LG DVD display LDR OK - Audio Players & Recorders
Freeview + dvd recorder RHT498H. A code has appeared. Why can't I get a picture and can't reset without a password?
From the manual (http://www.lg.com/uk/support-product/lg-RHT498H#manuals_panel):
To reset forgotten password:
a) Display set up menu (see Displaying Set Up Menu)
b) Select lock system icon in left panel
c) Select Lock System from middle panel
d) Enter [210499]
e) Select displayed YES option
f) Press OK [ ]. Password has now been cleared.
I hope that helps.
Aug 02, 2015 | LG Televison & Video
Flashing a dead nokia n97
Hi according to my experience your problem seems to the wrong selection of flash file.So, try to download it from here n97 or if this link doesn't works please use what you have download previously .There are many flash files with a higher version.Make sure that you should select the file of your correct phone type (RM-505 or 507).....Download the flash file what it is written on your phone.After you have done this please repeat the steps.Good luck
Jun 20, 2012 | Nokia Cell Phones
LG DVD player LH-D6230 - displays "dvd error" soon
Eprom corruption. Replace eprom, and edit in mode service.
Jan 07, 2011 | LG Audio Players & Recorders
Display show NO LDR (no loader) and no eject tray.
Most likely it is the BL/DVD Deck Assembly. It's very easy to replace.
Search eBay for one of the following part numbers:
EAZ54850412 EAZ54850411
Feb 01, 2010 | LG BD390 Blu-Ray Player
How do i fix my expression pedal on my digitech rp80?does it need a spring underneath it??? or is it read by sensor????
I think it is controlled via a LDR instead of a pot. If you see a pot under the pedal then it may need a new pot but I believe they have a LDR, which is an LED/light controlled resistor system. Either of these can be fixed by an experience repairman.
LDR parts are available at SmallBearElec.com. It will require some soldering experience. Be sure to test the pedal's control circuity with a digital multimeter to be sure the problem lies within this area and not somewhere else.
Oct 07, 2009 | Music
Lg not turning on
Please call the service centre person for the the repairing/ replacing of the faulty component LDR or SMPS section.
Jan 23, 2008 | LG 52SX4D 52" HDTV
LG DK 8621P DVD Player only play the audio (no video out)
how can off the progressive scan in my LG DVD player model 8680?
Nov 22, 2007 | LG DK 9411P DVD Player
149 people viewed this question
 Grubhead
Grubhead
