Question about Dishwashers
Bosch shx45 dishwasher
Not filling with water
SOURCE: Bosch Dishwasher not letting in water
The float switch may be stuck in the up position which shuts the fill solonoid valve off. you should be able to find the float switch under the lower dish basket.
Posted on Jan 14, 2008
  • 26 Answers
SOURCE: Bosch dishwasher not taking in water
May be open circuit water valve. Appliance will go to error mode if water level has not reached a certain height after a preset time. Check coil continuity with a multi meter. Should be looking for about 200 ohms.
Posted on Nov 12, 2008
  • 1462 Answers
SOURCE: My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Posted on Nov 26, 2008
  • 236 Answers
SOURCE: BOSCH DISHWASHER SMS63E09GB FLASHING E 15 CHECK WATER
it may be either the water meter tank on the l/h side or front water feed hose is blocked with food debris.
Posted on Mar 13, 2009
SOURCE: Bosch SHU 4000 series dishwasher; Water keeps on filling
Follow-up: I was able to fix the problem on Bosch model # SHU 4002UC. Purchased water inlet valve (part number 425458) from Sears Parts Center. I required the Sears unit number from the original invoice as Sears computer system apparently cannot identify the Bosch model number. The valve is as described by meyerjr above; however it is located at the bottom front of the machine so could be replaced (not so easily) without removing the machine. Cost of part was $30.50 Cdn including tax.
lwou
Posted on Apr 20, 2009
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
Have bosch sgs 6312gb it's not filling with water in machine
If it works when water is added the the over flow switch is ok
Here is the diagnostics guide Bosch dishwasher service guide
Nov 23, 2011 | Bosch Dishwashers
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
Bosch dishwasher model SMU4052UC/14, Won't fill
you need to check the water solenoid valve. if you follow the water line coming into the dishwasher you will find the valve(first spot in the water line with two wires coming from it) if you pull the wires off you should see 110 v when it is trying to fill with water if you do then test the valve for continuity.
May 06, 2009 | Bosch 36 Inch Pyramid Chimney Hood - Black
BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
Jan 05, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher---water filling from the bottom when off?
i would replace the inlet valve. it sounds like it is not closing all the way
Dec 29, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher
i know this sounds daft but --
turn off water. disconnect fill hose from water supply. wait 5 seconds and reconnect fill hose then try it out
Oct 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
Owen Barnes
