Sanyo washing machine problem
The washing machine wouldn't pump water out, after the wash.(as shown in the video). Any help would be much appreciated.
    Master:
  • 563 Answers
Check for debris blocking the drain pump. Also check for power to the drain pump.
Posted on May 04, 2013
  • 209 Answers
SOURCE: my washing machine is full of water!!!
check pump for open circuit electrically, if that is fine and the pump works but just doesn't drain then its a blockage somewhere between the drum and the waste outlet, strip the pipes and clean out, taking care to note original position of any parts and wires etc
Posted on Oct 14, 2007
  • 236 Answers
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
Posted on Mar 16, 2009
SOURCE: WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
Posted on May 20, 2009
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
  • 41 Answers
SOURCE: Washing machine won't rinse, drain or spin
COULD BE THE PUMP MOTOR GONE BUT FIRST CHECK THE FLUF FILTER IF FITTED
Posted on Jan 09, 2010
REPLACE PUMP
easy
  • How to Replace a Washing Machine Water Pump: 12 Steps www.wikihow.com/Replace-a-Washing-Machine-Water-Pump
    • 4 MIN
    • 76K VIEWS
    2016-01-08 · Video embedded · How to Replace a Washing Machine Water Pump. Washing machines are durable and expensive appliances. Repairing them is often less expensive than replacing ...
  • Washer Not Draining? Washer Drain Pump Replacement (Part ... www.youtube.com/watch?v=DwV71h86Gxw
    • BY REPAIRCLINIC.COM
    • 3 MIN
    • 381K VIEWS
    2010-05-14 · This video provides step-by-step instructions for replacing the drain pump on top loading direct drive Whirlpool washing machines. The most ...
  • Geeks On Home: How to Replace a Washing Machine Drain Pump www.geeksonhome.com/how_6509829_replace-washing-machine-drain-pump... How to Replace a Washing Machine Drain Pump. Washing machines take the drudgery out of laundry day, and they're a lot easier than using a washbasin or beating ...
  • Related searches for Washing Machines replace pump
  • How To Replace The Pump in a Washing Machine - YouTube www.youtube.com/watch?v=cvyCSQMPkCc
    • BY BUYSPARES
    • 5 MIN
    • 74K VIEWS
    2011-07-13 · For all your washing machine spare parts and accessories, visit: http://bit.ly/1VKQiNZ If the pump in your washing machine is faulty or broken, ...
  • How to Replace the Pump on a Washing Machine - Bosch ' ... www.espares.co.uk/.../how-to-replace-the-pump-on-a-washing-machine- View All Washing Machine Pumps Now » How to Replace the Pump on a Washing Machine - Bosch. Is your washing machine failing to drain following a wash cycle?
  • How to Replace the Pump on a Whirlpool Washing Machine www.geeksonhome.com/...replace-pump-whirlpool-washing-machine.html How to Replace the Pump on a Whirlpool Washing Machine. The pump in a washing machine helps remove the water from the washer's tub. Water comes in through the ...
  • How to replace a washing machine pump on Aeg, Electrolux ... www.youtube.com/watch?v=yrY9R_T8qrY
    • BY HOW-2-REPAIR.COM
    • 10 MIN
    • 17K VIEWS
    2014-03-26 · How to replace a washing machine pump on Aeg, Electrolux, John Lewis, Zanussi washer dryers Please remember to mark us to your ...
  • How to change and replace a washing machine pump on ... www.how-to-repair.com > Home > Washing machines > Pumps After checking that the pump is faulty in our previous tutorials you will need to replace the old washing machine pump with a new one. Disconnect the appliance from ...
  • Whirlpool Washing Machine Pump Parts from RepairClinic.com www.repairclinic.com/.../a11b5c36/Whirlpool-Washing-Machine-Pump-Parts Shop for your Whirlpool Washing Machine Pump from our huge inventory. Return any part for any reason.
