Question about Water Dispensing & Filtration
Culligan mark 50 water softener parts breakdown
I have a Culligan mark 50 water softener system. It worked great until just recently. I went through the Controller/timer and it still does not cycle properly. Is there a newer controller/timer that I can get and install that is compatible w/ the rest of my system? If so what model and make? Thanks, John
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 306 Answers
These valves are now obsolete and the tank fittings are not compatible with any other manufacturer. Sorry to say it,s time to replace it!
RJ
Posted on Jun 21, 2014
  • 175 Answers
SOURCE: No salt leaving Culligan softener during regen
It sounds like your salt in your salt compartment is stuck. Poor about a couple of gallons of hot water on top of your salt and see if that will break it up and fall down to the bottom of your salt container. Then regenerate your softener after about 3 hours have gone by. You should be back in business.
Posted on Nov 20, 2009
ftw1952
  • 10319 Answers
SOURCE: Culligan 01010091 (mark 89) softener will not auto
clean the drainage filter then it will work correctly again
Posted on Mar 06, 2010
SOURCE: The phone icon is on calligan water softener, how
I have the same problem. Did you ever figure it out?
Posted on May 26, 2010
h2oservices
  • 306 Answers
SOURCE: My Culligan 59 & 512 water softener keeps
Bypass softener. It has a bad solenoid or debris in diaphram.
H2O Services
Posted on Mar 03, 2011
h2oservices
  • 306 Answers
SOURCE: I have a Culligan water softener and noticed
There is a problem with the piston/seal pack assembly pack in the valve. The seals get worn or some debris gets stuck and causes softener to run to the drain. The seal pack assembly needs to be replaced. If you are handy, you can do this. It takes about 1/2 hour for a novice.
Parts are only available from Culligan.
RJ
Posted on Jul 03, 2011
My softener is a Culligan Mark 89. Water looks clear but is real salty. I bypassed the system and purged the lines to get rid of the taste.
Call Culligan for service. You have a serious problem as it sounds like your resin bed is not going through the backwash cycle before returning to operate mode.
Normally when your water softener goes through a recharge cycle, a solenoid operates to bypass the system while brine (extremely salty water) is drawn into the resin tank to perform the ion exchange process. This is a timed process. Once it completes then your softener switches into backwash mode where the resin bed is flushed with clear water. Finally at the end of the recharge cycle the softner switches back into normal operation.
This is not something that you can fix yourself. Contact Culligan immediately.
Nov 01, 2014 | Measuring Tools & Sensors
WHERE IS OUR SOFT WATER!? A few years back we had the Culligan man out to check our water because it was not soft (at the time, we had the Culligan Mark 100 model). After testing our water, the suggested...
The most frequent causes for intermittent hard water would be the gallon settings set too low causing the softener to run out of capacity or a meter that is not measuring the gallons. I would set the "hardness" setting on your culligan softener 30% higher than actual hardness. The softening resins they use are low in crosslink and very inefficient. Also make sure there are no toilets leaking causing hard water to "bleed" through softener. Iron filters require regular maintenance to clear oxidized iron from nozzles and the valve. Generally it is better to have the iron filter regenerate at least every 3 days to keep the bed refreshed.
RJ
Mar 01, 2012 | Culligan Sediment Water Filter
I have culligan house water softner. after i changed my hot water heater my softner stopped working. I dont have a manual to check. any suggestions?
Unless the softener was bypassed when the water heater went in, installing a water heater has no bearing on the softener working or not. Is it unplugged?
RJ
Aug 27, 2010 | Culligan 34" Whole House Water Filter...
Need settings for a culligan Mark 49 softener
I have the mark 49 catalog...maybe I could help you? westyolandal@gmail.com
This whole thing is new to me....I am trying to figure out how to even use the thing?
May 25, 2010 | Culligan Sediment Water Filter
Mar 05, 2010 | Culligan Sediment Water Filter
Proper Disposal of a Culligan Mark 50 Water Treatment Tank?
If you disassemble the valve completely (all metal parts) the valve itself is delrin plastic and is recyclable along with the brine tank. You may be able to scrap the softener tank. You will have to get all the resin and gravel out of it. Just tip it over take the inlet manifold out and drain the resin into a bucket, take the resin to culligan for disposal.
RJ
Jan 02, 2010 | Culligan Sediment Water Filter Heavy Duty
O-rings leak on a culligan mark 50 water conditioner
Neither a manual or parts are available for this this valve. It is obsolete.
RJ
Nov 22, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
I NEED A SERVICE MANUAL FOR MY CULLIGAN WATER SOFTENER. MODEL# 01014556 SERIAL# 2903H0010
Your best course of action is to contact Culligan here:
http://www.culligan-store.com/contact.asp
Nov 15, 2009 | Culligan Sediment Water Filter
I have a Culligan water softener and noticed recently that there is a running water sound coming from the drain tube. There is no leaking, and the sound is almost like a constant trickle. It stops if we...
RJ
Jul 12, 2009 | Culligan Sediment Water Filter
Culligan Silver Water Softener - Continues to Run
Same problem, no answer... incredible how strong is the "culligan maffia"...
Jun 26, 2009 | Dishwashers
Water Dispensing & Filtration Logo
259 people viewed this question
Top Water Dispensing & Filtration Experts
ray gallant
Tom Chichester
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Are you a Water Dispensing and Filtration Expert? Answer questions, earn points and help others
