Question about Motorola Mobility RAZR V3c Cellular Phone
Motorla Razr V3x wont turn on, and now wont charge.
My Motorola Razr V3x wont turn on. Over the last few weeks it would cut out every now and then (especially after i sent a message) and the phone would turn off, and now it wont turn back on at all. It wont charge either. When i press the on button, the display lights for the keyboard come on for about 3 seconds then switch back off again. I got a new battery but it didnt help at all.
  • jilli Mar 01, 2008
    i just got the phone 2 days ago and i turned it off. When i tried to turn it back on it wouldnt turn on. It vibrated and the backlight for the keybord came on and the screen said hellomoto then 2 seconds later it turned off. When i plug it in it wont say it is charging either...
  • Anonymous Mar 05, 2008
    i was textin my friend and the text wouldnt go through so i had 2 cut it off and it would cut back on and i think its dead
I had this problem too. Unfortuneately it happens often with that phone as i have been told. Mine got fixed about 10 months ago because it was under warranty and now it has happened again out of warranty and i have to pay for it to get fixed. Why should i when its going to keep happening every few months? It has nothing to do with the battery or the charger. The only way that it can be fixed is to take it to the manufacturer.
Posted on Oct 09, 2007
SOURCE:
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
Hi my phone will not send my picture it keeps saying message unsent I have a motorla razr v3x
Please activate the MMS service with your service provider and it should do also disable screening of teh images before sending them.
Thank You
May 11, 2010 | Motorola Mobility RAZR V3x Cellular Phone
Motorola v3x needs unlocking code
http://www.cell-unlock.com/motorola-razr-v3x-unlock.htm
http://www.motounlocknow.com/unlock-motorola-v3x.htm
http://www.unlockitnow.com/Motorola/V3x.php
Aug 26, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My vodafone razr v3x turns on then turns straight off
battery not holding charge mine did same change battery I verified problem by borrowing battery from my other phone and turned on no problem
Apr 24, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My V3c motorola phone will not hold battery charge
A normal battery only last between 300- 400 charging cycles, If you have had the phone more than a year time to get a bew battery, if less than a year check with your cellular provider to see if you battery has a limited warranty
Dec 09, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola razr v3i
there is no problem with yours fone,it is with yours brain go and give yours fone to nearest mobile shop to repair
Aug 09, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola v3x
Motorola RAZR V3x Cellular Phone MP3 PLAYER IS NOT WORKING PLEASE REP ANE PLAYER
Aug 06, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola RAZR V3x Cellular Phone Won't turn on
i have the same phone. it is motorola faulty built of chipsets. just return the phone for a next one
Feb 12, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Mobility RAZR V3c Cellular Phone Logo
150 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
