Question about Remington PowerMower 17-Inch 60-Volt Cordless/Corded Electric Combination Lawn Mower
Possible charging problem
I bought a new set of 5 replacement batteries for the mower and they will not take a charge. How do I test for charger problems? I use the mower connected to an electrical cord but would like the portablility of cordless in some areas.
2 Suggested Answers
  • 39 Answers
SOURCE: batter life in the second season
When batteries are only used seasonally, and they are stored, they can become damaged from weather or from storing them when they are not fully charged. In general, batteries used seasonally will have a shorter lifespan, so it sounds like you likely need a new battery. Check out http://www.batteryinternational.com/electric-lawn-maintenance-batteries.html for a replacement, and be sure to charge it fully before storing.
Posted on Jun 23, 2009
My battery won't charge even if I replaced it with new battery.
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/laptop-battery.html
Jan 14, 2013 | Computers & Internet
My toshiba P205-S6307 battery is not charging when plugged in
To test your toshiba p205 charger:
To test the laptop:
Jan 07, 2013 | Microsoft Computers & Internet
Why will the battery not charge?
To test the laptop:
Nov 27, 2012 | HP G60-120US Laptop
DELL laptop isnt charging but power cord will keep it on why?
Jenni:
Your battery has died. You'll have to buy another one.
Nov 24, 2012 | Dell Latitude D630 Notebook
My zg5 laptop battery will not power my laptop.battery is new. fully charged.
Hi John,
For the sake of clarity: the battery which will not charge/power your Acer Aspire One Netbook is the original battery that came with the Acer, is this correct?
Assuming that the answer is Yes then replacement with a NON Acer, universal battery is the only solution.
Reputable internet shops, such as Amazon, have these at around $50...
DANGER; Due to the recall of thousands of Acer (HP and others) batteries with a possible fire hazard please dispose of promptly and properly.
Best Buy has a Recycle program:
http://www.bestbuy.com/site/Global-Promotions/Recycle-FAQs/pcmcat174700050009.c?id=pcmcat174700050009
If this link does not work please Google Best Buy Recycle
Thanks!
Jimm
Nov 20, 2012 | Acer Aspire One Netbook 8.9" Notebook
I just bought a new battery charger cable called (Sealed Lead-Acid Charger) to replace an older (Lead Acid battery charger). The New Battery charger will charge for about 2 to 5 minutes and then stop...
ismail the charger you bought should do the job. By stop charging do you mean the light on the charger turns from yellow to green? Your scooter has small batteries 12/12 and don't require along period of charging. Now the scooter has a heat sensor for the batteries and will cut off charging when temp of the batteries gets too high. The older charger could have overcharged your batteries and made them weaker instead of stronger. I would suggest you replace the batteries (2 12/12AH) and charge them with the new charger. Remember to reinstall the heat sensors on each battery when replacing. If you have a digital voltmeter set it to 200 v dc and put the leads into the 2 outer plugs in the charger port on the battery pack. You should read 24-26 volts dc when the batteries are fully charged anything less would mean weak batteries. Hope this helps you
Oct 03, 2010 | Pride Mobility Products Go-Go Elite...
I think my battery is dead. Do I try to charge it
To charge battery, use a trickle charger at 2 amp. Batteries usually only last about 3 years, so if battery is at that age it probably needs replaced. (Replaced my battery with a lawn mower battery that matched the original battery size.) I would try to get a charge on the battery before replacing it. Replacing the battery could be expensive. Battery could also be low on zinc, water, or acid.
May 22, 2010 | 2004 Yamaha V Star Custom
Battery won't charge, 24v charger doesn't light up
Original battery is 130$+, or you can buy replacement for cheapest price (work the same). So, depends from the wallet, choose one... I found them on amazon, take a look:
1. cheapest one (about 30-40$): Amazon com 12N9 4B1 battery
2. Original one (130$+): Finally charging for our multi device world
I hope this was helpful. cheers
Apr 25, 2009 | Garden
Battery Charger displays green blinking light
This is likely a code from the computer system on the CMM1200 that the batteries no longer hold a charge. If you have a voltmeter, a "quick test" is to put the batteries on the charger for at least 8 hours and then test the DC voltage of the batteries. Test each battery separately by taking the cables off and testing the battery at the positive and negative lead. If they read less than 11.5 volts, you need a new battery set. You can get replacements from www.batteryinternational.com/universal-battery-ub12180-batteries-by-brand-universal-battery-nb.html. The model you have requires two of these batteries. Hope this helps.
Dec 25, 2008 | Black & Decker 19" Electric Lawnhog...
Battery won't charge after being replaced
The charger might be bad. Or then the pdas connector is bad, or the motherboard is damaged.
to find out is your charger working you could use a tester to test it or another pda.
If you could get some power into the pda you could use the bootloader to test the device. Its been years since I had my 3850.
Il have to find instructions on how to get to the bootloader but test the other things first.
Drop a comment.
Mar 11, 2008 | HP iPAQ H3835 Pocket PC
Remington PowerMower 17-Inch 60-Volt Cordless/Corded Electric Combination Lawn Mower Logo
23 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
