Question about Sony KV-35S45 35" TV
No color My Sony Trinitron KV-35S45 was manufactured in 7/98. Suddenly, without warning the color was gone. The picture is sharp in black and white. Initially, I could turn it off and back on and the color would return but that only worked for a day or so. Any suggestions? Thank you, Mike
  • marljac Aug 10, 2007
    I actually went through all the cables in the back and found a bad S-video cable. A new one solved the problem. Thanks for the feedback.
    Mike
  • 398 Answers
If the settings are correct and the signal is good but there is no color, it can only be one of 2 things - the CXA jungle IC and the chroma crystal next to it. If you have never replaced small parts on PC boards then have a qualified tech handle it for you.
Posted on Aug 10, 2007
My HP dv6000 laptop screen goes black suddenly, without warning. It is solid black if on battery power; if I have it plugged in to power supply, it is black with flickering white lines.
Your inverter is failing. Under battery power there is not enough DC power for the inverter to convert to High voltage AC power and it goes black. Even under charging, there seems to be evidence that the inverter is failing because there it is unable to consistantly convert the needed power. Check the cables on the back of the display and change your inverter.
Nov 02, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony Trinitron kv-27HFR blurry
the picture tube is gone.
i repaired 150 sony xbr and kv series with that problem.sony has a single gun not three and has a great pix,but burn out faster.
there is a main screen control that you can adjust ,but the tube is gone.
on the back of the crt there is 3 gun drives r g b .
turn the color all the way down so it is black and white.
if there is a green ore purple tint,one gun is out of balance.
ajdusting the r g b controls so that black and white is normal is what you want to do.
the crt board has the screen bias voltage 800volts on it so be very careful and use an insulated screwdriver to adjust the drive controls.
May 13, 2009 | Sony Televison & Video
How to connect laptop to sony kv-35s45
when connected to the tv, change the laptop resolution settings until you get one that is satisfactory.
Aug 23, 2017 | Sony KV-35S45 35" TV
Colors Faded in my sony KV-HA21M83A 21''
Its magnetic effect on picture tube. Power Off TV for 20-30 minutes then turn it On, hope problem will be resolved. Please also check and remove any speaker or some thing have magnet near by TV.
If color spots are still there, picture tube need to degaussed / demagnetized.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Kv-36hs20
Have you tried disabling SVM (scan velocity modulation)? Often touted as a "feature" of TVs, it's a way of artificially making a picture appear sharp. Totally unnecessary. When SVM (sometimes called VM) is on, it can lead to some color bleeding around edges.
Mar 24, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Picture Problem
Your TV's tuner is the problem. 1st thing to try is just to sesolder its connections to the main circuit board. If that doesn't work replace the tuner. Also could put a meter on the power coming into the tuner and see if it is drooping in sync with your picture. Tuners are not that expensive to replace.
Jan 06, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
TV colour problem
how did you explain trouble do you have a problem on tv with color
board ,surely a capacitor has few' capacity' for making the driving on
color that can  be rarely
delfo
Dec 18, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Color is gone in a sony kv-c2963e trinitron tv
as you say that color came back for 15 minutes then went off. this is a clear indication that there is a loose contact or pcb crack somewhere in color section only. if that happens to be ok then check 1 antena or cable socket loose 2 loose connector in color section 3 print open or crack near chroma signal processor. 4 loose near color control. 5 chroma ic night be defective. if you are not tech person take the help of tech.person.
Oct 01, 2007 | Televison & Video
Sony KV-35S45 35" TV Logo
65 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
