Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I can't log-in in my account
What is the problem if i can't log-in in my account? If i click my account, the desktop will appear and then it will automatically log-off. What is the solution of this problem?
  • Anonymous Aug 10, 2007
    how can I run regedit when I can't log-in into my account?
When you log on you won't see start bar and desktop?
hold Ctrl+Alt and then press del. or delete
click file...new task (Run...)  Then type explorer
Posted on Aug 25, 2008
There is a certain type of spyware that can cause this symptom. Here is the solution: 1. boot using your XP CD (may need to change BIOS) 2. Enter recovery console 3. at the command prompt go to c:\windows\system32 4. type: copy userinit.exe wsaupdater.exe 5. exit and reboot. Login 6. DON"T STOP - run regedit 7. Find the Userinit key in: HKEY_LOCAL_MACHINE\SOFTWARE\Micros­ oft\Windows\Windows NT\Current Version\Winlogon 8. Modify the entry: C:\WINDOWS\System32\wsaupdater.exe­ so that it reads C:\Windows\System32\userinit.exe No reinstallling windows required.
Posted on Aug 09, 2007
  • 883 Answers
Start pc in safe mode (hit F8 key on boot). then create a new user account. now start pc with new account. now delete your old account. no personal files will be deleted, only the account.
SOURCE:
Shortcut needeed for hotmail address. It seems to take ages to sign in or even find the page. Thanks, Verna
Open a web page Right click in the top of screen select the menu tab.
This will add to your screen toolbar File Edit View Favorites Tools and Help
Open your hotmail right click select Add to Favorites.
Then you can access your Hotmail through Favorites drop down list.
Or
If you have multiple Hotmail accounts, you can create a shortcut icon for each of the accounts on the desktop.
This allows you to quickly launch the specific login page for each email account without having to reenter or remember each email address.
Log in to your Hotmail account. Place the cursor in the address bar and highlight the URL.
Right-click and select "Copy."
Right-click on an empty space of the desktop and select "New" and then "Shortcut."
The "Create Shortcut" wizard launches.
Right-click inside "Type the location of the item" field and select "Paste."
The URL of your Hotmail account is pasted as the location of the shortcut.
Click "Next."
Type a name for the icon in the "Type a name for this shortcut" field and click "Finish."
The Hotmail shortcut icon appears on the desktop.
Double-click the Hotmail icon to log in and access your Hotmail account.
Repeat Steps 1 through 4 for each Hotmail account you want to create an icon for on the desktop.
Oct 02, 2013 | hotmail.com
Administrator password to login not working
Microsoft's latest operating system, Windows 7, and its predecessor, Vista, offer a new layer of security that is different from previous releases, such as XP or 2000.
The earlier Windows versions treated all users as system administrators by default. With Windows Vista and 7, all accounts are treated as limited users.
The User Account Control utility provides elevated permissions when required and prompts users for those permissions.
You can control UAC behavior in Windows 7 so it does not prompt you for these permissions.
Start your computer with Windows 7 and log in as you normally would. Your desktop should appear, and any background applications should be closed.
Click the Windows "Start" orb at the lower left corner of your screen.
Click your account picture at the top right of the menu.
You will be presented with a window that allows you to make changes to your user account.
Click the link that says "Change User Account Control Settings."
Look for the User Account Control options slider.
The default option of User Account Control is to notify you only when programs try to make changes to your computer or you install new programs.
The option directly below that does the same thing but does not dim your desktop.
The "Never Notify" option at the bottom of the list eliminates the prompts for permissions.
Move the slider to the bottom of the options window.
Click "OK."
You may be prompted one last time from User Account Control to confirm your settings and reboot your computer.
or
Log in as an Administrator on Windows 7
If you've recently upgraded from Windows XP to Windows 7, you're probably wondering how to log in as an administrator. In Windows XP, the administrator account was clearly visible from the log-on page, but it's no longer there in Windows 7.
Although there is an administrator account, it must first be enabled with the Windows command prompt before you're able to use it. Enabling the administrator account lets you troubleshoot problems with programs on your computer.
Click on the "Start" button, and then type "command" into the search bar.
Right-click "Command Prompt" when the results appear.
Click "Run as Administrator."
The command prompt opens.
Type "net user administrator /active:yes," excluding the quotation marks.
Hit "Enter."
Click "Start," and then click "Switch User." Click the "Administrator" icon to log in.
Aug 04, 2013 | Computers & Internet
Retrieving administrator settings
Click start Control Panel.
Select "User Accounts and Family Safety," then "User Accounts."
Click "Turn User Account Control on or off."
Remove the check mark next to "Use User Account Control (UAC) to help protect your computer."
Click "OK."
Set All Accounts to Administrator
Still in the UAC section of Control Panel, select "Manage another account," and click on a user account.
