Question about Alert 3 Voice Alert System-6 Wireless Pir Motion Sensors!
PIR MP Alert instructions
Setup
I have an installed PIR exterior motion sensing light, but no instructions on how to set the controls. Now, if it senses motion, it will stay on for hours.
the sensor has at least 2 knobs maybe 3. one show hands of a clock one show sun. one may show sensitivity. the adjustment is low to hi the wider the adjustment the greater the setting check out this picture on ebay for the icon.
https://www.ebay.com/itm/Outdoor-12M-PIR12V-PIR85-265V-Security-PIR-Infrared-Motion-Sensor-Detector-GF-/292078238929?var=&hash=item4401383cd1:m:mRSg-Rlk4nJMZJH-BiKb2gQ
good luck
Oct 20, 2017 | The Home Security
Mp705-4g need a manual
Hi, Christine for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Coby MP 705 1G Instruction Manual
Coby MP 705 Quick Setup Manual
http://mp3-player.getusermanual.com/files/mp705-4g-2--user-s-manual
Jul 10, 2017 | Coby MP-705 Digital Media Player
Instructions for pro symmetric pir
If it has a sensor adjust the sensitivity down and it will help it if not fix it
Sep 06, 2014 | Electrical Supplies
How to wire slave pir to a master unit touch swtich on a stairwell with two-way switches
sounds like two way switching , 2 switches wired parrell 1 to 1 2to 2 3 to 3
power 2 and 3 , but seek professional advice if using mains
Jul 19, 2014 | Elkay Computers & Internet
Reset instructions for PIR floodlight
There should be a screw adjustment under the PIR unit. Clockwise direction increases the amount of time it stays on and anticlockwise decreases the amount of time it stays on. It's usually a small hole which you can see a slot in which you turn with a screwdriver.
Nov 24, 2013 | Televison & Video
Nighthawk pir security light is continuously on. How to swith it off?
This is not an automotive question, but here is something that may be helpful to you:
Some of these devices have a "setup" which (for example) works by switching the power on and off and on, quickly which changes the operation to normal or always on or always off etc...
You will need to find the instructions for your particular unit and look to see if this one has this function built in and what the sequences are. Hope this helps!!
Oct 19, 2013 | Vehicle Parts & Accessories
Pir connection
Can't see how that should be any problem. Use the switch from the PIR to turn on and off the power supply. Not after the 12v but before
May 28, 2013 | Computers & Internet
Downloaded drver for my printer. the add new printer wizard can't
Hi ...
If you have the driver CD that you recieved with your printer, follow the below steps to install the saftware:
  1. Turn on your computer.
  2. On your computer quit any open applications, including virus checkers.
  3. Insert the MultiPASS MP730/700 Setup CD-ROM into your CD drive. The [MP Setup] splash screen will appear automatically.
    1. If MP Setup does not start automatically, on the Windows desktop, double-click My Computer (on Windows XP, click Start then click My Computer).
    2. Double-click the CD-ROM icon. If MP Setup does not start, double-click 'Setup.exe' (on Windows XP, 'Setup').
  4. In the MP Setup splash screen, click 'Install MP Drivers'.
    Note: For Windows 2000 users, if Service Pack 1 or later is not installed, MP Setup will display a message and installation will be aborted.
  5. Follow the on-screen instructions, clicking the appropriate button to move from one screen to the next.
  6. MP Setup will install some system files and may prompt you to restart your computer. If you are not prompted to restart, click 'Finish' in the MP Drivers Setup window and then proceed to step 7.
    1. If you are prompted, make sure radio button 'Yes, I want to restart my computer now.' is selected in the MP Drivers Setup window and then click 'Finish'. DO NOT remove the CD-ROM at this stage. MP Setup splash screen will open after Windows has restarted.
    2. If you had to restart your computer and the MP Setup screen is not displayed or you closed it, on the Windows desktop, double-click My Computer (on Windows XP, click Start then click My Computer).
    3. Double-click the CD-ROM icon. If MP Setup does not start, double-click 'Setup.exe' (on Windows XP, 'Setup').
  7. In the MP Setup splash screen, click 'Install MP Toolbox.'
  8. Follow the on-screen instructions, clicking the appropriate button to move from one screen to the next.
  9. At the MP Toolbox Setup dialog box, click 'Finish'.
  10. Confirm the MultiPASS is turned on.
  11. Connect the USB cable to the MP730 and computer USB ports. Windows will detect the printer and proceed to install the driver files.
  12. Your MultiPASS includes additional software applications that you can install now or at a later date. To install the software, click 'Install Utility Software' and then proceed through each installation.
You can also download the drivers by visiting the below link and selecting your operating system.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=9035#DownloadDetailAct
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Help again please
Luckily there is a website where you can download the instruction.
Go to http://www.cobyusa.com/?p=doc and select 'Mp3 & Portable' in the first box, 'MP3 & MP4' in the second and 'MP-C7085' in the last. Then click submit.
Beneath the boxes you'll find links to the setup guide, manual and quick-start guide.
Hope this helps
If you need more help, just ask! :)
Mar 27, 2008 | Coby MP-C7085 MP3 Player
Alert 3 Voice Alert System-6 Wireless Pir Motion Sensors! Logo
290 people viewed this question
Top Alert Home Security Experts
Paul Bade
Charles Ma
Charles Ma
Five sok
Five sok
Level 1 Expert
Are you an Alert Home Security Expert? Answer questions, earn points and help others
