Question about Singer Sewing Machines
Loud sound with brand new Singer 4111
I purchase a 4111 last Thursday. I am repairing 3mm Neoprene bags (reinforcing handle) so a total of about 6" sewing per bag. I have done approx. 50 bags and on my second one this morning my machine started making a very loud "clapping" sound when sewing. Top and bottom threads are both fine. I took off the plate and can see the bottom foot is getting caught in the back and not rotating smoothly. HELP!!
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 152 Answers
Oil the "feed dogs" (movement under the pressure foot) make sure your needle has not slide down. Try sewing on lighter weight fabric until you solve the problem. No clapping noise is good.
Posted on Aug 05, 2017
  • 128 Answers
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
Posted on Apr 19, 2009
  • 23 Answers
SOURCE: Thread getting caught in bobbin area
If you are seeing the needle thread in loops and birdnests then its the needle thread you need to check. The main reason is it is not threaded through the takeup spring(the one that moves) This action is critical as it is how the thread is pulled up tight. Also make sure the needle thread is between the discs and that it has sufficient tension that you do not see it on the bottom of the material. Try this: Use two different color threads for needle and bobbin. If you see the needle color on the bottom then the needle thread is not tight enough (or in 5% of the cases the bobbin is too tight or hung up). Let me know how it does. Jay
Posted on May 29, 2009
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
  • 980 Answers
SOURCE: Threading bobbin on singer stylist 522
To wind a bobbin put the cotton reel on the top pin, take the thread to the left and round the little wheel and back to the bobbin that should be on the winder, wind the thread round a few times to take a grip, release the stop motion in the balance wheel, turn the winder button so the winder moves to the balance wheel and press on the foot control slowly.
When you put the bobbin in the bobbin case make sure it turns anti clockwise.
Posted on Jun 27, 2009
  • 152 Answers
SOURCE: bobbin thread gets bunched up and loud clicking sound
The problem is never the bobbin when you have this problem. It's the top thread. Take the thread off the top of the machine and rethread the top. Make sure the small tension dial is on 4 or 5 (the larger dial on the front left is for the pressure on the foot, not the thread tension.) After you thread the machine, put the pressure foot down but NOT on the thread. Then pull gently toward the back of the machine. When you do, the needle should bend slightly backwards before the thread comes through the machine. If it pulls with no resistance you could simply have "fluff" or remants of thread between your tension discs. If you do, put the dial on zero and using an old needle, clean between the discs and try threading the machine again with the "pull test" I described earlier.
No tension on the top of the machine, lets the bobbin tension win and it pulls all the thread to the bottom of the fabric.
Posted on Oct 06, 2009
Bernina embroidery machine in kerala dealar?
Hi, Putting hooped items onto the machine can bump a presser foot and bend it. a strap/handle, on a tote bag can catch and bend a presser foot.
These are intricate machines, and do require trained technicians to service them from time to time. Always have your machine serviced at a authorized repair center.
Embroidery Services
San Diego, CA
Jun 28, 2016 | Bernina Sewing Machines
How does a presser foot get out of alignment for a pr600ii embroidery machine?
Hi, Putting hooped items onto the machine can bump a presser foot and bend it. a strap/handle on a tote bag can catch and bend a presser foot.
Embroidery Services
San Diego, CA
May 03, 2016 | Sewing Machines
I lost my instructions for pattern 5527 (diaper bag). Can you help?
You could contact Simplicity and see if they can help.
or find a free diaper bag pattern on line and use as a guide.
bags arent too difficilt, usually need to interface well, attach pockets, straps, then sew lining to top edge wrong side to wrong side, leaving a bit of the lining or side seam open so you can get inside to attach lining seam allowances to bag seam allowances to hold together.
Simplicity 5527 Diaper Bag in Three Sizes
Feb 28, 2015 | Sewing Machines
I need the Manual for the White Sewing machine model 1418.
go to this website link and type in W1418 to locate your manual as a free download. It is available there.
You can download it as a pdf file, it will take a few seconds to load to screen so just wait. Then Save it to your PC. A good idea is to print it out (double sided if you can) and get it bound with covers so you've got a good hard copy to keep with the machine. I saw a great idea to keep manuals and machines together: get a large ziplok bag bigger than the manual and attach to the sewing machine case handle with a zip tie in one corner. Then you can drop the manual back into the bag when not needed and it will always stay with the machine!
Hope this helps you out, 4 thumbs up if so. Happy Sewing, Tally Girl
Sep 16, 2011 | White Sewing 1418 Mechanical Sewing...
I am having a terrible time sewing through several layers on trim on pockets that I attach to the front of tote bags. I sell these totes and need a polished, professional look. When I bought this...
try a
Jean-a-ma-jig or Hump-jumper
trying to sew over a bump of fabric, such as a thick jean hem, try using this tool
local fabric store should carry it
It keeps your pressure foot level as you sew over the
you said your needle plate has many strike marks on it,,make sure you can't feel the strike marks so the fabric won't hang on them,,because marks on a needle plate can pulled the fabric
Sep 01, 2010 | Husqvarna Designer I
What happens if the needle breaks?
Extra needles came in the accessory bag. Just unscrew the screw above the presser foot, remove the old needle and put in a new one. These are common sewing machine needles,but the LS2125 will also handle dual needles. There are numerous videos online that show how to do this.
May 17, 2010 | Brother LS-2125 Mechanical Sewing Machine
Take your machine in for service.
If this machine is still under warranty, make sure you take it to a dealer who is authorized to work on the brand of machine you have.
If this is a used machine - take it to anyone who fixes sewing machine as any warranty the machine had expired when it was resold.
You will be charged around $50 for the repair person to just look at the machine.
Mar 27, 2010 | Sewing Machines
Sewing leather
leather needles, they make little cuts in the leather as opposed to normal needles that try to punch wholes, which does not with such dense material as leather.
Oct 23, 2009 | Janome 8080 Computerized Sewing Machine
My needle broke all of a sudden
The needle might not have been fully seated and tightened down - or vibrated loose and dropped down a bit and got hit by the bobbin shuttle. My mom used to soap or wax her needles (lower by hand into a candle or bar of Ivory) to sew stuff like DUCK, Burlap or thick denim.
Try thisusing a new needle (they're cheap) but be SURE that needle is all the way up into the carrier ;-)
Mar 26, 2009 | Yamata FY101-1A
Hemline Studio Collection Sewing Machine Bag $34.95$29.99. Click for more info · Hemline Studio Collection Serger Bag $34.95$29.99. Click for more info ... Category > Sewing Cases','');">
callthis number tell ur model
Click on the link for information on the available bags. You can order the bags through Bob McDougal's by calling 1-877-408-7005
Sep 17, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
69 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
