Question about Samsung RS2534 Side by Side Refrigerator
Power Cool button works on freezer , but not fridge
We have had no water for 36 hours, during which time the fridge temperature went up to 12 degrees. The water came back on , but doesn't come through the water dispenser anymore. Power cool button doesn't work on the fridge . Are these two things related? Any help would be appreciated. Thanks.Alisonkj
  • alisonkj Aug 14, 2007
    We had a repair man who came and advised us to shut the thing down . We did this , started all over again and so far so good. Apparently this is a well known fault on this model . I understand you can get a panel to fix on the back for around £100 ($200)
    I'd rather not go down this route if I can help it.
    Many thanks, Alison
He Alisonki! I was having the same problem. On mine the water coil inside the refrigerator keeps freezing which keeps the water from circulating and my refridge won't stay cold. I was told by one repairman that it was a computer problem and you have to order parts from the Samsung Manufactuer which takes about 2 - 3 weeks to get. I am tossing mine and buying a more reliable brand. One repairman came yesterday and left without fixing anything or charging me. Larry
Posted on Aug 14, 2007
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
I am having LG GR-B352 YC , what is the best temperature that i can keep initially and future??
Generic instructions to set temperatures in fridges:
Many manufacturers design these appliances to operate at 0 degrees F in the freezer and 34 to 36 degrees F in the fresh food compartment.
To set the temperature correctly, fill a glass with water (8 to 12 ounces) and place a thermometer capable of indicating 32 degrees and up into the glass with water (if the temperature goes below 32 degrees, the water will freeze - so no need to find a thermometer that indicates any lower). Place the glass with the thermometer in it on a shelf and wait. Putting the thermometer in a glass of water helps preserve the temperature reading while the door is open. You can skip the water and glass if you want - but you'll need to read the temperature as soon as you open the door.
The freezer will require a thermometer capable of displaying 0 degrees F. Place it on a shelf where it can be seen readily - but preferably in the rear - between items (to prevent the warm air from driving the indicator up when opening the door to read it).
It will probably be easier to set the freezer temperature first. Adjust both the freezer and fresh food thermostats to mid-points (if the fridge is empty - otherwise skip this step). Adjust the freezer thermostat up or down as needed to reach the desired 0 degree F temperature.
Once the freezer adjustments are complete, adjust the fresh food compartment thermostat as needed up or down to reach the desired temperature for it.
If you fridge is fully stocked, it may take some time for the temperature to stabilize and warm / cool the fridge's contents completely. This is further affected by how often the door(s) are opened and for how long. 24 hours is often claimed - but you might be able to sneak an 8 - 12 hour soak before reading the thermometers.
After the temperatures are set, you may find that the lower part of the fresh food area is partially freezing - simply adjust the thermometer up *slightly* as needed.
Please rate this reply if it was helpful - good luck!
Aug 11, 2010 | Refrigerators
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
Does not hold temperature, warms up.
if you hauled on its side then it is very possible you have oil in evaporator. replace all sealed system parts. compressor, drier and evaporator.
Jun 21, 2009 | Roper Refrigerators
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
Water dispenser not working
I am currently experiencing the same problem. It happen when I pressed the rapid cool button on the inside of the fridge and the temperature went down to 36 degree F. I assume that my water line is frozen. As soon as we use up some of the food in the fridge, I'm going to clean out the fridge and let the temperature rise, hopefully thawing the blockage. This is the only thing that I can think of.
Mar 25, 2008 | Refrigerators
Samsung french door fridge not working?
I had the same problem ("OF" on display and not working) and just found a fix and it worked (on SAMSUNG site).It was correctly stated that fridge is in "demo" mode. You need to push and hold POWER FREEZE and ENERGY SAVER buttons (not "Fridge button and the Power Cool buttons" as it was suggested above).
Oct 14, 2007 | Samsung RM255LASH Side by Side...
Not cooling
Listen for a clicking noise from the compressor. Could be a bad relay on the compressor, sealed system problem, or faulty board.
Oct 01, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Frigidaire 7.5 cu.ft. Top Freezer the fridge part doesn't cool; freezer is fine.
It should be under warranty, retry he is probably right, run for 24hrs and it should work ok, if you ever defrost you should turn off for 24hrs and leave the door open. Regards Advisor
Aug 08, 2007 | Frigidaire GLRT83TES Top Freezer...
Samsung RS2534 Side by Side Refrigerator Logo
209 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
