Question about Dishwashers
My whirlpool dishwasher type 280-2 detergent door will not open during wash cycle. Yes the compartment, springs and door are thoroughly clean. Will not open if I just close the door and remains empty. I'm wondering if perhaps I knocked off some random part that makes it open. So please tell me how darn thing opens and perhaps a pic of the parts so I could see if ones missing. Thank you for any help offered for this, its driving me nuts.
    Top Expert:
  • Dishwashers Master
  • 78,010 Answers
These are opened by heat, no other means.
Posted on Jun 30, 2017
2 Suggested Answers
SOURCE: Whirlpool Model #DU890SWKQ0, Type 280-0,
I have a whirlpool dishwasher 280-0 that will not drain. What can I do?
Posted on Oct 24, 2010
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
ADP 4730
The problem is with either the spring or the solenoid that operates the detergent compartment door. It should be released at the right time by the controller during wash cycle. You have to check the spring and see if it stuck. But if solenoid is faulty then whole detergent dispenser has to be replaced. You could switch to detergent tablet which you drop in the cutlery basket and it works fine. A brand like Finish works well and keeps dishwasher clean.
Alternatively you can purchase a replace detergent dispenser from,47872:463870&refine=dispenser&model_ref=641830
Also watch the video on how to replace.
Apr 23, 2014 | Whirlpool Dishwashers
Detergent door does not open during session
Sounds like a bad dispenser solenoid, or it is not getting the prompt to open from the controller or timer and it also sounds like it is still under warranty, get them out to look at it while you can.
Jul 21, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
The detergent door doesn't pop open.
If you push the door closed not far enough to latch and let go of it does it spring back open if not the spring on the dispencer door is broken or has fell off
Mar 31, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Inside detergent compartment door will not open during cycle
to much detergent clean it out and start over
Jan 31, 2009 | Dishwashers
LG Dishwasher model LD-1415M. Detergent compartment not opening during washing cycle. Any ideas? Cheers. Joe
First off, clean the detergent dispenser as best you can using white vinegar.. make sure you get any and all left over soap deposits off the cup and edges of it then,... try cycling the dishwasher without any dishes on the hottest setting and after it is about ten minutes into the cycle.. pause it and add two cups of white vinegar inside the dishwasher.. That should remove most , if not all left over deposits from the system. See if that frees up the dispenser .. Make sure the drain filter is has been cleaned thoroughly prior to running this process.. Hope this helps...
Sep 14, 2008 | LG Dishwashers
Dishwasher not cleaning well
clean the dispensor assy around the spring door hinge witha vinegar water solution . liquid detergent has a tendency to not fully break if your water is not hot enough, causes doors to stick, reccomend running hot water before starting d/w, and using a quailty powder( not tabs) detergent
Feb 20, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Main Detergent Dispenser does not open during cycle
check to see if anything like dried up soap in there if so wash out with warm water or try a liquid
Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
