Question about Fujitsu fi-4990C Path-Through Scanner
Fi-4990c problems- front optical sensor
Hi- Hopefully someone maybe able to help with this problem, after fairly extensive scanning (the counter is reading 178500) the scanner has stopped taking processing additional documents. Mechanically the scanner is working well (it still brings sheets through the machine when conducting paper thickness tests), however upon scanning the documents stay within the hopper by the intial sensors. The subsequent message of 'optical error:front' is now recurring and preventing the additional scanning of sheets. I would be grateful if anyone could point out ways to deal with this problem other than cleaning. I believe the problems could be related to limited memorary levels but I'm not sure. Thanks.
  • vincent7586 Sep 28, 2008
    After Turning my 4990c on it works well and showed getting ready in manual feeding mode. However when i start to scan it show the error message--"Opitcal Error: Front" and it cannt continue. How / What can i do for that?
    Thanks in advance
    vincent
  • 91 Answers
Fi-41990 scanner cleans after scanning 100,000 sheet for paper roller the pad cleans after scanning 100,000 sheets feeding path cleans after 200,000 sheets http://www.fujitsu-europe.com/support/scanner/manuals/consumable-option_3-5-8.pdf
Posted on Aug 10, 2007
  • kimberly puddicombe Aug 10, 2007
    did my solution solve your problem
SOURCE:
How do youfind scan count
If the scan count of your fi-6130 scanner exceeded 2,00,000 scans, then you may have to replace the consumable parts. After replacement of the consumables, you need to rest the consumable counters. To check/reset the Pick/Brake Roller Counter, please follow the steps provided below:
1.Turn on the scanner, and confirm if it is connected correctly to your computer.
2.From the "start" menu, select "All Programs", then select "Scanner Utility for Microsoft Windows", then click on "Software Operation Panel"
3.In the dialog box displayed, from the list on the left of the panel, select "Device Setting"
4.Click the "Clear" button beside the replaced consumable under "Page Counter"
5.Click the "OK" button on the displayed confirmation message. The counter is reset to 0
6.Click the "OK" button to close the "Software Operation Panel" dialog box
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jun 04, 2014 | Fujitsu fi-6130 duplex scanner
Black line 6130
Are the scan settings correctly specified for the scanning application software used? Check if interface cable are correctly connected.When the error occurs on ADF front, clean the glass inside of Base Unit. When the error occurs on ADF back, clean the glass of the Upper Unit.Check if any dirt get on the white reference sheet?
Also, check the mirror of the OPT Unit dirty, clean the mirrors.
Check the connector and check any cables are damaged,if so, then replace the damaged cables.
If the above doesn't help, then the issue may be due Optical unit or Control PCA problem. hence, you may have to seek the help of Fujitsu scanner technicians for rectification.
Thanks & regards,
ScanCare
Apr 25, 2013 | Fujitsu fi-6130 duplex scanner
Has Fujitsu fi-4340c scanner. Worked for a while then it showed Front Side Optical Alarm. I tried to clean sheet path, and replaced roller and pickup pad. Still the same error. Does anyone has the...
Explanation:
Front Side Optical Alarm only generated when start command is received or when white level reference is checked (every 50 scans). CCD output must be above predetermined slice level when reading the white reference. Slice level is set in F/W and compared to the read range values. The read range is approximately pixel 120 to 4800. If CCD output does not reach slice level the AGC tries to adjust the output of the amplifier to exceed the slice level. If any portion of the read range is lower than slice then Optical Alarm is generated. Also, it can be generated by dirty optics or reference, bad lamp or CCD.
Resolution:
If "Front Side Optical Alarm" appeared, clean the glass (small and large one) of the flatbed and carrier unit.
If the issue persists, then check if CCD harness or CR cable is disconnected? Connect the connector.
If the issue persists, then replace Front lamp.
If the issue is not resolved, then replace the Control PCA or Carrier unit or Optical unit.
Pls acknowledge if the issue is resolved.
Regards,
Tech Satya
Dec 08, 2009 | Fujitsu fi-4340C Flatbed Scanner
Fujitsu FI-4220C only scans one page at a time.
The problem is not just to roll over, be changed and separation pad. These two components change very easily and boxes that are delivered and indications for replacement.
