Question about Xantrex Technology DR3624 Inverter/Charger
What AGS is compatible with a Xantrex DR3624
I want a simple AGS for start/ stop. No A/C necessary
2 Suggested Answers
garymax2
SOURCE: Grundfos Pump On Xantrex Modified Sine Inverter?
SOME MOTORS HAVE TROUBLE, starting on Modified sine wave power. Grundfos is a high quality unit, you could try an other motor driven load to see how it is handled by your power supply.
Posted on Nov 18, 2012
How can I access battery equalizer on the Xantrac DR 3624 inverter when I lost the button on the panel?
Is the switch still there? If the switch is still there you might be able to activate it with a pencil eraser or something like that.. If you have lost the switch then you will not be able to equalizer your batteries
Jun 20, 2014 | Xantrex Technology DR3624 Inverter/Charger
I have a problem w the auto Gen. start turning the Gen OFF once it has started it. The lowest voltage setting to turn it off is 14.0vdc the problem w this is it will never reach that voltage. So I set the...
Your experience matches my own. I think the only solution is to use a DC monitor such as the Victron unit which has an external relay. Hook up the relay contacts to the Temp in on the AGS, then set the Victron to trip the relay when the batteries are charged to whatever percent you decide, such as 80%. Use the DC volts to start the gen and percentage of charge to turn it off......
Nov 17, 2010 | Xantrex Technology Xantrex RS2000 Sine...
Why does my dr3624 only put out 98 vac, its rated at 120 vac? i'm off grid and my batteries are new 24 volt
Are you using a true-RMS voltmeter to measure the DR's output? The DR's output is modified sine wave, and a cheap average reading AC voltmeter will give you a reading of 90 volts or so. Alternately, if you have an oscilloscope, you can verify that the modified sine wave is around 170V peak to peak. It should alternate in segments of -170, 0, +170, 0... The duty cycle and peak voltages will vary with the inverter load.
- Tom, Sun Electronics International, Miami, FL
Oct 03, 2010 | Xantrex Technology DR3624 Inverter/Charger
I need a control board.
You could buy the control board from :-
http://cgi.ebay.com/Xantrex-Inverter-Repair-Board-DR3624-Control-Board-/260652658387?pt=LH_DefaultDomain_0
I hope i have been helpful.
Thank you!!
Aug 21, 2010 | Xantrex Technology DR3624 Inverter/Charger
I have a Freedom invertor/charger 458 in my motorhome and i can't control the invertor with my remote board. I can push any button and nothing happens/no lights come on. it still charges and inverts. is...
Buy a long phone cord or however long youneed. Run it temporarily to the remote board and the invertor. Make sure powrr is off during this stage.If this doesn't work the solution is probaly going tobe much tougher. See manual.
Here is the owner's manual.http://www.donrowe.com/user_guides/xantrex/fdm_basic_remote.pdf
Feb 21, 2010 | Xantrex Technology DR3624 Inverter/Charger
Look I been using solar and wind power for the last 20 years and never used public utilitiy, run your inverter to a braker box and connect your pump to it donot forgfet to ground the box and the inverter. that is all what you need...remmber modified sine wave may effect the life of the pump if it is cheep it may be ok or you need to get true Sine wave.
Feb 09, 2009 | Xantrex Technology Xantrex Freedom Xmic...
Xantrex Technology DR3624 Inverter/Charger Logo
Top Xantrex Technology Electronics - Others Experts
Jimmer_9
Level 1 Expert
richie46
Jay Plesset
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
