Question about Dewalt Dw920 72 Volt Cordless Screwdriver Drill
How do use drill bits on the dewalt dw920 is there an adaptor we need
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: dewalt xrp 18 volt hammerdrill. Need gear schematics.
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will take you to a page where the schematics are.
Posted on May 24, 2009
  • 382 Answers
SOURCE: Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Posted on Jan 06, 2010
Testimonial: "Thanks for your help! It looks like there is still some live left on the brushes...I guess I was just overly concerned! :)"
What is the best lubricant to use on my dewalt hammer drills please
It depends to where you want to apply your lubricant.
If you want to lubricate the chuck with the sds drill bit you simply add some cheap grease on the drill bit and the drill bit will slide easily on the chuck. On the other hand if you want to lubricate the sds drill machine then there is a special type super grease that you can buy from Dewalt in order to do so. Also since in order the super grease to be needed this means that you have used the drill a lot then also is needed to change o-rings, brushes and so on. So usually you have to ask for a service center to do it since they know how to do it properly and using the right kit.
Oct 18, 2014 | Dewalt Drills
Removing centre screw from chuck
Drill a hole in the top of the phillips head screw with a 3/16 th's bit. Don't drill the head of the screw off, just drill deep enough for a torx bit to hold. Take a T-30 torx bit and tap in into the hole you have drilled. Then turn the screw clockwise and it should come out fairly easily.
Mar 26, 2010 | Dewalt Drills
How to remove a chuck from a DeWalt hand drill
Open chuck all the way (like for a large drill bit). There should be a set screw at the bottom (where you would put a drill bit). Don't turn too hard - it may be a left handed screw (I don't remember if it is a lefty for sure but try gently each way then with a bit more force each way until it moves).
Good luck.
Mar 19, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Jan 04, 2010 | Dewalt DC925 Cordless Drill
How do you load screws in Dewalt DW272WT VSR
You definitely need a hex-bottomed screwdriver bit. Please rate me
Jun 09, 2009 | Dewalt Drills
I cannot get the drill bit's to stay in my dewalt D25003 drill, do I need special bits or an adapter?
Are you using a SDS bit in this tool? If so you might have a problem with the bit lock mechanism, if not you do need the special SDS bits that will lock into this tool. Let me know
Apr 12, 2009 | Dewalt Drills
Drill bit came out, won't go back in. Dewalt 12v XRP
grasp the chuck and put drill in reverse position and pull trigger gently this will open chuck and re-insert bit do same in forward to tighten bit into chuck
Jan 10, 2009 | Dewalt 18 Volt Compact Drill Kit
My dewalt drill won't drive
is your battery is fully charge or maybe your clutch setting are too low. set it drill mode if it is not working you need to replaced
trans/clutch assy
May 28, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt Dw920 72 Volt Cordless Screwdriver Drill Logo
227 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
