Question about Starrett D125 Digitape 1Inch x 25 Electronic Tape Measure
Manual for a Starrett d1 25 digitape - Starrett D125 Digitape 1Inch x 25 Electronic Tape Measure
Where do I get a battery for starrett digitape D3-16
send code of battry store they will reply soon
Oct 11, 2014 | Measuring Tools & Sensors
How to replace the battery
small door on back side (opposite meter), located at the rear of the tape - press down with thumbs (toward center of case) and back - door pops open - 9v battery underneath
Jul 10, 2014 | Starrett D125 Digitape 1Inch x 25...
Need new battery, of course I removed the battery some time ago to go and replace it. Yup its lost.
you lost your battery - bring a unit with you and ask for battery that fits in the store.
Dec 11, 2013 | Starrett D125 Digitape 1Inch x 25...
The display is always on when I insert the battery- How do mI turn it off?
I installed a larger 3 volt battery and put a micro switch on the positive side.
Nov 19, 2013 | Starrett D125 Digitape 1Inch x 25...
Need Starrett 682EMZ Saw Tension user guide
I can't find any available manual. I have an Starrett tension guide before but It was an old model and I don't even have manual for it. Did you try calling Starrett? They might can send you one.
Aug 13, 2013 | Starrett 682EMZ 60000psi or 4000kg per Sq....
Name those moving companies of London who modern technology during removals day.
There are many removal companies of London who use latest technology. I have mentioned a website below, in this removal directory there are almost 8 removal companies of London. These companies use latest equipments which are especially made for removals task. They use heavy-duty fixed bar panel cart, padded tubes, dolly risers, pallet jacks, foam, stretch film etc.
Removal Companies London
Jul 23, 2013 | Starrett D125 Digitape 1Inch x 25...
Need a replacement battery for Dl1/3N duracell 3v
Here is a list of equialent batteries that are calimed to be able to replace the one you specify.
Equivalent Batteries Cross Reference: Duracell DL-1/3N, 3N, Ray-O-Vac 867, 2L76, Energizer 2L76BP, 2L76-BP, CR1108, IEC CR11108, CR1-3N, DL1-3N, Dantona Comp 15, Duracell DL1/3N, NL1/3N, Energizer LR1/3N, Eveready 2L76, L76BP, I.E.C. 3V CR1/3N, CR1/3N, CR11108, Innotek M041101, Kodak K58L, National HM-N, NR-52, NEDA 5008L, 5008LC, Nikon F-1, Sony CR1/3N, Varta CR1/3N, LaserMax LMS-1/3N, LaserMax LMS-1/3N 5PK, LaserMax LMS-UNI-G
May 17, 2011 | Starrett D125 Digitape 1Inch x 25...
I can't get the darn thing apart to get at the dead battery. How does it open??
The screw on the side nearest the battery door needs to be removed so the door can slide out, then open to expose the batteries.
Nov 05, 2010 | Starrett D125 Digitape 1Inch x 25...
Need to purchase battery. Don't know the size for a digitape 125
you may obtain the stock replacement for the tool, designated as a Duracell DL1/3N or as I did, utilize two more commonly available 1.5 V cellls Ag 13/357A but you need to then bend the positive battery contact terminal (the one more inside than outside) so that its point of contact is lowered somewhat..use your leatherman no problem.
Jul 12, 2010 | Starrett D125 Digitape 1Inch x 25...
Is it possible to turn off the Starrett Digitape.
Mine stays on until the battery dies. Brand new still have not used it for the first time.
Nov 17, 2009 | Measuring Tools & Sensors
Starrett D125 Digitape 1Inch x 25 Electronic Tape Measure Logo
59 people viewed this question
Top Starrett Measuring Tools & Sensors Experts
ray gallant
Mark Schmit
Mark Schmit
Are you a Starrett Measuring Tool and Sensor Expert? Answer questions, earn points and help others
