Question about Dishwashers
I have a whirlpool dishwasher type 280-2 and the detergent door will not open automatically anymore. The compartment is thoroughly cleaned and wont even open if its empty so gook or over filling is not the problem. I believe I probably knocked off some part that makes it open at the proper time. If someone could explain how the process works and/or submits a picture of the parts, I could perhaps deduce what is missing. Thank you in advance as this is driving me nuts!
Why would a whirlpool adp6000ix detergent door not open
The dishes/pans you stacked to be washed may have moved and a handle is hugging the bottom drain preventing opening the door. The real main reason is like a car door breaks and it will not open on the outside well the door on dishwasher can break too. When its old then it telling you to update.
Apr 29, 2014 | Dishwashers
ADP 4730
The problem is with either the spring or the solenoid that operates the detergent compartment door. It should be released at the right time by the controller during wash cycle. You have to check the spring and see if it stuck. But if solenoid is faulty then whole detergent dispenser has to be replaced. You could switch to detergent tablet which you drop in the cutlery basket and it works fine. A brand like Finish works well and keeps dishwasher clean.
Alternatively you can purchase a replace detergent dispenser from
http://www.buyspares.co.uk/whirlpool/adp4730-851150429849/dispenser/product.pl?pid=18330&path=463858:496324,47872:463870&refine=dispenser&model_ref=641830
Also watch the video on how to replace.
Apr 23, 2014 | Whirlpool Dishwashers
The second "wash" detergent compartment
Clean around the latch that holds the door. I have a whirlpool that does the same thing and I clean mine every once in a while that works.
May 14, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Detergent remains in covered section of dispenser
This is usually caused by the soap creating a bond to the door and not allowing it to open when it should. You can resolve this by thoroughly cleaning the soap dispenser and not overfilling it. If this does not work, then you may want to see if the switch timer is faulty that tells the door when to open.
Mar 27, 2011 | Whirlpool Dishwashers
It began with the dishes on the upper rack not being cleaned. Not the bottom rack is getting less cleaning done and some of the liquid detergent is left in the detergent compartment. I tried doing a...
Check your spray arms for pluggage at the slots and the nozzles. If you can remove them, do so and backwash them over the sink. Unplug the slots and nozzles with a toothpick or fine wire.
This should also help with dispensing the detergent, but reduce the amount to the least that you can use while still getting the dishes clean. We have cut our detergent usage to about 25%. Also, try to not place tall items where they can block the water spray to the dispensing compartment.
Use a good drying agent, and crack the door open when the washer reaches the end of the cycle, as this will help the dishes to continue to dry, and further release the steam, resulting in cleaner dishes.
The reduction of the detergent, along with the cleaning of the spray arms will help a lot. I should note here though that I've had to re-clean the arms after what I thought was a most thorough cleaning. Once they are really clean, they'll work better for a long time (usually).
Best regards, --W/D--
Feb 04, 2011 | Whirlpool Dishwashers
The washer fills and runs through the cycle but leaves a grit on the dishes
If detergent is left in the compartment:
? Be careful not to load items so close to the dispenser
that the cover will not open to release the detergent.
? The dispenser is not supposed to open when you
use the Rinse program.
? Your dishwasher detergent should be fresh and
stored tightly closed in a cool, dry place. Old or caked
detergent should be thrown away because it will not
dissolve properly and will leave a gritty residue on
the dishware.
? Wait until you are ready to start the dishwasher to
add the detergent.
? If you are using the Delay program, make sure the
dispenser is dry before adding the detergent.
? The detergent compartment only opens in the main
wash programs, not the Rinse program.
YOU MAY NEED TO CLEAN THE FILTERS MORE OFTEN
IF YOUR AREA HAS HARD WATER
This can cause low water pressure.
In hard water areas, it may be necessary to clean chemical buildup from the filters every 12 to 18 months. To do this, remove the coarse filter by squeezing the
tabs and lifting it out. Next, unscrew the fine filter and lift it and the main filter out. Wash all three filters gently in hot, soapy water and rinse them thoroughly.
Your spray arms may be clogging causing low pressure too.
Spray-arm jets and bearings may sometimes become clogged with hard water chemicals. To remove the spray arms, screw off the nut and take off the washer on top of the spray arm and lift off the arm. Wash the spray arms in warm, soapy water. Use a soft brush to clean the jets. Rinse thoroughly and replace.
Try cleaning the drain pump so it gives you more water pressure.On occasion something may get through the filters and into the drain pump. The drain pumps on ASKO dishwashers are designed to automatically reverse if anything should get caught in the propellers, thus ejecting the item back into the sump area or down the
drain. Should you need to remove an obstacle from the drain, first turn the power off then remove the filters . Next, lift out the small black insert
from the sump area. (You might want to remove any standing water first.) You can then look into the sump area for the item causing the obstruction. Should you
find something, simply scoop it out. Be sure to replace the black insert before you put the filters back in.
You could also try to clean the dishwasher with ' Dishwasher Magic '. This would work like charm :-
http://www.dishwashermagic.com/
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 26, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool quietpartner I Dishwasher wont clean anymore.
you need to take the blades that spin out and clean them off they have grime on them, is there water still in the bottom of the dishwasher when done> if so there is a plastic grate in the bottom rear of the dishwasher you need a 1/4 inch nut driver take the cover off and clean the debris out, there is a small stainless steele cutting blade in there be careful, it is to cut up foods that might not be washed off before putting dishes in the washer, also it is pressure that makes the detergent door open make sure you are getting full pressure comming into the waher, if non of this works the pump should be replace or it;s new dishwasher time
May 30, 2009 | Dishwashers
Inside detergent compartment door will not open during cycle
to much detergent clean it out and start over
Jan 31, 2009 | Dishwashers
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
