Opscan 4u user guide
Sheet too thin error message
  • 5161 Answers
SOURCE: Priner error occurred.Please see users guide?
Try turning off the printer and turning it back on. If the error persists, it's time to call Epson and have them service the unit.
Posted on Jun 20, 2008
efs_perpends
  • 1996 Answers
SOURCE: unable to open user's guide
The easiest fix might be to uninstall and reinstall it, if you have the cd....
Otherwise, you can download one from Dell online by clicking here
Posted on Apr 10, 2009
SOURCE: error message
unable to print see troubleshootingand routine maintainencechapter in User's Guide....I misplaced the User's Guide can you solve my problem?
Posted on Jun 09, 2009
komguy
  • 2306 Answers
SOURCE: drum error
With that error you need to remove the drum, run the little blue tab on top back and forth about 20 times, blow out the area below the blue tab, and re install and try printing again. If the error is drum life end you need to open the front door and press either menu or options, sometimes the clear/back button and tell it it's a new drum.
Posted on Dec 30, 2009
  • 166 Answers
SOURCE: 6170 I HAVE A ERROR MESSAGE STATEING 50C
Here's the link to Lexmark's site, and the user guide for your X6170... here's what they provide:
http://www.lexmark.com/publications/pdfs/x6100/eng/ug.pdf
Here's the Summary of 50C - found on PDF page 108, document page 102....
Cartridge Error: 50C
Your print cartridge has a short.
1 Press Power to turn your All-In-One off.
2 Unplug your All-In-One.
3 Plug in your All-In-One.
4 Turn your All-In-One on.
5 Remove and reinstall the cartridges.
Note: If this does not resolve the problem, see “More
troubleshooting options” on page 103 or replace your
cartridges
Posted on Mar 23, 2010
I have a thomson twg850 router but it won't accept my password, what do i do
Hello you might have to reset it and set it up again.
TWG850-4U Default IP: 192.168.0.1
TWG850-4U Default Password: admin
TWG850-4U Default Username:blank
Here is a guide:
http://compnetworking.about.com/od/homenetworking/ht/routerconfigure.htm
Good luck
Nov 19, 2012 | Computers & Internet
Paper doesnt feed
please try to clean rubber rollers that pickup the paper but didn't...
Mar 31, 2009 | HP PSC 2350 All-In-One InkJet Printer
OpScan Insight 4 scanner error message
i have a problem in opscan4 insight
Problem;
top/bottom image quality
Mar 20, 2009 | Office Equipment & Supplies
ROS Trouble with Xerox DouPrint N17
The ROS is the laser. Believe me you can replace the machine for less than the cost of a laser. The Polygon motor is most likely bad in the laser. I would guess in the $500 range for the laser
Dec 09, 2008 | Xerox DocuPrint N17 Laser Printer
Cartridge error
i have a lexmark p4350 and just recently got a eror message 1102, says consult user guide, cannot find that error message in the guide, what is it, thanks
Sep 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Pictures
K...Trust the solution. Try these steps. Open the printer, remove the ink and remove the printhead (See User's guide). Reseat the printhead and the ink cartridges. The printer will come up with an error message that requires calibration. Do the calibration and scan the sheet that prints right after by pushing the start button. In the menu options, clean the printhead. Do one basic and one deep. Print a demo sheet (another menu option) to see if the quality has gotten better. If it has not call Kodak AiO Tech support. You will need a replacement printhead.
Apr 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer
My camerais say error #e45
if you get this error message and it's telling you to see the user's guide - the user's guide will actually just tell you to do powercycle
with several powercycle (removing batt> putting it back in after 10 seconds> turn cam to auto) it may work again
if not, it needs repair
the user's guide doesn't have this defintion as it's an engineer code, only the repair center can determine or resolve
Feb 08, 2008 | Kodak EasyShare LS743 Digital Camera
34 incorrect media
34 Incorrect Media message appears if the printer has detected a mismatch between the type of media requested by the user and the type of media actually loaded in the paper tray.
To attempt a resolution for this issue, please do the following:
  1. Press the green GO button on the printer operator panel. Printing will resume, but the printer must go through a POR (Power On Reset) in order to clear the message.
    NOTE: The printer does not automatically reprint the page that generated the error message.
  2. Verify that the media you are using is supported by your printer in terms of size, weight, and input source.
  3. Using the printer operator panel, verify that the type of media loaded in the paper tray matches the Paper Type setting in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the media type setting are provided in the C510 User's Guide.
    • If the media type setting is incorrect and cannot be changed, there may be an issue with the media type sensor. Proceed to step 5.
  4. Using the printer's operator panel, verify that the paper loaded in the paper tray is the size listed under Paper Size in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the paper size setting are provided in the C510 User's Guide.
    • If the paper size changes to an incorrect setting or cannot be changed, it is likely that the paper size guides in either the 250-sheet or the 530-sheet paper tray are not set correctly. Remove the media from the tray and verify the location of the media guides.
  5. Power the printer off and then back on again.
  6. Resend the print job to the printer.
  7. If the error persists, you will need to contact Lexmark Technical Support for assistance. Please obtain the printer serial number before contacting Lexmark. If possible, call from near the printer as this will allow for the most accurate possible diagnosis.
Hope this will help you please let me know if it worked and don't forget to vote..
Cheers
Dec 18, 2007 | Lexmark C510 Laser Printer
63 people viewed this question
jasbo
jasbo
