the cover 3. make sure - the cartridge are snaped into...
Hi and welcome to FixYa,
Initially, check/clean the encoder strip. This would be the long narrow plastic strip with barcode like markings. Ensure that it is clean, no smudges, ink marks or any paper debris that may obstruct a light sensor passing through it other than the barcode like markings.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 11, 2009 | Dell A920 InkJet Printer
Dell 720 printer won't print
Our Dell AIO A940 stopped printing black ink. Tried so many things, and finally (a year later) got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
It's worth a try! Good luck!
Oct 23, 2007 | Dell Inkjet 720 Printer
Flashing Green Light/ Computer can't communicate with printer......
Hi. The flashing code signifies that there is a fault with the connection between the ink cartridge and the printer - usually because either the tape is still on the cartridge or maybe some glue from the tape still on the contacts. In my case, I think the cartridge was simply knackered, so I threw it away and opened yet another ink cartridge. It now works fine.
If you want to test yours, simply take out both ink cartridges, and re-insert them one at a time. If you've put a working cartridge in the flashing will stop; if you've put the dodgy one in it'll still flash. Just replace the dodgy one.
Hope this helps.
Dec 14, 2006 | Dell A920 InkJet Printer
Unable to print using black printer cartridge
Well, Yeah mine did the same thing!!
And I got soooo fusy! and etc. But yeah okay go to the manul script and look for the ink Number then once you find the ink number go and buy the ink that has the same number of ink as yours!
Then,
Once you get home replace it with the others.
BUY THE BLACK INK! not the TRI-COLOR!
Sep 25, 2006 | Dell A920 InkJet Printer
Dell A920 InkJet Printer Logo
545 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
