Question about Onkyo Audio Players & Recorders
Remote control codes bell fibe
TX-SR607
  • 3 Answers
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
Posted on Aug 21, 2008
  • 4 Answers
SOURCE: connecting a wii to an Onkyo TX-SR607 7.2
I am experiencing issues like this although with a VCR connected with analog video. I added a BluRay DVD player and all of a sudden I lost my video upconversion from my VCR. I am going to try to reset the receiver to see if this fixes the problem. If not, I don't think it is the receiver issue, I think it may be the fact that enorder for video to pass through HDMI, allot of criteria needs to be met. Certain Handshakes need to happen, especially with the HDCP issues. Most likely I will connect a separate video cable to my Plasma and use a secondary input on the Plasma for the VCR signal. You may want to purchase the Component Video adapter for the wii system as this will provide you with at least 480p and your receiver should not have an issue passing the signal over the HDMI output. Good luck and give me an update.
Posted on Jun 17, 2009
  • 1126 Answers
SOURCE: Is there any way to program my Star Choice URC550
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=starchoice
This is the only model that I could find. Codes are in the back of user guide. Hope this helps.
Posted on Aug 23, 2009
smarthome2
  • 1114 Answers
SOURCE: Onkyo TX-SR607 keeps turning off
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 03, 2010
caroldon
  • 17130 Answers
SOURCE: My TX-SR607 Display is Lost
This can be due to failure of the display section power supply, the display processor or the display subsection circuit. So since the amp is working well otherwise then it is possible that voltage to the display is checked , the processor section is checked for correct clocking and the linking cords are checked. Sometimes it can be poor soldering joints and a good touch up of solder will solve.
Posted on Jul 16, 2011
Need code for my new rca scenium tv for my bell expressvu remote I do not have fibe tv
RCA 503 505 548 630 633 634 636
641 645 646 648 650 651 652
653 654 656 661 663 665 667
668 670 691 698 701 708 715
716 725 742 763
Apr 21, 2017 | RCA Televison & Video
Tv codes
I am assuming you are using the bell Fibe TV system. The best option to program the TV code onto the remote control is to go to this site and select the remove control you have.
http://support.bell.ca/Fibe_TV/Receivers/How_to_program_my_Bell_Fibe_TV_remote_control
You will then need to find out what code applies to your TV as you have not provided the make and model for it.
Aug 29, 2014 | Televison & Video
How i can i find remote control code for bell tv fibe
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 17, 2014 | Haier 32-Inch 720P Led-Backlit Lcd Tv
Want to know how to set up my bell expressvu remote to control my onkyo tx-sr605 receiver?
If you are trying to use another manufactures remote to control your Onkyo receiver they are the ones who are responsible for programming the Hexadecimal codes into their remotes. We do not have codes for any other manufactures remotes. You may want to try the following website for codes www.remotes.com or http://www.remotecodelist.com for any codes to program your remote. As we do not have the remote controller codes for non-Onkyo controllers- you can try the generic remote controller code: 62503 or 52503.
May 04, 2014 | Onkyo TX-SR605 Receiver
Connect my TV with Bose Solo TV Sound System
see the diagrams22a4db52-8fe5-48e4-bdff-25e1eb3394e8.jpg1429d3ae-7ae9-4ebe-b479-00257395645c.jpgb4618280-d089-4e7e-a37a-b2614cd61071.jpeg attached. God bless you
Jul 26, 2013 | RCA Universal Remote Control
Remotes
093,097,091,097 are the codes to check. If you wish to get more details, check the site linked below. Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Two digit, three digit, four digit and five digit setup code list to different models remote controls are given. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window.
Apr 23, 2013 | Jensen JER-422 Universal Remote Control
Comment je peux fair pour pogrammer mon dvd sur ma tele commande universselle du cabloe bell fibe
google translated
how can I pogrammer fair for my dvd on my tv control of universselle cabloe bell fibe (What is cabloe bell fibe ?)
i have no idea maybe some one else can provide a solution now its translated
Mar 01, 2013 | Computers & Internet
Remote code for the Samsung SH-897M
for codes go to remotecentral.com if its a universal type remote
Apr 25, 2010 | Audio Players & Recorders
67 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
