Maxtor 160GB sata hdd showing 0GB - Computers & Internet
2 Suggested Answers
Geekinator
  • 183 Answers
SOURCE: maxtor 3200 160gb usb hard drive not in my computer
Hello kc9iid.
"Any suggestions?" ... Yes. Here's a quick few:
If it's showing in your WinXP's "Device Manager", try reinitializing it.
1. Select the device (maxtor 3200 160gb), then right-click > "Uninstall" it.
2. Reboot (instead of rebooting, you may also simply do a menubar > "Actions" > "Scan for hardware changes". However, if you haven't already rebooted since problem was recognized, this is a good time to do it now. If left un-done, you'd be amazed how often that one action alone will work wonders).
If that brings no joy, see if the drive is reflected in your "Disk Management" console [Start > Run... > type "diskmgmt.msc" (without quotes), then "OK"].
If it's not there, your registry is probably configured to "hide" (not display) the specific drive letter assigned to this drive. You can both check and correct this by getting "TweakUI". Download it here http://www.softpedia.com/get/Tweak/System-Tweak/TweakUI.shtml. After it downloads, launch it, then ensure the subject drive letter is checked ON [TweakUI > left colunm "My Computers" > "Drives"].
Good luck, and post back with a status report and/or any further questions.
"Today's the best day of my life...and NOW you're part of it!"
Posted on Dec 24, 2008
PROBLEM 0GB MAXTOR DIAMOND22 STM3160813AS
Your drive can be showing 0GB for a few reasons, if it is showing 0GB in BIOS, in Device manager or in any hard drive utility chances are the PCB is shot or one of the heads has stopped reading. In either case you will need the help of a data recovery expert if you wish to retrieve your data. If it's showing 0GB in My Computer but shows as 160GB(~155) in a harddrive utility or under device manager you simply require a software solution. If you require a recommendation for the professional recovery route simply reply back letting me know and telling me what country and state/province you live in, I can get you in touch with an appropriate service. If you simply need a software solution reply back with the drives original OS, your current computers OS and I can recommend a software package that will allow you to recover your own data.
Sep 30, 2014 | Computers & Internet
Dear i am using ms-7142 v-1 motherboard. now i,m using ide 80 gb hdd.now i want to connect 160 gb sata hdd.its not showing bios also.hdd is working fine.i reinstalled os.and installed sata raid driver
first thing I would try is seeing if the sata drive is recognised on another motherboard if at all possible ,in order to eliminate the motherboard as the issue.If it is recognised on a different motherboard it is more than likeley a bad cable or a bad board .
Sep 23, 2014 | Computers & Internet
When I plug my maxtor in, I can hear it "thinking"
use an external usb ide( or if your hdd is sata,then use a sata cable)then insert to a working computer then you can copy your files
Feb 19, 2011 | Maxtor OneTouch 4 Mini 160GB External USB...
How do i reformat (NTFS) my maxtor Basics 160gb external drive to get it back to 160 - it only shows 149gb
it is usual, that you wont be able to access entire 160gb...certain amount of disk space will be reserved in the HDD for boot sector...
Sep 29, 2010 | Maxtor BASICS Personal Storage 3200...
Install driver of maxtor 160gb onetouch 4 mini
Hmmm What software do you need?
You should not need software to run the HDD. Just plug it in.
You can get the One Touch software from Seagate (who no own Maxtor) See
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot4-downloads&vgnextoid=0ed72c9e46914110VgnVCM100000f5ee0a0aRCRD
HTH
Dec 08, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Only detact my sata rom when canect my sata hard disk dasant detact both I just bought a 160GB Maxtor SATA Harddisk (STM3160813AS). When I tried to installed it to the motherboard, it didn't detect the...
I the HDD is still brand new, then it has to be formatted by the PC, install the HDD do the following...
1. Right Click My Computer, click on Manage
2. Go to Disk Manager on the left
3. Your disk should be listed there, right click on it on the right hand side of the screen, create partition, then you need to format the hdd, then you can use the disk, If it doesn't detect the HDD when you want to install windows, then you must, change your SATA setting in the Bios to IDE mode, Try it out and let me know, got some more solutions that you can try if that doesn't work
Cheers
Techmor
May 28, 2009 | Asrock P4VM8 Motherboard
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
MAXTOR 160GB HDD PN:9NX2A4-500 WILL NOT WORK ON MY PS3
the ps3 does not support many external hard drives.
But they do accept USB Flash drives/thumb drives.
Aug 07, 2008 | Computers & Internet
EMACHINE T1840 160GB HDD UPGRADE
The Safest thing to do is to actually create a 2nd partition
which will give you the full use of the 160gb
remember thou that windows sees a K as 1024
not the 1000 measurement you would expect
On older pcs there is a limitaion 137 then when formated bringing it down to 127gb
If me I would run the Maxtor setup and choose custom ,delete the partition already made, then create 2 partitions ,then tell it to copy from your old c:\ to the first partition,making new hdd the new boot drive
another option is go buy a ATA133 PCI card with 48 bit addressing
Nov 14, 2007 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
