Question about Rowenta Power Duo Iron
Rewenta power duo dx6250 - Rowenta Power Duo Iron
THERE IS A POWER SHORTAGE IN MY CORD
Don't keep using it unless you want to get electrocuted... It is cheaper now to buy a new iron than it is to have this one repaired.
Apr 08, 2011 | Rowenta Power Duo Iron
Model dx6250 just quit working while my wife was ironing. What Happened? No sparks or nothing going on cheked power cord and it gets juice to the control but nothing beyond that.
Hi rhmoreno,
The fuse in your iron might have sacrificed itself to save you and the iron. :)
Replacing the fuse with the exact same will solve your problem but for which you will have to open the iron and thoroughly scan it to find the fuse.
hope i solved your problem, if i did then please vote for me and rate for me too :)
Regards,
Salman
Feb 11, 2011 | Rowenta Irons
How do you remove Torq screws that have that annoying center pin?
You Have to buy a 'security' torque set. I bought a set of security bits with 50 different types that included the one needed for the Rowenta Power Duo. It was only $9.00 at my local Harbor Freight store.
Oct 24, 2010 | Rowenta Power Duo Iron
Removing deposits on iron plate
Try adding some CLR to the iron, fill it up with water, and run self clean. Then wipe bottom of iron with an old towel. Repeat with clean water in the iron, to rinse out the CLR and minerals.
Jun 21, 2009 | Rowenta Power Duo Iron
How do you reset the power off
How do you cook rice just for 2 people
Mar 03, 2009 | Rowenta Power Duo Iron
Iron leaks water from the back end of the base
This problem is the way that rowenta seals the water tank. If the iron is disassembled and the seal is properly put on it will not leak,, however this seal is a silicone based product and not just an off the shelf gasket. I have sealed and repaired some using a high temp silicone
Sep 26, 2008 | Rowenta Power Duo Iron
Residue on iron plate
They sell cleaner for this. Or just use very fine steel wool #000 or #0000. Only use on a stainless steel iron, not one that has non-stick coating.
Sep 15, 2008 | Rowenta Power Duo Iron
Repair of Steam Iron
Hi, honestly if there is a short circuit to ground and you are trying to troubleshoot this, I would not advise you doing this (I do electronic tech/engineering everyday) and am uncomfortable doing it, as it is a shock hazard to continue using the device, especially if significant others are using the appliance. Unless I am SURE I can fix the problem AND I know how to test for circuit isolation as recommended by UL, CE and other safety governing bodies...i.e. "Know about HI POT and Leakage Testing techniques."
That said, since you have already dismantled and accessed the "guts", there is probably a fastener or moulded retainer you missed. Probably a good idea to try and locate a schematic or reverse engineer it, making sure you draw lots of assembly and disassembly diagrams as you go if you are so inclined
Jul 12, 2008 | Rowenta Power Duo Iron
I have a Rowenta Power Duo iron that just quit heating. Is there a place in Memphis, TN that can repair it?
This is the main information about your iron.
You can call them and they will help you to find the right place
Rowenta Inc.
196 Boston Avenue
Medford, MA 02155
Tel: (781) 396-0600
Monday-Friday
from 8am to 5:30pm (EST
Good Luck
Jun 17, 2008 | Rowenta Power Duo Iron
Shot of Steam
take it down and clean, it is clogged up.good luck.
Nov 25, 2006 | Rowenta Power Duo Iron
Rowenta Power Duo Iron Logo
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
