Question about Maytag M7Y10F2A Air Conditioner
Heil unit nac036aka5 - Maytag M7Y10F2A Air Conditioner
Heil epm36f19a1 runs but no heat
Fan relay is stuck among other things. The thermostat turns on the combustion air fan and puts power to the spark unit. If the burner comes on after the temperature in the heat exchanger rises the indoor fan will then come on. After the thermostat comes to temperature the power to the gas valve which shuts off the burner. Then after the heat exchanger cools a bit the indoor fan will stop. That's the sequence of events. look at the switches that control the fans. There is a wiring diagram somewhere on one of the panels that access the unit for service.
Mar 06, 2013 | Electronics - Others
How long is the compressor in my heil max pro 10 waranty good for
Not sure which model number the Heil Max Pro 10 warranty uses. Heil will usally place the model number on the side of the outside unit or inside the cabinet for thee Inside unit. Click here for a direct link to=> Heil HVAC
Use care when reading any warranty because the wording is mostly written so you do not understand.
To help you decide which Heil product and warranty protection is best for you, select from the following at-a-glance comparisons.
Please let me know If I can help you with other question, Thank You, Sea Breeze
Aug 31, 2011 | Heating & Cooling
I HAVE A HEIL 5000 A/C CONDENSING UNIT.\r\nCAN YOU TELL ME WHAT SIZE IT IS (TON)? MODEL # CA5560 VKD2 STYLE # 60MCE-000095ZR SERIAL # L9811 50209MANF # NCA5560 VKD2 I APPRECIATE YOUR HELP. THANK YOU VERY...
It looks like you have a 60,000 BTU unit or a 5 ton unit...12,000 BTU/ton is how you figure that...
The 60 in the model number indicates the nominal btu's of the unit... the exact output could be a bit more or less depending on the air handler...
heatman101
Aug 04, 2010 | Honeywell International Heil Quaker...
Heil heater keeps turning on and then shutting right off. Reset interior and exterior breakers to no avail. When the unit will kick on heat does come from vents
How long do burners stay on? If they go out within a few seconds, the flame sensor may need to be cleaned. The control board you have shown is probably doing it's job by shutting down and something else is causing this. Always check your air filter first. More info needed.
Jan 11, 2010 | Honeywell International Heil Quaker...
Heil HC-10.Wide-range cartridge.This cartridge is now giving very much reduced output amplitude although audio quality appears to be the same. Other cartridge is perfectly OK . Is there any simple remedy...
This is about the only site I could find that might help short of emailing Heil Sound.http://www.eham.net/reviews/detail/2392 at http://www.dk3hv.de/SSB-Audio/Heil/body_heil.html
Oct 14, 2009 | Heil Sound Audio Players & Recorders
Can't find the filter to replace it in our Heil air conditioner
What is he model number of your Heil A/C. SOme are odd size filters. You can pick up washable filter at Walmart. The filter goes underneath the unit. Should be panel that slides off. I really need more info Thanks james
Jun 06, 2009 | Heating & Cooling
I Am looking for heil NPA HC36 AKOL air conditioner wire diagram
You will need to contact a Heil distributor to get a wiring diagram. Or you can try a dealer but they probably won't help you fix your own unit. That would be taking money out of their own pockets.
Mar 10, 2009 | Heating & Cooling
Maytag M7Y10F2A Air Conditioner Logo
167 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
