Question about Microwave Ovens
Sharp Microwave oven Model R84 STM need to eplce Digital ck and control Panl
Replacement Clock and Control panel required
SOURCE: Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Posted on Sep 24, 2007
SOURCE: Control panel on a whirlpool microwave
SOME ELECTRONIC CONTROLS HAVE A LOCKOUT FEATURE THAT IS ENGAGED AND DISENGEGED BY HOLDING A CERTAIN BUTTON FOR 5 SECONDS. LOOK FOR A LOCK PAD AND HOLD IT FOR 5 SECONDS TILL IT BEEPS.
IF NOT AVAILABLE, THE TOUCH PAD MAY BE UNPLUGGED FROM THE MAIN P.C. BOARD OR MAY BE DEFECTIVE.
ALSO, TRY UNPLUGGING THE MICROWAVE FOR 5 MINUTES
TO RESET THE MICROCOMPUTER, THEN PLUG IT BACK IN AND SEE IF IT WORKS.
AN ELECTRICAL OUTLET NOT WIRED WITH PROPER POLARITY OR NOT GROUNDED CAN AFFECT ELECTRONIC APPLIANCES ALSO.
Posted on Mar 28, 2008
SOURCE: Panasonic Microwave inverter oven model,
10 Amp fuse blown inside oven.
Posted on Apr 19, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Whirlpool microwave/oven combo- model #RM288PXS
That would be a problem with your control board. It probably needs a few capacitors and a relay replaced and minor circuit board repair.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
P.S. (to Guest: Please make a new post with your model number. I think your problem is different.)
Posted on Nov 08, 2008
  • 4 Answers
SOURCE: Sharp microwave oven LCD display malfunctions
Might or might not work. IT worked for me.
This is a common problem. i havent completly solved it yet but this helps.
Be very careful doing this, There is Voltages with AMPERAGES high enough to boil your blood inside a microwave.
I had mine apart cleaning it. Only one number worked on my display. I wiggled and messed around with the wires in the back of the display. And almost every number in the display works again. Hope this helps.
Posted on Mar 07, 2009
Model R1800 Sharp Microwave Looking for Sharp Carousel Convection Oven Control Panel Model R-1800
What are your sympotms? I repair those boards.
Feel free to contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 22, 2016 | Sharp Microwave Ovens
The control panel of my sharp grill 2 convection microwave oven is very dim
Dimmed light might be caused by a slight contact between the panel's connector and the mainboard. Or, there is a dimmer option (feature) in the menu. Depends on model. Some of Panasonic microwave ovens are equipped with such a feature.
Regards,
Dan
Oct 12, 2016 | Sharp R-820JS 900 W 0.9 cu ft Countertop...
How to fix Sharp Carousel Microwave Oven R-303CW clock not working?
The clock is part of the control board and cannot be repaired as a separate item. Most replacement control boards costs as much as
a new microwave.
Jul 15, 2014 | Sharp R-303CW Convection / Microwave Oven
I also have a Sharp Carousel Microwave oven model # R-409AK in which the clock/ timer digital display has become faint and can not read the time. The microwave part works fine otherwise. What part do I...
It is a display panel you require and you should be able to get a manual at the same time.
Try http://www.sharpdirect.co.uk/support/spares-and-accessories/page/spares/
Hope it is helpfull
Feb 27, 2011 | Sharp R-319FW Microwave Oven
Display clock doesn't light
We regularly repair such control units for customers nationwide for $39.95 with a one-year guarantee.
mini_manual_behind_grille_small.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Apr 26, 2010 | Sharp R-254 Microwave Oven
Sharp Carousel 2 Microwave start switch broken
Hi George,
I ahve the same issue. Did you manage to repair it or did you need replacement?
If repaired then how?
if replaced then where did you manage to get the part from?
Regards
Vipin
Jun 04, 2009 | Sharp R-1870 Convection/Microwave Oven
The time display on my sharp r-425ew microwave went out.
in the particular sharp model u have ,u can replace the display clock.
Dec 29, 2008 | Microwave Ovens
Sharp 1100 w Microwave Model R-420BK - Clock display not working correctly
This is a problem with the control panel assembly, and we repair these for customers nationwide with our guaranteed $39.95 service.
William E. Miller
prototech@usa.net
Aug 13, 2008 | Sharp R-420DK Microwave Oven
R-1460
Check fuse. Remove 3 screws from the plastic grill located at along the top front of the unit. Remove the phillips head screw above the control panel. Slide up and pull out to partially remove control panel. You will see a white fuse. Replacement is CD3G 125v 20amp or BUSS ABC 20 or Little Fuse 314020 at 250v 20a. Radio shack caries the ABC.
May 12, 2008 | Sharp R-1460 Microwave Oven
Sharp model number: R-320HQ (1200 watts)
the electronic circuit are corroded timer does not function / the IC program was lost of memory such as function / if you have some old look a like Sharp Model you may transfer control panel.
Jan 05, 2008 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
