Question about Konica Minolta DiMAGE G600 Digital Camera
Camera on off slider seems faulty, camera keeps shutting down makeing it Annoying to use .Is there an eas fix for this problem or does it need a repair shop.
  • 5 Answers
SOURCE: konica minolta driver
Try these links:
Posted on Sep 27, 2007
  • 4889 Answers
SOURCE: konica minolta dimage x1
Of course this problem can be fixed but only temporarily..This is the main problem with LCD screen displays.Either you replace the screen and use it for the time being or sell it off before the liquid leaks out completely.
Posted on Oct 08, 2007
SOURCE: service manual?
The manual is posted here.
Posted on Jan 10, 2008
SOURCE: Konica Minolta Z2 SDHC reading card
Spare yourself the trouble. I had researched it (I thought) and got one, and stuck it in. The screen read: "Unable to use," It continued to read this, even after I formatted the card, so I ended up giving it to my brother, who has a Kodak camera. Sorry!
Posted on Aug 13, 2009
  • 11967 Answers
SOURCE: I have a digital camera and it won't read the SD
What does your owner's manual say?
Posted on Oct 06, 2009
  • 21 Answers
SOURCE: need battery door part for Konica Minolta Dimage
e ba -24.99 at this site-
Posted on Oct 23, 2009
0 characters
1 Points
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
"No Card" showing in screen
Check the lock slider on the memory card. it will be on the side. if that fails connect your mem card to a pc and format it.
Apr 04, 2009 | Konica Minolta DiMAGE G400 Digital Camera
Dimage Z6
Hmmm. can you access any menu functions? if so select system reset... never seen that before :-(
Aug 02, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Hi - You can download the manual from the link underlined in blue below:
See page 28, select "Fill Flash":
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 01, 2008 | Konica Minolta DiMAGE G600 Digital Camera
Samsung g600 flash on the cam
go on the camera and then the menu for that and see the lightning arrow thing turn that off
Jan 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
I had this problem with my 600. I noticed that the end, center, part of the focusing mechanism was slightly out of alignment. (The part that usually sticks out furthest.) Once I straightened that piece, it was able to retract and the camera could be closed. Look at the focusing mechanism from all sides to make sure it is straight. The part was very slightly off, but enough to cause the error. My camera has been working fine since.
Aug 14, 2007 | Konica Minolta DiMAGE G600 Digital Camera
Camera keeps turning on and off
HI, Try Replacing Battery . I hope It will Solve the problem. All teh Best Sangita
Jul 10, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Power Compatibility
Look on the power supply or the back of the unit. You will most likely see something like "INPUT 100-240VAC 50-60Hz 15-20VA". If so, then all you need is a plug adapter. If not, you'll need a power converter.
Sep 13, 2005 | Konica Minolta DiMAGE G600 Digital Camera
Konica Minolta DiMAGE G600 Digital Camera Logo
15 people viewed this question
Top Konica Minolta Digital Cameras Experts
Level 1 Expert
Are you a Konica Minolta Digital Camera Expert? Answer questions, earn points and help others