Click on "Change the account type." When working with multiple accounts, some changes can only be made if you and the account holder are both logged in with "Administrator" accounts so you need to change all user accounts to "Administrator."
When you are done making changes, you can change them back to "Standard," but always leave at least one "Administrator" account.
Select the "Administrator" radio button.
Click "Change Account Type" at the bottom right.
Repeat this procedure to change each user account to "Administrator." When all user accounts have been changed, close the Control Panel.
Create a Full Administrator Account
Click "Start" (the Windows Vista icon in the lower left of your screen). In the Search box, type "cmd". Right-click on "cmd," and select "Run as Administrator." An elevated command prompt window will appear.
At the command prompt, type "net user administrator /active:yes", and press "Enter."
Choose a password and assign it to the "Administrator" account, by typing "net user administrator 'password'", where 'password' is your selected password. For instance, if your password is "abc," type "net user administrator abc". Press "Enter."
Type "exit" and press "Enter."
Log off. When you log back into your "Administrator" account, you will have full rights.
hope this helps
Sep 17, 2012 | Dell Inspiron 530s Desktop Computer...
What's your problem?(other) account appeared on log-in page?
I can't ex[plain how it got there but you had best remove it.Log in as yourselfr. You should be the administrator. Open System Preferences. Locate "Users". Your name should be highlighted. Ckick on the padlock to unlock the panel. Now click on the name ":Other" and just above the padlock click on the Minus sign. You will be asked what you want to do with the account details. Select remove immediately.
After that try another restart and see what happens.
Mar 10, 2012 | Apple eMac Desktop
How to make an hp laptop go to the log in screen
The login screen will not appear if you have Windows set to login automatically. You will have to log out first. Try this:
Save & close all programs you have open.
Click the START button
Click LOG OFF
When it asks if you want to log off, click LOG OFF
The login screen should now appear
If you want to change your password, picture, or add or delete accounts, you need to login again, then follow these steps:
Type in password and login
Click START button
Click CONTROL PANEL
Go to USER ACCOUNTS
From here you can make changes to login and user account information
Oct 24, 2010 | Computers & Internet
Cannot access my account
I assume you cannot log into your user account in Windows.
This is how to create a new user account to log in and to move your user files from the old account to the new one.
Start the computer and keep pressing F8 until startup menu appears. Use arrow keys to select "safe mode".
When windows appears, log on as Administrator.
Use Control Panel, Users and create a new user. Select Computer administrator type. Restart the computer and log on to the new user account. Then you will have to move all your data files:
Open Windows Explorer, navigate to C:\Documents and settings\[your old user account]
Select folders Desktop, Favorites and My Documents (this may appear as [User]'s documents) and copy or cut them. Go to c:\Documents and settings\[your new user account] and paste them here.
You will lose only the desktop picture and some windows settings.
After that you may delete the old user account from Control panel/Users
Aug 08, 2010 | Computers & Internet
Sage sbd platform installation update has stopped working
To download the Sage SBD Desktop Installer Utility (Build 111)
Access the Updates page on the Sage website: http://www.sage.co.uk/support > Downloads > Updates.
Note: You must log in to view this page. To do this, click Log in, enter your email address and password for the Sage website, then click Log in.
From the drop-down list, choose Line 50 & Sage 50 Accounts then click Go.
Locate the Sage SBD Desktop Installer Utility (Build 111) then click Download.
From the File Download window, make a note of the file name, for example, sbddesktopbuild111.exe, then click Save.
From the Save As window, browse to the required destination, for example, your Windows desktop, then click Save.
The Download window appears showing the progress of the download and the estimated time to complete.
Once the download is complete, if required, click Close.
You have now successfully downloaded the Sage SBD Desktop Installer Utility (Build 111). For instructions on how to install this, click the Install it tab.
Mar 23, 2010 | Computers & Internet
I bought a computer and I can't even get into it because it is password protected is there something I can do?
yes if the password is unde bois you can clear the cmos hardwar if it is under windows you can use hierin to remove the password it is easy contact me with details and i will tell you how to deal with the passswrod issue you have
Oct 26, 2009 | HP Computers & Internet
I need to change account in my name
Go to CONTROL PANEL then click USER ACCOUNT then in the user account windows look for the user account that you want to change as you name then click CHANGE AN ACCOUNT . After you change Log out the computer and login your new user name
Apr 25, 2008 | Sony VAIO Digital Studio PCV-RX540 PC...
Desktop icons
your problem is so simple just listen see below
1.go to desktop
2. right click there
3.open arrange icon by
4.then in second last their is lock desktop icon
5. click their your prob is solved
if go to desktop right click their and click properties
then click desktop
then click customise desktop in web their is lock desktop icon put tick out from their your prob is solved enjoy
Nov 15, 2007 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
124 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
