Question about Cub Cadet Garden
Lt 1024 how do you replace the alternator on a cub cadet lt 1024
  • 109 Answers
SOURCE: I have a Cub Cadet
Try lifting the hood on the mower and turning the flywheel, back & forth by hand, this will release the starter gear from the flywheel.
It could be the starter, but I would load test the battery first.
Posted on Apr 16, 2009
  • 202 Answers
SOURCE: I have a LT 1024
There should be 3 safety switches on the mower. 1 will be under the seat, causing the engine to die if you were to fall off the machine while in gear. 1 is in the transmission to be sure the machine is in neutral when you go to start it, and one will be on the blades to insure they are not engaged when you go to start it. You will not want to bypass this switch, rather get it replaced as it is very important that this safety feature is working should you slip off the seat or accidentally get off the machine when it's in gear.
Posted on Feb 17, 2010
  • 10865 Answers
SOURCE: i have a cub cadet lt 1050 need diagram for drive
Hi. All of these questions are answered in the owner manual. TO download one go to this link http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10051&langId=-1
J.
Posted on Aug 03, 2010
agent91
  • 2100 Answers
SOURCE: I put a new pto clutch on my LT 1024 cub cadet
Yeah if you bought a new one, it should be good, the switch is 12 volts, and there is a fuse on it, on some I should say, I just did mine. So get out your tester, check the switch for juice, if none, follow the wires back to the fuse or to the harness, there could be a corroded link there. The old clutch might still be good, save it, they are expensive. I had to pay $75 for a used one. You can test the old one on the bench by jumping it with a battery, it will make the solenoid jump. If it doesn't, it is shot. Check it out.
Posted on Aug 13, 2010
  • 7 Answers
SOURCE: I have a cub cadet,
i have the exact same mower, i also have 13 more cubs on top of it. i have serviced them and many more for over 20 years. does the motor keep running strong, or does it bog down and want to die?? what do u smell when it gets weak like that?? when the deck quits working, does it start back up when u back up out of the brush or do you have to shut the deck off and restart it?? -Brian-
Posted on Nov 07, 2010
Will a model OEM 190-621 snowblower fit on a cub cadet LT 1024
Have you tried the cub cadet forum? If not, give it a click:
http://onlycubcadets.net/forum/forumdisplay.php?f=42
Nov 21, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub cadet lt 1022
Some of these belts cost around $40
Jul 24, 2014 | Cub Cadet Lawn Mower V belt Replaces CUB...
Mower blades will not engage when hot
overheating safetybsprings are wore out. they either got over heated or reached their limits
Jul 24, 2014 | Cub Cadet Garden
Why does cub cadet lt 1024 drive belt keep coming off belt
Once the drive belt comes off once - it's probably stretched and twisted and won't stay on. You'll need a new belt - be sure to get one that's Kevlar so you won't be replacing as often.
May 03, 2014 | Cub Cadet Garden
Have sterring problem cub cadet lt 1024
i have been finding the plastic bushing that holds the steering shaft down into the other gear breaks or wears out that a look there
Aug 13, 2012 | Garden
I have a cub cadet series 1000 LT 1024 need to replace drive belt, how do i get the pto clutch off?
You donot get PTO of to change the belt. if you want to take the pto
clutch Need to turn the opesit way left
May 31, 2012 | Cub Cadet Garden
I have a cub cadet, LT 1024, it sounds like it's loosing power on the deck. When I get to a grass a little taller than 5", it slowes down a lot, and sometimes the deck itself quits working. Can you...
Oct 19, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have a Cub cadet LT 1024 which will not start. The solenoid clicks like it is trying and lights will come on but that is only reaction. Battery is brand new and hooked up properly.
solenoid clicks, only tess you the coil is working inside the solenoid. disconnect cable from battery to starter. with ohm meter check for continuty across main terminals of solenoid while holding key to start. if no continuity, solenoid is defective.
Apr 29, 2010 | Oregon Scientific Electric PTO Clutch for...
Cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
May 02, 2009 | Garden
I have a Cub Cadet LT 1024 Series 1000 riding mower. It has been starting hard and it is not the battery. Now it tried to start and when I tried a second time to start it there was no sound at all. I'm...
Apr 14, 2009 | Garden
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
