Question about Behringer PMP4000/B212XL Mains & Monitors PA Package
Behringer pmp 4000 monitor promlems
I have used this system for 6 months and at the last show I lost the low end on the monitors.I use an old peavey monitor 300 head to drive the stage monitors and this has always worked fine. About 3 hours into my last show I lost the low end on my monitors. The peavey head seems to be working fine. And also the behringer seems ok.Of course I haven`t pushed them for hours like at a show.Any idea what would cause this.The signal to the mains was fine just the monitors.
  • 5603 Answers
SOURCE: pmp 4000 setup for active mains and monitors
If you only have powered speakers for both mains and monitors, you will NOT use the Speakon outputs on the back.
You will connect USING BALANCED TRS audio cables from the MAIN L and R jacks on the top of the unit to your powered main speakers and also connect the monitor speakers by TRS balanced connections to the MON1 and MON2 1/4 inch jacks on the top deck of the unit.
POWER ALL the speakers AND the mixer from the same receptacle or power source/conditioner.
This may mean running an extension cord alongside your audio snake from the stage. Failure to do do this can cause damage due to exceeding the common mode noise (ground bounce) of different power sources.
Leave the speaker slide switch in the Main L/R.
Adjust the rotary knobs for Mon1 and MON2 for each channel to proportion each to the monitor "mixes" which you will control overall with the MON1 and MON2 sliders.
You will use the MAIN slider to control the mains level.
To set the trims for each channel, push the PFL so only that LED illuminate red... then at max inout level for the channel, use the LED bar graph on the right side so it is just a little below the clip level where the top LED's of the bar graph do not illuminate.
Posted on Dec 10, 2010
  • 5603 Answers
SOURCE: When I hook up my
Please read my tip on fixya regarding a HAZARD of PMP mixers when using Speakon to 1/4 inch speaker cables. Essentially, the barrel of the 1/4 inch on A channel is the "hot" and one had better never let it touch a grounded point.
Now to your problem...You may have to run the MAIN sliders near the unity setting (zero Db).
It is important to set the trims correctely. For each of the inout channels, push the PFL button for the channel down and set the trim control so LED display is just below the clipping point at maximum input for the channel.
Ideally you would like the channel sliders to be in the vicinity of unity gain when system is balanced. Running the sliders way down results in a poor signal to noise ratio. Next you adjust the channel monitor knobs to set the monitor mix. These should be about 12 o'clock if possible to get decent signal to noise ratio.
For the MON/Mon1 mode, do NOT use the "Surround" simulator OR the "Speaker processor" ... make sure those swithces are off. You will probably want to PAN the channels fully to the MAIN side "B" which MAY be the reason your level seems low.
Remember the individual channels are about 400 Watts and 600 peak. Frankly myself I prefer to use both MAIN channels to the main speakers and use an external amp for the monitors OR use powered monitors for monitor use.
Posted on Jan 03, 2011
Testimonial: "Thanks for the helpful info on the Behringer 5000 amp I have....Your explanations were very helpful and easy to understand for this newbie.Thanks"
  • 5603 Answers
SOURCE: I have a Behringer PMP
Bridge mode you use chan B (left connector on the back) using a SPECIALLY wired Speakon. The impedance of a speaker connected as such CANNOT be LESS than 8 ohms.
In the Main/Mon mode, the two amplifiers are separated in function. The monitor knobs for EACH channel input control the mix sent to Channel A which is for the monitor speakers. The Mon1 controls the level sent to Output A for the monitor speakers. Mon2 fader is NOT used.
The individual channel faders control the main mix and the Main fader controls the level sent to Output B which goes to the main speakers.
Posted on Apr 02, 2011
  • 5603 Answers
SOURCE: Using Behringer PMP3000 to power monitors??
The power amp INSERT's are NOT intended to be used as inputs for the power amp but are for external effects units. The TIP of the jack plugged in here receives the signal from the preamp section and the inout of the power amp is taken from the RING of this threee conductor jack. If you want to use one of the power amps to run monitor speakers with no less than 4 ohms combine, you can use the built in Mon mode without any additional cables. You will set the mono/mon positon (center) and use the mo1 slider to control the output from the amp side for the mon speakers. The other amp then is used for the main speakers.
Posted on Nov 06, 2011
  • 5603 Answers
SOURCE: Our Behringer pmp 6000 just recently mysteriously
Try plugging in a set of headphones into each of the mon left and right. If the monitor sliders are up AND the channel monitor knobs are up you should be able to hear in ONE SIDE only of the headphones. If not, then you may have failed to power your monitor amp or speakers from the SAME receptacle as the mixer and this can result in ground bouncein building wiring that will blow out the driver chips for the mon signals.
