Question about Craftsman 10" Table Saw
Saw wont power up all the way
We were ripping 2 x 4s and all of a sudden it just went to half speed.... any ideas?
    Sergeant:
  • 468 Answers
I can't find any reviews or enough information about your saw. Try posting a thread to craftsman support site or call them perhaps.
Posted on May 08, 2013
Bosch 4000 table saw wont power on
The field is notorious for failing in these tools -
If you remove the cap on the field housing you can access the field wires - check to see if you have continuity through the field windings.
To further investigate
1) Remove the brushes and inspect them for excessive wear or chipping (If they look burnt or are chipped the armature is suspect)
2) Remove the 4 screws holding the field assembly to the saw frame
3) Pull the field off and inspect the armature (especially the commutator (copper segments the brushes ride on) for burnt or raised segments or windings.
Dec 11, 2013 | Bosch Work Site Saw 4000-09 With Gravity...
Bosch 4000 table saw tripped breaker. Went to turn saw back on and no power. I replaced the speed control board and still no power? I checked the switch and is fine. Any ideas?
Remove the cap on the end of the motor and remove the 2 carbon brushes. (Ensure the brushes move freely in the tubes and contact the armature)
Remove the 4 screws holding the motor housing to the frame and pull it straight off. Check the copper commutator on the armature and make sure it is not burnt.
22123698-wvjv2ek3boqiwefmtj30yfqx-1-0.jpg If armature and brushes look fine my guess is you have a bad field (very common problem in this tool) #1619PA5590
http://www.ereplacementparts.com/bosch-4000-0601476139-table-saw-parts-c-128_167_168.html
Dec 11, 2013 | Bosch Saws
Only goes half speed
How old is it? Maybe you need to check all the connections, and do a google search, there are lots of similar problems and solutions that lead you to Fixya.
Dec 01, 2013 | Electric Jazzy 1115 Power Wheelchair
Low output on 110 when using power tools
Take and plug in a variable speed drill now when your generator is powered up slowly hit the trigger on the drill start it at low speeds run it for 30 seconds then give it half speed for 30 then full speed fo 30 seconds then try your chop saw
Nov 25, 2012 | 5.5 HP GX160 Engine
Toyota lexcen automatic wont shift out of first gear, reverses well tho
Start with shift sensor. Then go down the line. It is possible something went wrong during the last shift and the transmission sensor locked it down into safety mode to avoid ripping up transmission. If this doesn't fix it you may need a rebuild.
Nov 22, 2017 | Cars & Trucks
I was driving home all of the sudden my car went off so I pulled over checked the engine and I saw that the timed belt was ripped off, I replaced it set it up but still wont start should I looked for some...
Do a compression check on the motor. If it seems to be turning over faster than it did before the timing belt break, you may have bent your valves in the machine head. With out fixing the valves and restoring compression the motor will not run.
Nov 06, 2010 | 2000 Mitsubishi Galant
Bosch 4000 tablesaw suddenly ran backwards and died
I had a customer bring me a saw with this same problem. All components tested OK on my growler. I went on a limb since the speed control and the armature tested OK. I replaced the feild since to me it seemed to be the only component that could cause the motor to run in reverse. Tool now works properly and have had no more problems with the tool.
Dec 02, 2008 | Bosch Electric Table Saws
Dead loptap
how suddenly? like everything was fine then wont go on now? or things were acting strange then - dead? their can be two to three things that have happened, dead battery (flat or split!) blown fuse in the AC TO DC stepdown on the mains power cable. (the box with the little light on the power cable.) or component falure. this will only likley happen if you drop it while its on or similar tho. unless its new? my first idea would be to see if its stil under warrentee then look at a repair quote i would do a job like this for $270 if its a component fail or $150 if its a power systems fail! so dont get ripped of :) ask which one first. good luck!
Oct 08, 2007 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Craftsman 10" Table Saw Logo
70 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
