FGHD2433KF1 REPLACED TOUCHPAD AND CONTROL BOARD SAME RESULTS. NORMAL AND CHINA ARE THE ONLY BUTTONS THAT DON'T WORK
SOURCE: Touchpad does not work
in such case you can restore your program to old date...such as 5 days before.. hope your touhpad will work like before..
restore your program to the early date from when your touchpad was working...
reinstall touchpad driver....
otherwise you have to reinstall your Operating System...
SOURCE: got a laptop for 55th
I do not know what is really the problem, but you can go on this site http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=115&prodTypeId=321957&prodSeriesId=4169434
SOURCE: my eee pc 901 doesn't
Hi
It seems to be there is pressed button and should be released.
Try with the control keys like ( Ctrl, Alt, Shift, both right and left, and Fn key ).
Press these keys hardly ( not much ) to release them,
Please, Tell us your results.
Good Luck
SOURCE: Acer Aspire 5102 I've reinstalled win
You will need to install the touchpad driver. The native windows driver will operate the basic functions, but for scrolling etc, you need the driver from Acer (Synaptics)
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=44
If you have a external mouse, or you can borrow, go into device manager to see if the pad is enabled, if okay! try a system restore bringing the computer back in time before this happened, if still no luck the sensor pad maybe defective, the last option a complete recovery of the operational system to factory setting, this will prove if the sensor pad is defective, or wire ribbon might have come loose from the motherboard.
