Question about Sharp AR-5316 Advanced Digital Imager Copier
F2 when i turn on my copier the copier lights are on and the letter apear (F) AND THE NUMBER IS (2) and when i press the start puttom the number apear is (4). please solv this problem for me > with tahnks
Hi i think the problem code for f2 problem is to enter this code pressing * interrupt CA interrupt then the light will go of then you enter 80 then press copy and 1 copy.
Posted on Jan 15, 2013
I have changed the chip wt 4 different ones but still showing F2 please help.
Posted on Jan 18, 2012
  • 328 Answers
Please verify the error code. I can not find your code
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 12, 2007
Replace toner cartridge or replace CRUM chips in the rear of the cartridge .
Posted on Nov 17, 2007
You need to chang the toner cartridge because you toner crum chip is broken.i means f2-04
Posted on Aug 13, 2007
SOURCE:
Where can I find the imei/cereal number for the Panasonic toughbook cf-y5?
The Serial Number for ALL Panasonic Toughbooks
is located in two (2) places:
1) On the white sticker or label located on
the underside of the Toughbook.
It starts with a number then a letter.
2) When you press the F2 Function key
as you start the Toughbook and then
enter the BIOS, the Serial Number is listed
on the first page.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Nov 12, 2015 | Panasonic Computers & Internet
Were theserial number on a cf-52
ALL Panasonic Toughbooks have the serial number
listed in two (2) places:
1) On a white sticker on the UNDERSIDE of the TB
(Usually beginning with a Number then a Letter).
2) If you press F2 when starting the unit, then the
serial number is listed on the first screen in the BIOS.
Good Luck!
Regards,
Jun 18, 2014 | Panasonic Toughbook 28 Notebook
Where is the serial number on a cf19
The serial number on ALL Panasonic Toughbooks
built since 2004 are located in one of two spots:
1) On a small white sticker or label on the underside
of the Toughbook. The serial number starts with a
number followed by a letter.
2) When you press the "F2" Function key immediately
upon startup you will enter the BIOS. On the first page
of the BIOS you will find the Serial Number. Again it
That's It!
Good Luck!
Regards,
Sep 19, 2013 | Panasonic Toughbook CF-29 Notebook
When i press other key its not working
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
Nov 04, 2012 | Samsung N150 (36725723009) Netbook
Need to know what the steal key is used for on the electronic game a to z
  • The purpose of the steal key
  • Turn's on your opponents lights.
  • You get to look at the progress of your opponents, and take away from one of them.
  • Press each of the other player's blinking numbers and look at their letter lights, comparing who has the most turned off.
  • Steal from the player of your choice.
  • To confirm which player you want to steal from, hold their number button down for several seconds.
  • This allows you to use your turn to turn back on as many of your opponent's letter lights as you can. Just play the same way as before, but instead press the letter lights that are not lit, turning them on as you go.
  • Play the same as before: the Game Unit will select a category number, an opponent should read it aloud and start the timer.
  • You will have 15 seconds to turn on as many letter lights as you can.
  • Then your turn ends. Press your own number button to confirm the end of your turn, and pass the Game Unit to the next player.
  • Hope this helps.
  • Regards,
  • Tony
Jun 10, 2011 | Milton Bradley Toys
When you type the letter u i o p j k l m number will apear instead of letter why?
Usually it's because the number lock is locked on.
Check your keyboard carefully for a key that reads "num lock" press it once and you should be good to go :)
p.s. If it's in blue sometimes you need to press FN + 'num lock"
Hope this helps!
Oct 14, 2010 | Dell Inspiron 4000 Notebook
My copier sharp AR-5320E is showing number 2 and letter H on the"
press #
press *
press clear
press *
enter 14
press the start key
Apr 23, 2009 | Sharp AR-5320 Black and White Copier
I dont know how to program frequiences on the scanner
1. Press Menu (Bottom left hand side of the scanner) You should see "Program System"
Press E You should see "Select System"
2. Turn VFO knob (Top outside right knob on the scanner as it faces you.) until "New System is displayed.
3. Press E
4. Using the VFO knob, select "Conventional then press E three times
5. Press the decimal key until all the letters under "Edit Name’ disappears
6. Now you’re ready to name your system. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
7. Turn VFO to Edit Group then press E
8. Use VFO to select New Group then press E twice
9. Press the decimal key until all the letters under "Edit Name’ disappears
10. Now you’re ready to name your group. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
11. Turn the VFO to Edit Channel then press E. (You should now see "New Channel")
12. Press E then enter a frequency
13. Press E twice
14. Press the decimal key until all the letters under "Edit Name’ disappears
15. Now you’re ready to name your "Subgroup" i.e. " Dispatch" Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E then menu
16. Use VFO to select New Channel
17. Repeat steps 12 through 16
Mar 27, 2009 | Uniden BC246T Handheld Scanner
I press a letter a number comes up as the letter
You have your number lock on. Turn it off and you should be fine.
Jan 28, 2009 | IBM 08K4800 Keyboard for Thinkpad 560Z,...
When I press print the letters AP apears and
what is the Brand/make and model number of your copier?
Feb 14, 2008 | Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
313 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