How to set up a behringer pmp 2000
http://www.behringer.com/EN/Products/PMP2000.aspx
You will find the manuals on this web page under "Documentation"
May 09, 2014 | Music
Behringer ms 40
I'm not sure what kind of problem you are having on this but I have been trying fix a Eurolive B215D powered monitor for a friend for over 6 months. I have found that I could fix it in a few hours but, can't find any record of the components used. Standard resistors, caps, and others but certain things like output transistors and more specialized spec components can't crossover to generics for repairs. The only way to get them is through Behringer manufacturer AND they want to sell you a new on instead of fixing the old one. Can't seem to get parts for Behringer equipment. I have talked to other techs that say the same.
Mar 12, 2013 | Behringer Ms40 40w Active Powered Studio...
I have a behringer pmp 1280s. I was running two speaker and two monitors through it. One of the monitors was kicked and the patch cable to it was bent. I smelled smoke and the sound coming through turned...
That's a bad sign. A dead short in the output results in a short of the audio output transistors. I believe that to be the problem and a fairly simple fix to someone good at soldering BUT, you can't get parts for behringer equipment. Most components are specially made for behringer. I've been working on an amp for 6 months and I can fix it BUT, I can't find the parts anywhere, or can even find any reference to them online. Without a reference to the specs, I can't even get a generic replacement. Check your music stores in you area, a behringer dealer may can help you.
Mar 03, 2013 | Music
Our Behringer pmp 6000 just recently mysteriously lost both monitor 1 & 2 signals. Please provide some suggested resolutions? Is there anything other then the channel monitor level knobs and the main...
Nov 01, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Where (on-line) can we find download for advanced manual for Behringer PMP 4000 16 channel powered mixer? What we found on-line was the exact manual that came with the mixer.
There really ISN'T and "advanced" manual... Everything you need to know is in the user manual that comes with it... Service manual with schematics will not give you much you can use unless you are into electronics detail.
PLEASE read my tip about Behringer PMP mixers on here regarding a hazard if you use Speakon to 1/4 inch cables or adapters. Essentially, the sleeve, NOT the tip is the HOT lead for a speaker on channel A. Ground it inadvertently and goodbye channel A amp.
Be VERY careful of speaker leads with this amp as it is easy to pop a channel IF a speaker comes loose or shorts. Loop cables through the handlesto avoid cables being yanked out or breaking plugs.
Feb 09, 2011 | Behringer PMP4000/B212XL Mains & Monitors...
When I hook up my passive mains and monitors in the mono1/mono mode....mains on B and Monitors on A outputs I don't seem to have much output volume on the mains.....my monitors are okay but main sliders...
Jan 03, 2011 | Behringer Europower Pmp5000 Powered Mixer...
You seem to be the expert - i just got my pmp 4000,,,,i'm a little confused,,i understand the concept of side A for mains,,(mono) and plugged monitors into side B -got sound out of both mains and...
The MON faders ONLY control the output to the MON L and MON R jacks, NOT the split use of MAIN/MON outputs. You MIGHT try varying the MONO fader and see if it varies the MON part of the split output.
Best to use the unit as MAIN L and R to main speakers and use a stereo amp or POWERED monitors driven from the MON L and R jacks. With this, the MON faders will control your monitors as you would like them to.
ALSO make sure ALL equipment connected together is powered from teh same recepacle power system. Powering interconnected equipment from receptacles at opposite ends of the room is asking for damage due to ground bounce and faults.
PLEASE read my tip on here about a HAZARD of speaker polarity if you use Speakon to 1/4 inch cables.
Oct 29, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Can I hook up 2 separate power amps to PMP3000? I
Better way... Connect the main speakers via the Speakons and then put a Power Subwoofer to one of the Monitor connections IF you are not using both stage monitors. If you need to kill the lows to the mains, use the EQ in the PMP-3000.
Use the EQ that is USUALLY on the subwoofer to kill the highs to the sub.
Lot less cables and hardware.
REMEMBER for equipment safety, power ALL interconnected equipment from the same source be it a receptacle or power distribution system.
Powering parts of a system from receptacles strewn around a room is asking for trouble of ground loops and ground faults.
Apr 24, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer PMP4000/B212XL Mains & Monitors PA Package Logo
27 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
