Question about Cycling
I am looking for a speedometer cable for a Huffy 24" stationary exercise bicycle. Will any speedometer cable the correct lenght work?
  • 31 Answers
SOURCE: ploblem with deraileur on 24'' huffy
take it down to your local bike shop and lets them see if it alright.
Posted on Jul 24, 2009
  • 21 Answers
SOURCE: remove the pedals from a boys huffy bike
Bike pedals can be a little tricky, but most likely for that bike you will need a 9/16's wrench. There should be some flat surfaces inboard of the pedals between the crank arm (the long arm that you screw the pedals into). Now, here's the hard part - the R pedal is normally threaded, but the L pedal is reversed. The easiest way to remember which way to turn the wrench is to stand behind the rear wheel and you will always pull the wrench towards you to loosen. Depending on how long the pedals have been on, they might be pretty tough to get off. You could use some penetrating spray (like Liquid Wrench) and let that sit for awhile. Also, once you get the pedals off, remember to put a little grease on the threads so that next time they won't be so tough!.
Posted on May 14, 2010
  • 21 Answers
SOURCE: Looking for a parts manual
Anytime I need some sort of odd ball item. I search eBay for it and I have had wonderful luck thus far. Hope this helps !
Posted on Mar 09, 2011
dunnbiker
  • 8546 Answers
SOURCE: looking for rear whell axel
You really should take the wheel to a bicycle shop for that kind of service. There are a lot of variables to be considered, special tools, the magic touch, etc.
http://www.parktool.com/blog/repair-help/categories/hub-service
Posted on Aug 19, 2011
dunnbiker
  • 8546 Answers
SOURCE: looking for manual for huffy
That would probably fall under "Multi-speed, Freewheel Bicycle Owner's Manual" at http://www.huffy.com/Support/OwnersManuals.aspx
http://www.huffy.com/ExternalLink.aspx?url=/pdf/ownersmanuals/b5cdef6e-94bb-4bfb-9996-832637c144b8.pdf
Posted on Aug 25, 2011
I have an old Airdyne, probably 20-25 years old. I don't have the owner's manual any longer. All I want to know is what the rate of energy (calorie) expenditure is at each level on the speedometer. I've...
Stationary bikes provide a no impact workout because your feet never leave the bike pedals. This is preferable if you have back or joint problems that cannot tolerate repeated jarring of high impact exercises.
Stationary biking can burn 315 to 466 calories when done vigorously. This is a great exercise especially if you are trying to lose weight. You'll burn more calories in less time compared to other cardio exercises like high impact aerobics. You'll never burn this amount of calories while playing.
Feb 12, 2011 | Schwinn Original Airdyne
Just inherited a very old tunturi family exercise bike, and it is VERY old but works a treat! Trouble is I have no idea what format the speedometer is in!! Anyone got any ideas? I was told it's miles but...
Generally the Speedometer is in miles per hour, that is the standard. If you, when looking at the dial gauge, see the numbers go above 50 then it's in kilometers.
Exercise bicycles will give you a pretty accurate account of Speed and this in turn gives you an accurate account of distance. But this is the distance that wheel traveled, not the equivelant that you would be able to do on the road on an actual bike. Yoiu do not have factors like wind resistance, rolling resistance, and terrain to deal with. You will go further on the stationary bike then on the road if you are judging by distance, as you will be pedaling at a higher speed.
congrats on the inheritance.
Dec 06, 2010 | Cycling
18 speed bike 6 gear shift works fine 3 gear
You have to look if when you act on the shifting level it get hard to move or it is free, if free, probably the cable is broken.
Also check if the cable is not too loose, try to follow the cable track and move the level and see if the cable move with that, in that way probably can find where the cable is stuck or broken/loose.
May 09, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
Bought a Huffy 26inch magellan 700c mens commuter Bike from Kmart there was no manual having trouble figuring out how to get it into various gears, is there a manual I can down load.
just move the gear levers, but keep pedalling forward while you do. you cannot change gears while the bike is stationary and do not pedal backwards while changing
Apr 06, 2010 | Huffy Newport 26 Men s Comfort Bicycle
If the cable is rusty or otherwise binding it won't let the derailleur fall toward the smaller sprockets when the control is moved. Likewise, it may not even let you move the control in the direction that pulls the cable (bigger rings).
If you don't know much about the process I suggest you read this:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
and take the bike to a Local Bike Shop for a look-see and maybe a tune-up.
Mar 16, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
We have 2 regular bicycles. We would like to put
Just about any decent bike shop should sell them. Just had a look on Google for "exercise bike stand" and got hundreds of hits..
Oct 06, 2009 | Huffy Womens Mountain Bike - Blue/Grey
Operator manual for huffy crosswind bike grip shift
Look for the manufacturers name and model number on the gripshift and check at www.parktool.com. Look under derailleurs for repair tips which will give you an idea how they work. A twelve speed has six gears on the rear sprocket and two on the crank giving you a combination of twelve speeds. sheldonbrown.com is another good site with good articles and pictures.
Jul 15, 2009 | Huffy Alpine 24 Youth All-Terrain Bicycle
Had to replace cable on grip shifters on a Huffy
if u buy a new grip shifter it comes with a diagram a bicycle shop might help
Jul 14, 2009 | Huffy Alpine 24 Youth All-Terrain Bicycle
Ploblem with deraileur on 24'' huffy
Mar 21, 2009 | Huffy Alpine 24 Youth All-Terrain Bicycle
Cycling Logo
89 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
