Question about Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx motor not running - Bosch Classixx WFL 2066 Front Load Washer
4 Suggested Answers
  • 1294 Answers
SOURCE: Bosch Classixx WVF2402GB motor will not run
Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Posted on Apr 10, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch Classixx WAE24162GB/03 motor not working, have cxd brushes
There is a thermal cutout in the motor, but unfortunately it is not resettable.
The only way to be sure if it is faulty, is to check it for continuity with a meter, if it is open circuit, it can be bypassed, but this then leaves the motor unprotected, but it will prove if the fault is in the motor, or elsewhere.
It could be a blown track on the control board caused by the brushes shorting, in addition, to an open circuit thermal cut-out.
Posted on Apr 14, 2010
Testimonial: "I had already decided to split the motor and check it out thoroughly and yes it was the thermal cut out open circuit. Fixed and all working again. Ta."
  • 50 Answers
SOURCE: bosch classixx 1000 express wont spin
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been a bit stressed out and popped it.
Next two things are more serious unfortunately. The relay on the circuit board might have burnt contacts from switching the motor over the machines life, or, one of the motors windings has developed a fault. (these are both pretty rare though).
Posted on Jul 29, 2010
F21 flashing on my bosch classixx 6 1200 express
F21 is a motor fault and in some cases can also involve a module fault. It could be as simple as the brushes need replacing or the drum has been severely out of balance.
Mar 21, 2013 | Bosch Washing Machines
Bosch classixx 1000 express wont spin
Jul 29, 2010 | Bosch Washing Machines
Apr 14, 2010 | Bosch Classixx WFC 2465 Front Load Washer
My bosch classixx 1000 washing machine is not spinning at the end of the wash cycle, and when set to spin it does not spin, what can i do?
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl vote me 'very helpful' for the free help, thnks!
Apr 03, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Clicking noises
IF APPLIANCE IS RUNNING OK I WOULDNT WORRY TOO MUCH THE CLICKING YOURE HEARING IS PROBABLY THE HEATER RELAYS SWITCHING ON AND OFF AND THE MOTOR REVERSING RELAY ALSO NORMALLY THEY WOULD NOT BE HEARD OVER NORMAL RUNNING NOISES OF MACHINE.
Sep 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 fills, drains, but won't wash ?
This a classic example of worn brushes in the motor.
To check , remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws that secure motor, and lever motor back with a screwdriver or similar.
Keep hold of the motor as you lever it back.
You will find the brushes at the terminal end of the motor, replace if less than 4=5 mm in length.
Refit motor belt and motor plug.Test. before you refit panel
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch Washing Machines
Dec 09, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Changing the brushes when the motor is off
Nov 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch classixx 1200 express
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
16 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
