Question about Dell Latitude E6400 Notebook
EPROM CHANGE BIOS PASSWORD
  • Dell Master
  • 32,281 Answers
PC BIOS toolkit is a password removal/decrypt and BIOS settings modification/backup/restore.
http://www.syschat.com/download120.html&act=down
CMOSPwd - CMOS password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
Using a computer with Internet access, download the files from these WEB sites and create a bootable CD disc to run them.
Posted on May 04, 2013
Unlock password for asus laptop
if its a bios password.you will need to send it in to acer as passwords are stored on a eprom chip.so removing bios battery wont work.
Dec 14, 2014 | Computers & Internet
D525 hdd password forgotten---frozen
The hdd password is stored in the firmware of the hdd, not in the bios. There is only two options available.
1/ type the password.
2/ purchase a new hdd as it is totally unformattable in that condition.
Jul 22, 2014 | Acer eMachines 520-2890 Notebook
How to remove write protect on hard drive with no os
first of all u need to find out if it is your hard disk password or your bios password, if its you hard disk passwords all you can do is to replace the hard disk, and if even after replacing your hard disk you are prompted for a password than its your bios password , in this case you need to replace your EPROM
Oct 08, 2012 | HP Pavilion s3000e (GC387AV) PC Desktop
The bios administration was cleared, but still it is asking for a password
Remove the battery,power cord and unplug the small internal battery on the motherboard. leave it unpowered for 30 minutes.reconnect all and your bios password will be cleared as long as your unit does not have an eprom chip that does not require power
Apr 28, 2011 | Computers & Internet
Which pins do you reset when flashing the bios to clear password from eprom on a Dell Inspirion 1525?
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have removed your password you will have change fist boot back to your hard drive)
Hope this helps
Mar 28, 2011 | Dell Computers & Internet
I'm having trouble removing a bios password from my latitude d631. I tried removing the battery for a few hours, and dozens of default master passwords. Nothing's worked and this is alot of trouble just to...
there are a few options, if there is no small battery on the motherboard you can either replace the eprom chip or do a paperclip trick. on ebay there are password removal sellers for around $20
sometimes they can help , but it sounds like its locked in you eprom the paperclip trick involves removing the motherboard and powering on the laptop while jumping the pins on the eprom chip with a paperclip.
Feb 07, 2011 | Dell Computers & Internet
I deleted my bios how do i install my bios
The software in the BIOS is stored on an EPROM (Eraseable Programmable Read Only Memory). So, buy some hardware, namely an EPROM writer, remove the EPROM chip from the motherboard, insert the EPROM chip into the EPROM writer, download the latest BIOS-software from IBM's web-site, and load the software onto the EPROM writer, and rewrite the software onto the chip. Remove the chip from the EPROM writer, and reinsert it into the IBM motherboard.
Jul 17, 2010 | IBM NetVista PC Desktop
Forget bios password
Try shorting out the cmos battery contacts, to drain any voltage that's holding the password in the eprom memory. Sometimes there are some metal test posts that can be shorted out to achieve the same thing, but you have to have a service manual to identify them. Only other things I can think of is to reflash the bios, or change out the eprom (they're usually soldered, however, and not a do-at-home job). See if shorting out the contacts for at least 24 hours works...hope it does.
Apr 12, 2010 | Dell Latitude D600 Notebook
My toshiba tecra8000 laptop displays toshiba logo for 1 second and then it displays password.Bios batteries have been removed.code no of flash eprom on mother board is unknown tome.If I get the code no of...
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Mar 09, 2010 | Toshiba Tecra 8000 Notebook
Power-On Password reset and SVP
The supervisor (SVP) password is stored in a chip called 24RF08.It can not be reset by disconnecting the BIOS battery or shorting any jumper.
Nov 24, 2009 | IBM ThinkPad T43 Notebook
Dell Latitude E6400 Notebook Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
