Gas ducted heater brivis 20 plastic burning smell when turned on
SOURCE: rinnai convector 516TR
Hi This is happening to us and I called Rinnai... they suggested that if anyone either in our apartment or an ajoining one has painted walls or varnished a floor that the convection heater picks up the smell and the only way to get rid of it is to burn it off by running the heater for several hours in a well ventalated room...
I am going to try it tomorrow.
will let you know
Posted on Aug 19, 2008
SOURCE: brivis ducted heater making a banging noise every
The heating system has a number of burners which must ignite as soon as the heater starts. When one or more burners does not fully or partially start properly, unburnt gas fed to that burner accumulates in a small pocket until is is eventually ignited causing a small explosion. This condition is caused by restricted/blocked burner jets. The gas jets are small and easily fouled by spider nests or other items sucked into the system. You will need to have the heater serviced by a qualified gas plumber.
Posted on Jun 20, 2009
  • 55 Answers
SOURCE: Strong ''burning plastic'' type smell coming through heating ducts.
it sounds like you have a main air movement system motor that is burning out. it will probably quit on you in the next few days. likely cost to repair from company 375-700 somtimes more if you have a variable speed furnace, in which case you should consider replacing the whole furnace for what it would cost for the motor on one of those.
Posted on Sep 13, 2009
Testimonial: "Spot on. "
SOURCE: Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Posted on Nov 08, 2009
  • 3 Answers
SOURCE: Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Posted on May 05, 2010
Brivis ducted Heater won't get above 19 degrees ,
could be broken ducting letting hot air escape or on the intake side drawing too much outside air in. could be the fan unit not pushing enough air
Jul 26, 2013 | Cars & Trucks
Brivis heating
sounds like an over heat safety sensor is faulty,or blocked ducts to have to much heat buildup in furnace, best advise have a techie look atbit
May 05, 2013 | Heating & Cooling
Brivis ducted heater He20 (LPG fuel ) sooty flue & smells of gas
Inproper air/fuel mix, not enough air getting into burner. This is a dangerous situation, Possable causes inclide blockage in air intake and wrong gas supply. get an expert to look at it.
May 13, 2012 | Heating & Cooling
Burners on our Brivis Buffalo 52 Ducted heater aren't getting gas
test thermosat for proper operation ie-broken wire-power if good jump stat and check if unit goes on if it does than stat internal problem or wiring problem and needs replacement or repair --if stat good check fan safety/high limit sensor if good would need to check and test thermocouple thats the tube that the pilot flame burns on may be enough to keep pilot burning but not enough to open valve for heat demand
May 31, 2010 | Heating & Cooling
Brivas ducted heating not firing up. Gas supply ok electic supply ok. Spanner symbol on screen and Error 62 Model ME 20 E
Hello, We have Brivis Me20 gas ducted heating. It suddenly stopped working and gives error #60. Sometimes after pressing reset several times it fires up for a short period then fails again. Any ideas what might be wrong?
Thanks,
J
Apr 30, 2010 | Heating & Cooling
Apr 12, 2010 | Heating & Cooling
Sep 22, 2009 | Heating & Cooling
Sep 08, 2009 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
