Question about Toshiba CZ32T31 TV
Toshiba CZ32T31, Vertical Deflection?
My television has a single horizontal line whenever I turn it on. It is a 32 in. color TV (cz32t31). I have done some research and keep ending up with a vertical deflection problem as my answer. Some sites go on to try and tell me how to fix it by mentioning parts that I've never heard of. Does anyone know where I can find free schematics or diagrams that I can use as reference? If anyone has any tips, please let me know. Thanks!
  • Anonymous Nov 05, 2007
    My CZ32T31 also displays a single horizontal line, at times, but has other issues. The picture will appear after a while, followed by loud noises as the pictures suddenly comes and goes. Eventually, the picture appears and everything is back to normal, until the next time I turn the TV on.
  • 398 Answers
Usually the solder joints on the vertical output IC crack and the little pico-fuse opens. Resoldering the IC and replacing the pico fuse should bring the picture back. If you have never heard of these parts before and have no idea how to find them, then allow a qualified tech to handle it for you.
Posted on Aug 10, 2007
I too have the same T.V. and it recently began having the exact same symptoms of the previous two post, what is the estimated cost to have a qualified technician fix this issue?
Posted on Sep 29, 2008
SOURCE:
I have a thin line in my tv and i dont know what ic no.to replace?
The fault is a failure of the deflection circuit and since you have not specified whether it is a vertical or an horizontal line the section failed will be related to the position of the line.
If horzontal the vertical IC or the section related is faulty and if Vertical the horizontal section., Now this can be the deflection IC, teh deflection coils or even discrete components like capacitors or resisitors in this section which will require a signal trace with a voltage test before the absence of the sync pulses are confirmed and the section identified.
I request not to change the IC unless it is proved but you can solder the vertical IC or the section concerned -- if there is dry soldering.
Aug 25, 2011 | Toshiba 32A50 32" TV
When I turn on the TV with the remote or on the front, it comes on for a second and then shuts off. I was able to keep it on once, and all I got was a horizontal white and colored line across the TV, but...
horizontal lines indicates that the vertical section is most likely the defect..a defective deflection yoke could cause this and eventually damage the vertical output ic causing an overloading in the power supply then can caused to shut down
Jul 16, 2011 | Toshiba 27D46 27" TV
Want to connect computer to tv
Hello
You can't connect computer diretly to your Toshiba TV. You must have a VGA to AV converter in between TV and Computer. This device is available in most of the electronic spare part shops. OK.
May 27, 2011 | Toshiba CZ32T31 TV
I have a Tobisha TV CZ32T31, need a replacement remote for it.
http://remotes.com/ will replace almost any remote you need and for a pretty cheap price.
Jan 04, 2011 | Toshiba CZ32T31 TV
I have a Toshiba CF32H40 TV that is displaying a Single Horizontal Line. Any help would be great
you lost vertical deflection. this will require parts replacement, however it is possible it is only bad connections (cold solder joints)
Dec 28, 2009 | Toshiba CF32H40 32" TV
My CRT TV displays a single horizontal white line across the screen. It will flicker and try to display the picture. If you smack it you'll get a quick picture then back to a line. After about 10-15...
The single line means that the vertical deflection doesn't work. And since it is working when you kick the tv or has warmed it's clearly a bad connection - open the case and reseat the wires going to the tube coil.
Dec 21, 2009 | Toshiba 32A33 32" TV
H line problem
I think you are describing 'no vertical deflection.' If all you have on the screen is a single horizontal line, the vertical deflection circuit (or IC) has died. Unless you have service documentation on hand, I can't give a part number to replace but this is typically not an expensive failure and if the set was OK before, it is worth having repaired.
Jul 05, 2009 | Sansui 27" TV
I need some assistasnce
sounds like a bad capacitor in the deflection circuit or a leaky diode which is causing the problem. Adjusting wont help.
Dec 02, 2008 | Televison & Video
Toshiba 32A14 horizontal line
This symptom is characterized by a thin horizontal line in the middle of the screen. This symptom is caused by the absence of the deflection sawtooth current in the horizontal deflection coil.
The trouble is easily isolated by a continuity test and by checking the most likely defective components such as A)open vertical linearity compensation transformer, B) open capacitor and C) open horizontal deflection coil.
Be sure to decrease the brightness first before trouble-shooting if the line is very bright,as it burn the phosphor screen..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 19, 2008 | Toshiba 32A33 32" TV
Toshiba CZ32T31 TV Logo
469 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