  • How to Replace Beko Washing Machine Pump www.how-to-repair.com > Home > Washing machines > Pumps This video will show you how to replace Beko washing machine pump, If your Beko washing machine is not emptying or draining the water then it is a good chance
  • Mar 10, 2016 | Washing Machines
    Tip
    Clothes Washer Will Not Drain
    My front loading clothes washer wasn't draining properly, it wouldn't complete the cycle, and the clothes would come out still sopping wet.
    We found that the problem was the filter located next to the water pump. It prevents large items from entering the water pump and causing severe damage to the pump.
    To access the filter on my Whirlpool machine I had to remove the top panel, the front control panel, remove the door gasket from the front panel, and then remove the front panel. On some models all that is needed is to remove a panel on the bottom-front of the machine. (I wish mine was like that!)
    This video I did on it might help you understand what to look for.
    I imagine that a top loading clothes washer has a similar pre-filter.
    on Mar 18, 2015 | Washing Machines
    Sanyo washing machine AWD-703HCTP DISPLAYED EH1 ERROR CODE what is the problem
    Maybe you have solved your problem, but if not, I haven't much good news, just a website with more info about Sanyo washing machines. That division of the giant Sanyo was sold to Panasonic.
    The link for more about the washers is...
    http://ashachine.info/sanyo-washing-machine/
    Good luck.
    Nov 25, 2014 | Washing Machines
    My front load whirlpool washing machine got to spin cylce and stopped. The door wouldn't unlock and the light showed add garments but it hadn't finished spinning the others any suggestions?
    Your drain pump filter probably needs cleaned. YouTube has several videos you can watch on how to do it. It's an easy fix. Type " whirlpool duet drain pump " into the search bar. Let me know if you have trouble.
    Jan 12, 2013 | Whirlpool Duet GHW9150P Front Load Washer
    I have a Roper Washer Model # AL4132VW1 while doing a load of laundry yesterday my washer wouldn't remove the water. I tried all the cycles but it still wouldn't work. Do you have a idea what is...
    It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
    Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
    Replacing the pump on a Bosch machine, please check this link for tips:
    http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
    Jul 25, 2011 | Roper Washing Machines
    Hotpoint wd440 washer/dryer. 1st problem was it wouldn't drain so I cleared the pipe. Now the machine 'wash' light flashes during a wash. The washing machine doesn't seem to hold the water...
    Make sure that the outlet of the pipe is at least as high above the floor as the top of the machine. If it is lower than the level of the water, it will just drain - there is no shut-off valve to stop it from doing this. Please rate this answer.
    Jun 17, 2011 | Hotpoint Washing Machines
    I have a f&p smartdrive 608 which is shutting off water supply intermittently on both hot & cold supplies allowing virtually no water in to the machine. Manually filled then wouldn't wash tried...
    Hi
    I believe it is the water inlet valve that should be replaced however, please post back with its complete model no and also tell me if any of the lights are blinking on the control. Please post back for further assistance.
    Daniel
    Jun 03, 2011 | Washing Machines
    The cycle does not go
    The typical problem is a bad water pump. Your washing machine would still do the agitation part, though. It would just stop when it came time to drain the tub. Replacing the water pump every so often is almost routine maintenance on old machines. It's inexpensive and fairly easy.
    If it won't agitate, there's another possibility. You have a safety mechanism that keeps the washing machine from doing the spin cycle when the lid is open (you wouldn't want your kid reaching in there while the machine is spinning). I think most machines will agitate with the lid open, but some machines might not - while there is a slight safety risk, many people want to add bleach, laundry additives, etc, while the machine is agitating.
    There should be a pin on the lid that goes into a hole and pushes the safety latch when the lid is closed. If you're missing that pin, you need to replace it (that would be a good problem, since the replacement pins are very cheap).
    Once the machine fills up, push a screwdriver into the hole a little ways and see if the machine starts working.
    Apr 30, 2011 | Thomson Washing Machines
    Washing Machines Logo
    114 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