These are the codes for parts:
Pad Assembly - Part Number: PA03289-0111
Pick Roller - Part Number: PA03289-0001
After replacement counters to be reset for each Pieces. Open the scanner properties.
Usually have to display a maintenance message on the computer display, such as: separation pad should be replaced.
If there is to scan any messages like that, you have to clean the sensors around the separation pad. They are round and are getting a little inside. Click on the blue button at the top of the ADF and open the lid.
I hope you was helpful.
Aug 10, 2009 | Fujitsu fi-4220C Flatbed Scanner
Fujitsu fi 4750c scanner error
Try a flatbed scan scan with the cover open.  If you see the lamp come on, it's likely a cable or CCD problem, though it can be caused by a really dirty reference strip or mirrors. I've never seen one that dirty but it's mentioned in the service manual. I have seen lost documents in the ADF unit cause backside optical alarms, but the front unit is protected from this by glass. If the lamp doesn't light, it can be a defective lamp or cable. In all these cases, you'll need a tech onsite. Disassembly of this model is difficult & reassembly is even worse. I wouldn't recommend it even if you're mechanically inclined.
Apr 07, 2009 | Fujitsu fi-4750C Flatbed Scanner
M4099d scanner
Attributed to paper sensor problems.
Clean the little square and round paper sensors under swing arm of
upper feed roller asm.
also clean the clear plastic return reflectors.
these may need changing as they taint after time.
Jan 12, 2009 | Fujitsu M4099D/FI-4990C Scanners
Fi4990C
When the scanner scans the first image it will bring in via a set of solenoids a background white Reference metal flap for both rear and front cameras.
The above error comes about when the solenoids are sticking or they have magnetised themselves.
1.Clean the Solenoids.
if scanner still errors .
2. Replace solenoids.
Dec 30, 2008 | Fujitsu M4099D/FI-4990C Scanners
Blank Pages
The scanner's paper sensor may be jammed. IT is sensint there is paper and hence scanning!. Try and fix it. Sensor may be optical or mechanical. If optical remove shreds of paper or dust. If mechanical ensure it moves forward and backward.
S. Mohan. Chennai
May 09, 2008 | Fujitsu fi-5750C Flatbed Scanner
Panaboard KX-B530
I had the same problem on mine.I found it was due to the vertical height of an aluminum window plate, that is attached in front of the CCD optical sensor box, this box is located inside the back aluminum enclosure.
You have to unscrew the back cover and slide it out sideways, be carefull becasue the back cover is heavy and you don't want that falling on someones toes. Also there is some strong adhesive tape holding the cover to the enclosure so you'll have to pry on it a bit to pull the tape loose.
Once you have the cover off, you will be able to see the optical sensor box that is on the far side where the two guard bars (the flat aluminum bars that hold the back panel in place) the two guard bars meet on the one side Like a V.
Right where the bars meet and the V, you should be able to see the small optical box that has a small **** on the face of it and has two small screws on each side of this **** or "window". This is the Window for the optical sensor to pick up the image it is scanning which is a reflection on a mirror that is located on the opposite side of the enclosure. This mirror is about the size of a standard classroom meter stick and it reflects the scribbles of the panaboard surface as the canvas rolls around durring the scanning phase.
If you uncrew the two small screws that are on each side of the Optical sensor window, you will notice that this Window plate will be able to slide back and forth. Adjut this window plate hight and try printing another page and see how the image looks. If the Black bars are bigger then you have moved the plate the wrong way. Readjust and try again. Once you make the proper adjustments the black bars will no longer appear.
Well, this is what fixed mine, so hopefully this will help you.
Regards,
Gerry O'Brien
email: gerryob AT digital-circuitry DOT com
Oct 01, 2007 | Panasonic Panaboard KX-B530 Graphic Tablet
1.st step remove the software from the computer and then reboot. 2nd step install the software. 3rd step try a scan. Still in trouble? 4th step new scanner These items are not repairable.
Jul 01, 2007 | Fujitsu fi-4750C Flatbed Scanner
Fujitsu fi-4990C Path-Through Scanner Logo
340 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Vincent G
Vincent G
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
